| Re: Mast sealing
[Re: Frozen]
#31540 03/27/04 01:14 PM 03/27/04 01:14 PM |
Joined: Nov 2001 Posts: 116 Edmonton, Alberta, Canada Al Schuster
Posts: 116 Edmonton, Alberta, Canada | ok, what if your jib halyard runs up the inside of the mast and tension is controlled with a pulley system inside the mast with controls that extend out to the ends of the beams? Scrap the system, I suppose, but then how do you rig up a fancy jib halyard system otherwise? (obviously, there aren't many other boats to check out in my area, or I would) BTW, 6" snow overnight and still coming down. Is it really spring down South? Al | | | Re: Mast sealing
[Re: Al Schuster]
#31541 03/27/04 04:46 PM 03/27/04 04:46 PM |
Posts: 1,449 | Al, Bring the halyard down inside the zipper of the jib. If you really want adjustment there is aheap of ways of getting luff tensioning back to your man beam.
Many people these days don't bother adjusting the luff of the jib especially if they are running spinnakers or just sailing wild downwind. So even people without spinnakers are tending to set it before the race and forget it.
It you are stuck on adjusting it a wire down one or both bridle wires can help bring it back and depending on the purchase you want a 2:1 at the bridle intersection and another 2:1 between the bridle fitting and main beam is possible. If sailing a tornado with the new jib it could be brought back along the spinnaker pole. Personally, I'd KIS and just set it between races.
Regards, Phill
| | | Re: Mast sealing
[Re: Tornado_ALIVE]
#31543 03/29/04 07:56 AM 03/29/04 07:56 AM |
Posts: 12,310 South Carolina | Or use the good 3M marine sealant - it's designed to take the weather and holds up for a long time.
Jake Kohl | | | Re: Mast sealing
[Re: Frozen]
#31547 04/02/04 10:17 AM 04/02/04 10:17 AM |
Posts: 833 St. Louis, MO, | Will Marine or Plumbers "Goop" work as a sealant?
No, It is too brittle to handle the flexing.
3M 5200 is probably the best. Next to that a good RTV is what I use.
Mike Hill H20 #907
Mike Hill N20 #1005
436
guests, and 52
