| Bloody bad luck !
[Re: ]
#33626 11/28/04 09:17 PM 11/28/04 09:17 PM |
Posts: 9,582 North-West Europe | I'm trully sorry if I caused all this, Gary.  Would I be correct if I assume you reinforced the outside of the hulls but not the insides ? Bloody bad luck, Gary. A real pitty. >>hope you guy's don't mind a sad post. Surely not, this is drama. There wouldn't be any exitement if there is no risk of failure. This time, the risk won out over good fortune. But I for one have heaps of respect for you for starting on an adventure like that. You're my hero. I remember running heaps of numbers on the basic Taipan platform to determine the right modifications. I remember the feeling during the first times out on the water. I understand the greatness of the project you choose to undertake. Together with the others I hope she is salvageable. This project has trully won the hearts of the sailors on this particular forum. If I may; I've you choose to repair it and the failure was on the unreinforced inside of the hulls than I would advice you use the same cloths for the reinforcements as was used to build the hulls. Using a different cloth can still lead to problems as, for example, glass and carbon have different properties leading to staged failure. Meaning first the stiffer carbon will fail as the more flexible glass will not take any load at that time. Then all the load on the glass again, which will fail in sequence. Using the same material for the reinforcements is a good way to prevent that. I'm sure you know this yourself but I just wanted to make sure. But again Gary, bloody shame this happened. Hope you will rise from the flames and get altered back, with you in the saddle. Wouter
| | | Re: Bloody bad luck !
[Re: Wouter]
#33627 11/29/04 09:08 AM 11/29/04 09:08 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | Oh NOOOOO !!! Sorry to hear the news Gary.  I saved all the pics of her on my pc, and look at them often. You just HAVE TO FIX her ! (I know it`s easy for me to say that when you have to put all the money & hard work in, but I really hope you get her back out there soon.) Good luck, Steve | | | Re: F16 One up .
[Re: ]
#33628 11/29/04 07:07 PM 11/29/04 07:07 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Whoa. I know you Australians have quite the sense of humor, and I've had my leg pulled more than once by you guys. So, I'm just wondering if this is really true--did Altered really meet demise?
| | | Re: F16 One up .
[Re: ]
#33630 11/30/04 12:16 AM 11/30/04 12:16 AM |
Posts: 851 US Western Continental Shelf | Gary,
My sympathies. Thanks for taking us along for the ride. Beautiful work! Hope you find a way to revive her.
In any case, thank you so much for sharing with the world.
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: F16 One up .
[Re: phill]
#33632 12/01/04 04:38 AM 12/01/04 04:38 AM | Anonymous
| Anonymous
Unregistered | Hi all, you guys are unreal thanks for the support. This realy does feel like a community of sailors, certainly makes me feel better.
Still don't know what I am going to do with Altered will be getting it looked at by others this weekend, I am still going to take it to Colac, am sure I will get lots of expert? opinions but there will be at least one boatbuilder there with experience of this kind of repair. I hope to get it fixed by a boatbuilder, as I just don't have time available now. If I can't get it fixed by boatbuilder I will be in further touch with Darryl and Phil there expertise is much appreciated.
Regards Gary. | | | Re: F16 One up .
[Re: David Parker]
#33635 12/01/04 01:25 PM 12/01/04 01:25 PM |
Posts: 9,582 North-West Europe | David, Matt
The same thoughts occurred to me as well.
First the Bridle seems a little low to me as well considering the hulls were modified A-cat hulls. Personally (as I didn with my own boat) I would have raised the bridle intersection and used a extra 3rd line to keep up the blue snuffer mouth. In altereds case I would have placed the bridle strop some 2 mtr's up from the decks and have it then continue as a single stay.
Having double forestays is not what you want to have on a spi boat as the spi tends to get blown between the stays to often. A single forestay with a high bridle strop seems to be the best compromise.
David. F16 is both sloop and uni-rig. We sail sloop when doublehanding and uni-rig when singlehanding. Gary only sails singlehanded as far as I know and has no jib as a result.
I agree with Matt that the most simple reinforcement against the most likely cause of the failure would be to just laminate an extra skin to the outside of hull that is just inside and in front/below the mainbeam. The failure seems to me to be a compression buckling failure caused by the increased bending stresses due to the bridle strop. You probably have added 400 kg sideways load to the hulls = ALOT.
The fibres can probaly take the laods but not if they become unstable when the hull starts to get out of colom (rimples along the hull) and moves sideways inward and/or outward. Thickening the wall will prevent this rimpling effect and thus induce more strength than would be expect by just adding the cloth.
But we need to be sure that this failure under compression buckling was the case of this. A sub deck is the most effective solutions as that would completely stabilize the walls.
Get up back there on that horse Gary !
| | | Re: F16 One up .
[Re: Wouter]
#33636 12/23/04 07:48 AM 12/23/04 07:48 AM | Anonymous
| Anonymous
thought I would give you an update on Altered. All has finaly been sorted out and boat is being fixed and strengthened by McKenzie Composites as we speak, hope to be back on the water in a few weeks. Bigger better stronger etc. Can't wait to get back on the horse Wouter.
Hope to be racing end of January long weekend in OZ lots of sailing on, maybe even in South Australia, Phil what to you think of Milang Goolwa?
Febuary is looking very busy possibly travelling interstate for reggattas every weekend. Still working on trailer to make sure it is up to scratch.
Anyway hope you all have a good christmas and a happy new year, thanks for your support through the good and bad times with Altered.
[Re: ]
#33637 12/23/04 09:14 AM 12/23/04 09:14 AM |
Posts: 9,582 North-West Europe | Can't wait to get back on the horse Wouter
From you I expect nothing less !  Happy X-mas and best wishes for 2005 to you too Wouter
569
guests, and 1,269
