Portsmouth # for F14 #33490
05/20/04 08:26 AM
05/20/04 08:26 AM
Houston
carlbohannon Offline OP
Houston
Has anyone asked for a Portsmouth # for the F14? It would probably be a good idea to start with the Mystere 4.3 numbers.
I am going to try to race my boat at GBCC with the full height mast and a test sail.
Re: Portsmouth # for F14 [Re: carlbohannon] #33491
05/20/04 11:04 AM
05/20/04 11:04 AM
Carl,
With all the different configurations, it is not fair to stick everyone with the same number. US Sailing already provides modification factors for the boats and that is what I use when sailing in P/N races. I mulled over this for quite some time with no solution. Even if we came up with some number for the max allowable sailarea, I don't think anyone would really be using that much sailplan anyway and that to me is not fair.
Our rules are loose enough to cause this problem and that is why the P/N mod factors are a good choice to use. The F18 class is alot more stringent and can come up with a number.
Bob
Huh?? #33492
05/20/04 12:15 PM
05/20/04 12:15 PM
Bob, I thought the idea was to get a F-14 number so that we're all racing straight up... You did a horizon job on the 4.3s in GA... why would you want us to give you time, too?
Re: Huh?? [Re: John Williams] #33493
05/20/04 12:53 PM
05/20/04 12:53 PM
What would you suggest that would be all encompassing?
Bob
Re: Portsmouth # for F14 [Re: carlbohannon] #33494
05/20/04 04:36 PM
05/20/04 04:36 PM
Norfolk, VA
Dan Berger Offline
Dan Berger  Offline
Norfolk, VA
It seems to me that in an F14 class, as long as you fit into the box rules, there is no handicap. The only exception would be the newer style dagger board boats vs. the older style like hobie 14.
I don't see how you could sail in a regatta as an F14 without others and be scored fairly. You would be better off (in the H14 case) by taking the hit for the oversized main and the addition of the headsail.
The F18s are all close enough (IMO) to have a Portsmouth rating, but I bet if the PR for their individual boat is better, they would race under that for an open regatta!
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Portsmouth # for F14 [Re: carlbohannon] #33495
05/21/04 03:28 AM
05/21/04 03:28 AM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
I thought the whole idea of F14 was to develop a formula which promotes innovation by allowing some development in 14ft cats. If you are advocating 'sub' classes within the formula with varying yardsticks/Portsmouth numbers it really defeats the purpose of the class as I see it. I mean there would be no incentive to continue to develop your boat, a. because you would already be competitive on yardstick and b. if you continued development the boat would simply attract an equalising Portsmouth number and nothing would be gained. This is assuming that some miracle formula could be developed to make all the various configurations equal in the first place which is almost impossible.
No IMHO F14 must simply be scratch racing and if you want to race under a Portsmouth number, best leave the boat 'existing one design' class legal.
Bern
Re: Portsmouth # for F14 #33496
05/21/04 08:30 AM
05/21/04 08:30 AM
Houston
Houston
Having a Portsmouth # for F14 does not preclude anyone from racing as a one design with mods. You simply register as whatever you are and give the mods.
Not having a # Portsmouth leaves specialty boats out in the cold. Such as custom boats and boat that are so modified that hey scare the race committee.
No matter what, I am going to have to apply for a Portsmouth # and I am going to look a whole lot like an F14 with and without a spinnaker.
It would be better if we decide on a preliminary number together. We can call this thing whatever we want, so as not to confuse it with the modified production boats. Call it EXP 14.
With no port mouth # there is no incentive to build a boat. Though if 2 boats are built this year I will be surprised
Re: Portsmouth # for F14 [Re: carlbohannon] #33497
05/24/04 07:08 AM
05/24/04 07:08 AM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
I'm sorry, now I see, you want to race your F14 in a mixed fleet for overall placings on yardstick within the whole fleet against all comers. In Australia we run 14ft only regattas and within those you either race for line honours (F14), or to existing one design yardstick places. Generally Formula class boats F16, F18, race as a class and not for overall line honours against all comers.
I'd say, given that my 430 without a kite runs with tail end H16's, that the H16 number would be somewhere about right when fitted with a kite. Just my opinion.
Bern
I see that there are two issues... #33498
05/28/04 11:00 AM
05/28/04 11:00 AM
I guess we're talking about two different things - Carl is looking for a base number for he and other home-builds to use when his boat is complete. I'd say the 4.3 numbers are a good jumping-off point. It also seems like you're saying, Bob, that you don't want the modified Hobie 14 to get lowered to the 4.3 number in open Portsmouth racing. I'd be OK with that when there aren't other Formula 14s on the race course. I'd contend that you could run with the 4.3 numbers just fine - I base that on your performance at Spring Fever.
In addition, on the Portsmouth side, I don't think the spinnaker modifier you're taking accounts for the modified Hobie 14 being able to carry the extra sail area upwind as well as down. The spin mod was calculated on downwind only, so you're only getting a half-hit. Work that in and you get closer to the 4.3 number, but they still owe you time.
Am I looking for a number that will make Bob come in second? Of course not - he's got years of experience and more than a thimble-full of talent to back it up. He can take all comers. If we're to get the 14 thing off the ground, though, we need to agree to ask US SAILING for a number and then let the data accumulate, just like anyone else's class. And we'll need to use it or it won't have credibility. Otherwise, we might as well be saying, oh, I dunno, something like "you know, the Formula 18 idea is fine, but there's one that is notably faster than the rest and it should get a seperate Portsmouth number..."
Re: I see that there are two issues... [Re: John Williams] #33499
05/28/04 03:55 PM
05/28/04 03:55 PM
Yeah - I'm with John. F14 needs to have a single Portsmouth rating for all comers. If you're the only Monster H14 / F14 at a regatta it's your choice to use the Portsmouth mods or the F14 number. This does not mean that all Mystere 4.3's all of a sudden have to race the F14 number but it does give Carl something to race with.
Re: I see that there are two issues... [Re: Jake] #33500
05/31/04 05:46 AM
05/31/04 05:46 AM
I would like to see a M4.3 use a reacher instead of the spin and accumulate data with that rig versus the 14 with reacher. I guess my rig was optimized for the light air we had at Hartwell. Higher winds would have kept the reacher furled until the downwind legs. So I'm skeptical on this sudden rush for a number with only a 0-3kt regatta under our belt. I'd like to see Carl sail his boat against a Hobie 16 or something similar for a comparison before we ask for a number. In other words, I'm all for a F14 number but let's take our time and collect some data before we run off to US Sailing for a preliminary number. Who's going to be the first M4.3 to put up a reacher?
Bob
Re: I see that there are two issues... #33501
05/31/04 10:12 AM
05/31/04 10:12 AM
Allow me to simply clarify my original thinking of the F14 concept:
Originally, no P/N was contemplated. It was conceptual to race together as a fleet, not in mixed racing. US Sailing already has modifiers in place for that form of competition. Now, everyone wants to race P/N. And again, I oppose a number right away until data is collected. It only complicates the original intent. Keep it simple and it will fly: complicate it and it will fall. It was simple up to the Spring Fever race. Now, it seems (IMHO, to me) like we are getting stuck.
Bob
Re: I see that there are two issues... #33502
06/01/04 08:32 PM
06/01/04 08:32 PM
Bradenton, FL
Sycho15 Offline
Sycho15  Offline
Bradenton, FL
We need another race to compete in. When's the next big thing in the South-East?
Re: I see that there are two issues... #33503
06/01/04 10:38 PM
06/01/04 10:38 PM
Mike Fahle Offline
Mike Fahle  Offline
FWIW, I agree with Bob. Portsmouth numbers and mods already exist for handicapping existing boats with any mods they use. Why come up with a number for a boat that MAY be built? It is hard to believe that someone would want to build a boat to the F-14 rule, then decide not to only because there was not a Portsmouth number assigned for all F-14s already! If you DO insist on an F-14 handicap, then as a race organizer interested in fair handicaps for all, I want it to fairly rate the fastest possible boat that will come from the box rule but as a Mystere 4.3 owner, I do not want to use that number as it would not be fair for my boat (which I believe is the fastest production boat available as an F-14). So forget about an F-14 rating. The current Portsmouth rule is fine as is for individual boats and when there are enough F-14 compliant boats together at a given event, we can race one-design as F-14s.
Please keep in mind two very important points:
1) As Bob already wrote, Spring Fever conditions were very light and not a valid comparison of relative boat speeds. Remember also that more than one boat was rigged like Bob's and were sailed nowhere near as fast as Bob's.
2) In the U.S. at least, the main idea of this effort was to get existing classes together with some relatively easy and inexpensive mods to make one-design racing. If someone wants to start from scratch they should be able to build a significantly faster boat with the allowable parameters than what already exists in the existing production classes, even with mods. (considering the A class as a guide, it should be possible to produce a lighter boat - under 150# - all up, with twice the sail area!) We will have to address that disparity if and when enough boats exist to make it an issue, but we do NOT need an F-14 class Portsmouth number!
Re: I see that there are two issues... [Re: Mike Fahle] #33504
06/02/04 05:50 PM
06/02/04 05:50 PM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
Exactly.
As I said previously, an F14 built to the existing class rules will be well amongst the H16's or possibly even better than that sailed well off the breeze so the H16 Portsmouth would probably be a reasonable starting point, however not too many existing F14's can race successfully to that number if any, except probably my 430.
If the H16 Portsmouth number was adopted, it'd spoil any chance for most F14's to place well at an open regatta.
Bern
OK, so what we're agreeing to is... [Re: Berny] #33505
06/03/04 01:09 PM
06/03/04 01:09 PM
We'll sail the F-14s straight up any time there are more than one on the course, and we'll continue to use the DPNs with any modifiers necessary in open fleets. This may be tough for organizing authorities to handle, but it sounds like it may not come up too much - we'll see this weekend, as Bob and I are both doing a two-day event in Navarre on 14s (unless he brings his 17??)
Now, back to the original topic for this thread - Carl wants to know what number to use for his home-build project. Not up to me to get or assign one, but I think you'd be safe asking the Portsmouth Committee to give you a note indicating the 4.3 number as a start, though it sounds like you have the potential to be a bit faster. Keep in mind that the host of any event that you enter generally reserves the right to assign you a number if they have any beef with what you've got. I've never seen that right abused - generally it's the addition of the "miscellaneous" modifier, which doesn't change much at all, but pacifies some 20-footer with heartburn.
Everyone happy with this? Let's pick the next event! How about the Horn Island race in Mississippi July 3 and 4? How about something further north? Let's keep it going somehow...
Re: OK, so what we're agreeing to is... [Re: John Williams] #33506
06/04/04 09:44 AM
06/04/04 09:44 AM
RickWhite Offline
RickWhite  Offline
For a major race, I would like to suggest the NAMSA North Americans/Tradewinds Regatta in the Florida Keys in January over Martin Luther King Weekend. We usually have anywhere from 50 to 110 boats. and usually lots of wind.
We could make this our F14 Midwinter Championships.., or something to that effect.
Rick
Rick White
www.onlinemarinestore.com
Re: Portsmouth # for F14 #33507
07/12/04 01:08 PM
07/12/04 01:08 PM
Surabyakid Offline
Surabyakid  Offline
I want to check to see if understood the gist of this thread.
At the Oriental Sailing Social this weekend, I was talking to a few Isotope sailors over the post race beers. They indicated they were sending race data on the Isotope in an effort to get a modification to thier Portsmouth Number. They suggested submitting the F14 data as well from our club racing. I said that my understanding was that the F14 class would compete straight up against each other and that we would use our original one design class number plus the appropriate mods when racing open fleet for those who are racing refitted boats and a derived (method unknown) number for those who custom build.
Did I get this right?
Pat
PS: A couple of the folks indicated they may be considering a Cheshire Cat based F14.....
Re: Portsmouth # for F14 [Re: Surabyakid] #33508
07/13/04 05:56 PM
07/13/04 05:56 PM
Hi Pat -
Since nobody piped up to answer you, I'll jump in. You're spot on as far as I understand things. We're agreeing to race all the F-14s straight up, and use our various class numbers with mods in open fleets. That means going to the oganizers for any races you plan to attend and asking for an F-14 start with seperate scoring, or at least asking that all the F-14s start in the same open fleet start and sail the same course so you can figure out the results yourself. So far, regatta hosts have been very accomodating, particularly if I volunteer to help with the scoring.
As far as the home-builds, I'm not sure what to say - I guess once somebody gets one finished, we'll ask Darline for a provisional number like the CFR 20 and P19MX did...
Re: Portsmouth # for F14 [Re: John Williams] #33509
06/23/05 03:06 PM
06/23/05 03:06 PM
Richmond, VA
Rich Offline
Rich  Offline
Richmond, VA
So, has anyone followed up on a P-number for a homebuild? I have a little project going here...Someone home built this out of what appears to be donor parts from a Solcat 18. It was first titled in Michigan in 1996.
14'3" Long, 7'11" Beam, 24" Mast Extrusion (since I cut it) Weighs in at 230 lbs at the moment...will go on a diet soon enough.
Hulls are cedar strips over tortured plywood.
Took it out this past weekend and she sailed pretty well as a uni-rig with about a 120 square foot main. Jib should be on by the weekend of the 4th of July for my next test.
I can stall the sails with the best of 'em!
0 registered members (), 2,772 guests, and 540 spiders.
Yesterday at 10:10 AM
