need a link to PORTSMOuTH cat numbers #29682
02/11/04 06:45 PM
02/11/04 06:45 PM
brobru Offline OP
brobru  Offline OP
Hello All,
May I have a link to current Portsmouth cat numbers,....thanks
regards,
Bruce
St. Croix
Re: need a link to PORTSMOuTH cat numbers [Re: brobru] #29683
02/11/04 06:51 PM
02/11/04 06:51 PM
Reno, NV
pschmalz Offline
pschmalz  Offline
Reno, NV
www.ussailing.org/portsmouth/tables2003.htm
The 2004 numbers do not appear to be out yet.
here ya go... [Re: brobru] #29684
02/11/04 06:51 PM
02/11/04 06:51 PM
Re: here ya go... [Re: John Williams] #29685
02/11/04 07:22 PM
02/11/04 07:22 PM
brobru Offline OP
brobru  Offline OP
Gang,
Thanks,..got it,......I see NO number for a I-20 without spinnaker,..what does one do now?
regards,
Bruce
St. Croix
Re: here ya go... [Re: brobru] #29686
02/11/04 07:36 PM
02/11/04 07:36 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Install a spinnaker.....
Eric Arbogast
ARC 2101
Miami Yacht Club
Use the Mod Factors [Re: brobru] #29687
02/11/04 07:52 PM
02/11/04 07:52 PM
Pensacola, Florida / Katy, Tex...
Cookie Monster Offline
Use the US Sailing Modification Factors. -- Boats rated w/ a spinnaker that don't have one. I think it is factor SN, which means mulitply the rating by 1.020.
http://www.ussailing.org/portsmouth/tables03/modifications03.htm
Don Cook ARC22 #2226 ADRENALIN
Re: here ya go... [Re: brobru] #29688
02/11/04 07:53 PM
02/11/04 07:53 PM
Crystal Beach/Dunedin CSWY Fl.
catsailorp19mx Offline
Bruce,
Go to this link at US Sailing and look at Code SN.
Dave
Re: here ya go... [Re: arbo06] #29689
02/11/04 07:53 PM
02/11/04 07:53 PM
brobru Offline OP
brobru  Offline OP
Ha
It so happens that there was not enough spin boats for a class,....so the I-20 kindly agreed to sail non spi,...
We orinally planned to use Texel,...which has a calculation avaiable,...spin and non-spin for all boats,..posted or not..
..so to keep peace amoung warring islands,..force was yeilded to Portsmouth,....so,...instead of being the 'magic bullet' to cure all ills,....it created a new one..
..ok,..if there is NO posted Portsmouth number,..then you are SOL,.....for , as I understand,..one cannot just 'make-up' a Portsmouth number.....
comments.?...suggestions..
Bruce
St. Croix
ps; regatta is Sat-Sun-Monday,...come on down!
Re: here ya go... [Re: brobru] #29690
02/11/04 08:15 PM
02/11/04 08:15 PM
Bruce,
Someone will correct me if I am wrong, but this is how I'd calculate this situation.
Take the I-20 at it's Portsmouth numbers in the various Beafort wind ranges and multiply that number by the SN modification factor for that same Beaufort wind range.
I come up with 60.38, 64.68, 61.71, 59.77 and 57.67.
This may be entirely wrong, but that is how I see the picture.
Hope this helps.
Dave
Re: here ya go... [Re: catsailorp19mx] #29691
02/11/04 09:18 PM
02/11/04 09:18 PM
brobru Offline OP
brobru  Offline OP
Dave,
Thanks,..that looks like a winner.
We will be in Beau 4 day 1, building winds Day2, Day 3 most likely in B 5
..all in all,..15-20 mph,...2 foot rollers,...air temp 85 f,...water 72 f-ish....will put results up for you Northern types to enjoy.
thanks again to all,
regards,
Bruce
St.Croix
Brobu walk up to that ... [Re: brobru] #29692
02/12/04 06:22 AM
02/12/04 06:22 AM
Brobu walk up to that US I-20 of that guy wanting to participate and measure his mainsail area. Carry a bathroom scale and measure ready to sail weight as well.
Than Texel or ISAF will produce a number.
PN can't just statistically produce a rating number out of thin air.
Re: Brobu walk up to that ... [Re: Wouter] #29693
02/12/04 01:29 PM
02/12/04 01:29 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
I guess I'm missing the point here.
You're sailing portsmouth, hence needing a #.
You use the correction of a spin boat, not flying one.
There's no # for with and without as you say. You have to use the correction, as has been said.
I guess I missed the point somewhere
F-18 Infusion
#626- SOLD it!
Re: Brobu walk up to that ... [Re: Todd_Sails] #29694
02/12/04 02:13 PM
02/12/04 02:13 PM
I agree with Todd. This isn't rocket science. What's so hard to figure out? US Sailing has a Portsmouth Rating for just about any catamaran you're going to run into. There is a rating for that boat. Use the modification factors to alter the rating. If you want to know what an Aqua Cat rates with a Hooter, double traps and a skipper and crew that weigh 500 lbs. you can come up with a rating using the modification factors. When all else fails, read the directions.
Re: Brobu walk up to that ... [Re: Cookie Monster] #29695
02/12/04 02:29 PM
02/12/04 02:29 PM
brobru Offline OP
brobru  Offline OP
Hello All,
..yes, I agree with you all,...it is not rocket science...
...the Texel site even has a spredsheet(Excel) download with the formula in place,..you just put in the numbers,...and let a calculator do the rest
...in this case,,, just change the mainsail size to that os a I-20 North American stock sail ( from the factory),......
...that is why the formula( based on on finite measurements) rating systems are nice,....a 327c.i. 300hp chevy engine is the same every year,....not 350 hp one year,...and then 295hp the next year,....a crude analogy, but the point is clear
..keep is simple,...lets go sailing..
...once again,..thanks to all.
regards,
Bruce
St. Croix
Re: Brobu walk up to that ... [Re: brobru] #29696
02/13/04 01:50 PM
02/13/04 01:50 PM
Hi there Bruce,
Am I correct in my recollection that you were doing the numbers on the P19MX a while back? Now it is the I-20. Are both of these configurations giving you a hard time?
Couldn't resist. I've exchanged posts with you before and "am stepping out on the limb a bit". Hope you take it as a little humor, certainly nothing else intended. :-)
Dave
P19MX "soon to be Tornado spinnaker and snuffer equipped"
Re: Brobu walk up to that ... [Re: catsailorp19mx] #29697
02/16/04 03:50 PM
02/16/04 03:50 PM
brobru Offline OP
brobru  Offline OP
Dave,
I give up with this quest.
We held the regatta,....the questionable ratings' were not changed.....didn't matter,....a H-16 from Puerto Rico beat them all weekend long
...a good sailor always 'beats' the rating,...yes?
regards,
Bruce
St. Croix
Re: Brobu walk up to that ... [Re: brobru] #29698
02/16/04 09:30 PM
02/16/04 09:30 PM
Next time deduct 2 points from the EU I-20 and have a good approximation of the performance. I assumed 1.4 sq. mtr. larger main and 5 7 kgs lighter.
Re: Brobu walk up to that ... [Re: Wouter] #29699
02/17/04 06:04 AM
02/17/04 06:04 AM
Chelmsford, MA
Barry Offline
Barry  Offline
Chelmsford, MA
The problem you are having with the I20 will fix it self. The US/EU I20 will soon be the same boat world wide known as the Nacra 20. Look for an updated Yrxel number this summer.
With this main, the N-20 in Europe will be the identical specs as the NA boats are. Are we gearing up for a NACRA 20 worlds? Note the specs. At PC site are the old main sail area & not the North America spec. which has become the accepted NACRA 20 one-design
0 registered members (), 2,834 guests, and 321 spiders.
