| Re: righting a 16
[Re: mbounds]
#32916 05/06/04 04:24 PM 05/06/04 04:24 PM |
Posts: 152 Central Texas | Regarding the wind conditions, I made similar experiences. While I am(160lb) able to get the cat out of the water on >15 mph days, I was not able to get it out a few days ago when it was relative mild. My cat is currentely equiped with a righting line. I'm thinking Soloright right now...
Patrick, Hobie 16 '85
| | | Re: righting a 16
[Re: Broken_Leg_Sailor]
#32920 05/19/04 04:47 PM 05/19/04 04:47 PM |
Posts: 152 Central Texas | I do not have a Soloright, but I have seen the pics on the website while it was still up... IIRC the soloright is basically an oar that the inventer reinforced with some composit material (carbon or glass fiber)one side of the oar (the paddel shaped end) will be placed in the lip (with lip I refere to the lip that for example accomedates the stainlesssteel rod that holds the shrouds) on the inside of an hobie hull (the lower hull). The other end of the oar is suspended by two lines (halyard type) to the pylons of the upper hull. The user is expected to step outwards on the oar while holding on to the line of a traditional rightning system. The oar could be replaced by some kind of pole stiff enough to support 200 lb. The oar idea was kind of nice since it also functioned as a paddel (an unfortunately long paddel).
Patrick
| | | Cel Phone in waterproof pouch is a wise fall back
#32925 05/23/04 04:13 AM 05/23/04 04:13 AM |
Posts: 9,582 North-West Europe | Cel Phone in waterproof pouch is a wise fall back option.
Of course other means of emergency solution should be implemented as we need to make as little use of rescue services as possible.
Water
| | | Re: Cel Phone in waterproof pouch is a wise fall back
[Re: Wouter]
#32926 06/07/04 12:36 PM 06/07/04 12:36 PM |
Posts: 152 Central Texas | Hmm... I did not expect that the weight of a cell phone would make a significant difference in the sailor’s ability to righten a cat... (Sorry could not restrain myself) I think that practice proper techniques and suitable equipment (solo right, righting pole, water bucket, shroud release) and the skills necessary to use the stuff are the way to go. I guess what I like about this forum is the discussion and user feedback in context with stuff that works. Since the solo right might not be available at this point, I will try to build a similar device based on a defective windsurfing mast. In case it works I will post my experience and some pics of the thing. I do not like the cell phone idea. A cell phone or better a radio should be the last resort - when every thing else fails. Having one available is not a bad idea. At the same time it might provide a faulty sense of security.
Patrick
609
guests, and 45
