Leakage #33008
05/10/04 06:21 AM
05/10/04 06:21 AM
Netherlands
willemm Offline OP
willemm  Offline OP
Netherlands
Help! Significant amounts of water enter my right hull during sailing. What's the most common cause? Any tips on methods how to localize the leak?
Willem
Re: Leakage [Re: willemm] #33009
05/10/04 08:47 AM
05/10/04 08:47 AM
beaufort, sc
dannyb9 Offline
dannyb9  Offline
beaufort, sc
you can get a hair dryer or a vacuum cleaner that blows air to pressurize the hull, then use a wet sponge and soap and look for bubbles. i've had leaks from a crack in the bottom, a drain plug that needed new sealant, and leaks around the pylons. the hull/deck joint and gudgeons are also possibilities
marsh hawk
0 registered members (), 2,673 guests, and 261 spiders.
