Nacra F18 Changes for 2004 #30055
02/18/04 03:05 PM
02/18/04 03:05 PM
The Netherlands (North West Eu...
RobLammerts Offline OP
Daggerboard:
Photos from above the hulls.
Photo of the new trampoline system.
More pictures at web page
enjoy.....
Rob Nacra 6.0 European version Nr 090 + Spi
Re: Nacra F18 Changes for 2004 [Re: RobLammerts] #30056
02/18/04 05:17 PM
02/18/04 05:17 PM
Michigan, USA
RCochran Offline
RCochran  Offline
Michigan, USA
I think I like the old tramp attachment method better. Less chance of getting your leg caught.
Nacra F17 USA 320 We Don't Need No Stinking Jib!
Re: Nacra F18 Changes for 2004 [Re: RCochran] #30057
02/18/04 09:36 PM
02/18/04 09:36 PM
Florida
JMAC Offline
JMAC  Offline
Florida
Not sure how much of a gap there is, doesn't appear to be as big as on T-boats, etc. I've seen in the past. I agree with the possibility of getting your leg caught, and also know there's a huge chance lines will feed down through there, but I'm on my second tramp with the old style attachment. First thing, loosening up the beams on all 4 corners so you can bust your butt trying to get enough slack to slide it through the slits is a major pain! Secondly, the reason I sent my first tramp back was that the bolt rope on the back end didn't have enough material to keep it in there, and it gradually started pulling out, so I had to take it off and re-feed it back, only to have it pull out again. The solution for this appears to be to have additional material sewn along the trailing edge. Haven't put my new tramp on yet, but hopefully it will have enough material on there to stay now. I think anything is an improvement to this hastle.
JMac
Nacra F-18 #325
Re: Nacra F18 Changes for 2004 [Re: JMAC] #30058
02/18/04 10:45 PM
02/18/04 10:45 PM
I had a new trampoline pull out of the track on my 6.0 recently - turned out that the bolt rope was not stitched in place and had backed out when I installed it. It was enough to get the trampoline started out of the groove and a lot came out at once (fortunately I was on dry land at the time!). Before I figured out exactly what happened, I thought about putting a UHMW (soft plastic) rod in place of the bolt rope - has anyone tried this? I wonder if it will accelerate the wear on the trampoline.
0 registered members (), 426 guests, and 47 spiders.
