Keel repair #31604
03/19/04 01:48 AM
03/19/04 01:48 AM
DanWiz Offline OP
DanWiz  Offline OP
I noticed last year that the gel coat was worn on the keels. I can see the fiberglass, but it doesn't seem worn. What is the best way to repair? Should I apply a coat of epoxy with filler, or lay glass over it? The damage doesn't appear bad and that it only needs to be covered.
Dan
Re: Keel repair [Re: DanWiz] #31605
03/19/04 08:00 AM
03/19/04 08:00 AM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Dan,
I think some Epoxy / filler will do a good job for your situation. I did that same repair on my old H16 a few years ago, using West System Epoxy. Epoxy isn't the easiest thing to sand, so don't expect to put it on thick and then carve it down to shape. Try to get the first thickened coat applied in the general shape of the original keel. You can go back and fill in any defects later. Epoxy doesn't hold up to sunlight, so you'll have to paint it. I was able to find spray paint to match my boat and the repair wasn't very noticable at all.
Jack
Re: Keel repair [Re: DanWiz] #31606
03/29/04 03:45 PM
03/29/04 03:45 PM
Neb
flounder Offline
flounder  Offline
Neb
Ace Hardware, if you have white hulls go with a product called PC-11. It is an epoxy. Easy to work with. Dries white and is tough as heck. I have been using PC-11 and PC-7(grey) for years.
If you beach your cat alot like I have all my life, epoxy is the way to go. It is tough to sand, but that is a good thing when you are on a beach all the time.
0 registered members (), 2,437 guests, and 213 spiders.
