| Re: Another convenience item worth its price...
[Re: MauganN20]
#31964 04/01/04 03:00 PM 04/01/04 03:00 PM |
Posts: 1,884 Detroit, MI | I wouldn't race with it on your body, though. Hobie Class Rules: 18.1 b) Weight and water jackets for the purpose of adding personal ballast are not permitted, shall not be considered clothing or equipment, and shall not be allowed for meeting minimum crew weight. Try explaining to a Jury that it wasn't being used to increase your weight (especially when it works just as well attached to the trampoline). | | | Re: Another convenience item worth its price...
[Re: MauganN20]
#31966 04/01/04 03:13 PM 04/01/04 03:13 PM |
Posts: 12,310 South Carolina | Seriously - US Sailing has the same kind of rules and camelbacks and such fall into such a category. I have one and live by it for long distance racing but for around the bouys I leave it in the trampoline bag. Race organizers should put an exception in the racing instructions to allow them and while I usually check with them ahead of time, I have yet to see a written exception.
I'm in the process of sewing on (figuring out how to) some heavy duty velcro and a nylon security strap so I can velcro my camel back to the back of my life vest so I can eliminate the additional straps around my torso (that could get entangled).
Jake Kohl | | | Re: Another convenience item worth its price...
#31968 04/01/04 03:29 PM 04/01/04 03:29 PM |
Joined: Sep 2003 Posts: 270 Nepean (Ottawa) Ontario Canada Frozen
Posts: 270 Nepean (Ottawa) Ontario Canada | I'll drink to that one!
I got one for long distance bicycling. I did my first century (150 mile ride) with one. Had no previous long rides. Man, that water bag gave me new legs.
Try some of the stuff they have in Bike shops to give some taste and energy to the water. If you choose the mixes carefully, you won't glow in the dark or anything!
I like the idea of attaching it to the lifejacket, as long as it won't make you go face down if you land in the water. Maybe put it on the front? (I realize it would be less convenient)
Cheers Alan F
Tiger
[Re: Frozen]
#31969 04/01/04 04:02 PM 04/01/04 04:02 PM |
Posts: 12,310 South Carolina | it's full of water so it has neutral bouyancy in the water -it shouldn't affect the life jacket's righting moment. Besides, most of the life jackets we use will not orient you face up anyway (try it). I always bleed the air out of my camelback after filling it so it doesn't slosh and disturb the beautiful wooshing wind and water sounds. As far as the rules go - I can identify with it...I mean what's next? A jacket full of lead to give more righting moment? Granted, I think an exclusion should be made for camelbacks given that they fall below a certain weight or volume limit.
#31970 04/01/04 04:42 PM 04/01/04 04:42 PM |
Posts: 270 Nepean (Ottawa) Ontario Canada | Another thought is to partially fill with liquid the night before and throw it in the freezer, laying it flat so it hardens with the flat on your back... side. (no other way of saying it.)
Then top it off before you go. You'll have a full day of icewater. We used to do that for hang gliding excursions.
Cheers Alan F
Tiger
#31972 04/01/04 04:54 PM 04/01/04 04:54 PM |
Posts: 1,884 Detroit, MI | This is from the ISAF web site here (ii) Camel backs The issue of Camel backs (Drinking containers worn by the competitor), mentioned in the 1996 Olympic Regatta report dated October 1996, was discussed. Competitors will be able to carry drinking water on the boat. In view of the prohibition of weight jackets, camel backs will simply replace weight jackets.
Recommendation For classes other than windsurfers, camel backs and similar devices must be prohibited by the Racing Rules Committee. This was from the November 1996 Centerboard Boat Committee meeting minutes. The prohibition was placed in the 1997 rule book when they dropped the clothing weight limit from 15kg to 8kg. The problem with water jackets is not while you are in the water. It's when you try to get out of the water that there's a problem. Anybody that's gone for a swim in a leaky drysuit can attest to that. | | | Re: Another convenience item worth its price...
[Re: Frozen]
#31977 04/02/04 01:23 AM 04/02/04 01:23 AM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | Anybody read the Worrell 1000, Atlantic 1000 or Great TX rules?
"BLADDER PACKS
One (1) liquid filled bladder or similar device (commonly called a “Camelbak”) with a capacity not exceeding seventy (70) liquid ounces may be worn by each sailing team member for the purpose of liquid consumption. These devices shall not serve as Crew Weight as defined by Rule 20"
The exact same rule is posted in the Great TX SI's/Rules.
The Atlantic 1k states it a little different, but same rule anyway.
"7.3 The combined weight of the sailing crew shall be a minimum of 325 pounds. Crews not meeting minimum weight requirements may elect, at the discretion and approval of the Race Committee, to place weights on the front beam of the race boat. No other additional weight with the exception of prescribed equipment and 5 pounds of potable liquid per crew member, contained in bottles or “bladder” type packs will be allowed" (The Atlantic and TX races allow 4.55lbs of water)
By the time you put all your required gear (VHF, EPIRB, knife, whistle, strobe, GPS(s), Cliff bar(s), multi tool, spare parts) on your person, the thing feels like a weight vest.
I think the best configuration I have worn has been with the pack stitched to the life jacket. I know a few that wear it under their PFD, but I think the stitched version is a better deal. You will be hard pressed to find any serious distance sailor that does not routinely wear one.
Depending on the weather, 1 or 2 32oz Gatorades and 1-2 16oz waters on a typical buoys day. Don't think I've ever lost one while on the water.
Read the way this is worded, "Weight and water jackets for the purpose of adding personal ballast are not permitted, shall not be considered clothing or equipment, and shall not be allowed for meeting minimum crew weight"
They are saying you cannot carry it to make weight. "adding personal ballast" is the key. | | | Re: Another convenience item worth its price...
[Re: mbounds]
#31979 04/02/04 06:55 AM 04/02/04 06:55 AM |
Joined: Aug 2003 Posts: 125 Cape Coral, FL pete_pollard
Posts: 125 Cape Coral, FL | I think water jackets are fairly common in dingy racing; not sure what the rationale for this rule is on cats.
"Cat Fest Sailor"
Pete in Cape Coral
[Re: Frozen]
#31980 04/02/04 07:06 AM 04/02/04 07:06 AM |
Posts: 12,310 South Carolina | Speaking of a convenience item worth it's price! EPIRB = Emergency Position Indicating Radio Beacon.
It's an emergency transmitter. Originally they used to send out a homing signal on emergency frequencies that were monitored by aircraft. Since the modern satellite area, in addition to the homing beacon, they communicate with the satellites to get the distress signal to the coast guard. There are different types; some even interface with or contain a GPS to send out exact positional data; some work only in coastal waters (these are being discontinued), some out to sea and all over the place. Even backpackers and hikers are beginning to carry them.
#31982 04/02/04 08:30 AM 04/02/04 08:30 AM |
Posts: 270 Nepean (Ottawa) Ontario Canada | Jake
Are they the same as aircraft ELT's (Emergency Locator Transmitter) in that they transmit on 121.5 (aircraft band) and I believe double that on 243?
We monitor that freq on our second VHF on our aircraft. We (and everyone else) refer to it as "On guard".
The reason I ask is that when we hear an ELT signal we automatically assume it is an aircraft, so this is a different twist.
I have seen those transmitters somewhere in a boating store, but I didn't notice what freq they were on.
Cheers Alan F
Tiger
1 registered members (FredL),
343
guests, and 59
