| Re: Lighter mast makes the Tornado safer!
[Re: Hakan Frojdh]
#34735 07/19/04 04:56 PM 07/19/04 04:56 PM |
>>... The current alu mast has an s-shape instead of a normal bend wich makes it very difficult to get a proper sail shape
The carbon mast will have a S-shaped bend in it while sailing as well. This is the result of the way the stays are rigged to the masts on the cats. Carbon or not Carbon is of no consequence.
| | | Re: Gabler letter and Grandfield response
[Re: Kevin Cook]
#34736 07/23/04 11:51 AM 07/23/04 11:51 AM |
Posts: 1 | Kevin, Are you still building carbon boats? email me at c_boyd99@yahoo.com I have a project I want to chat with you about. Thanks | | | Re: Lighter mast makes the Tornado safer!
[Re: Hakan Frojdh]
#34738 08/31/04 03:40 PM 08/31/04 03:40 PM |
Posts: 284 S. Florida | Hello Hakan, There is one very important point you did not mention. 1. The price of the Tornado just went up $5,000 plus US dallars. The boat is now a 30,000 dollar boat instead of a 25,000 dollar boat. 2. The weight of the carbon mast will not be 10kg lighter than the aluminum mast. Maybe a 5kg reduction is possible. If the new carbon mast is made to the same section as the present aluminum mast, it will be very very stiff. This means a new mainsail luff curve is required with much less curvature will have to be developed for the carbon mast and here goes the $$$$, dollars, running away again. Also the stiff carbon mast with reduced bend will make sails less versitile. Now the Tornado sailors will need light wind sails, medium wind sails and strong wind sails; the $$$$, dollars run away again. 3. The reason masts of any material bend in an S shape with spinnaker up is that the spinnaker hounds is too high above the main hounds, too much cantilever. Lower the spinnaker hounds is one solution. Another very simple and inexpensive solution is "back stays". Then you might as well go masthead with the spinnaker. 4. The present aluminum Tornado mast does have very little structural margin with the spinnaker and double trapeze. This is no surprise. A slightly larger aluminum mast section would be one answer. The cost of the new extrusion die equals the cost of one carbon mast. Summary: What it comes down to is the Tornado class wants a carbon mast no matter what. To have it bend properly and have a thick enough wall so that the new mast does not have local buckling problems, the carbon mast section MUST BE SMALLER with a thicker wall. Then the class can have a mast that is bendy as the present aluminum mast and is tough at the same time with a reasonable wall thickness. The new smaller section carbon mast just made several hundred Tornado masts, maybe thousands, of aluminum Tornado masts not competitive. For a class to go from an aluminum mast to a carbon mast is one tough question. It has major impacts on many facets about the boat. It is not nearly as simple as "substitute carbon for aluminum and save 40% in mast weight and go for it". Good Luck, Bill | | | Re: Lighter mast makes the Tornado safer!
[Re: BRoberts]
#34740 08/31/04 04:28 PM 08/31/04 04:28 PM |
Posts: 1,200 Vancouver, BC | Cost of the carbon mast from Marstrom will be held at 2860 EURO (~$3500 USD) with all fittings. Cost of an alloy mast with all fittings is nearly 1700 EUR0 (~$2100 USD)...a diff of $1400...where is the $5000 increase coming from? Whole boat is ~$22,000 USD...about a 6% price change for a carbon mast rig. Minimum weight to be 15 kg...end weight to be set prior to final production by Marstrom. Why do you say the section thickness will be the same as alloy, thus making a very stiff stick? I see no mention of it in the proposal: Rule Changes Mike.
[Re: jfint]
#34741 08/31/04 04:36 PM 08/31/04 04:36 PM |
Posts: 1,200 Vancouver, BC | Josh, the whole point is to stop people buy specially designed masts of alloy that are of limited availability. This creates an unfair competition. Also, the fact the top teams spend big bucks on numerous alloy section masts until they find a few they like (extrusion inconsistency), makes it quite expensive to be competitive. Finally, equipment costs of an olympic campaign are a drop in the bucket with respect to the costs of training/travelling globally for at least a few years. Greg Scace, a USA campaigner until recently, told me his teams budget two years ago was $100,000 USD for ONE YEAR!!!...and that would ramp up significantly the year prior to the games. His main sponsor (and employer) got caught in the dot-com burst and dropped their committment. His olympic dreams died that day. This i'm sure is just barely relevant to the subject, but as someone who has just become part of a partnership to start racing in the olympic class with an old, albiet still new in packaging tornado, this is kinda dismaying, because when this becomes the standard we will not be able to afford the change. The price of entering this game is daunting enough already, how much can the cost go up before you virtually eliminate new sailors entering your class?
[Re: jfint]
#34743 08/31/04 04:58 PM 08/31/04 04:58 PM |
Posts: 3,116 Annapolis, MD | I have an 8 year old boat with one of the original pre spin masts.... I don't double trap with more then 380 lbs on the boat because I fear I will break it going up wind....(Advice of Darren Bundock) Down Wind.... I blow rotation to allow the mast to rotate to 90 to keep it together in a breeze.
When I break it.... I would much rather put a carbon mast on the boat and get a (new to me).. slightly used sail from someone on a campaign. The technology will be superior to anything else on the market.
If I sell the boat to a cruiser... an aluminum stick will be just fine for them as well.
The Olympic guys want a carbon mast for two reasons:reproducibility and cost control based on the class president's letter.
Reproducibility... They seem to collect sticks to find the proper one for them.....They believe that the carbon masts will be far more reproducible and so cheaper in the long run. Cost Control.... Well funded campaigns (the Brits) have a mast program on going so the cost of playing just went up enormously.
With respect to a the cost of the boat... an I20 with carbon mast is close to 16K.... Is a Marstrom worth a 5 or 6 K premium?? ... ABSOLUTELY... the boat is bullet proof for 10 years and holds it value longer.
With respect to a campaign... the cost of the boat is trivial compared to the cash needed for sails, travel regattas and coaching.
Take Care Mark
crac.sailregattas.com
[Re: jfint]
#34744 08/31/04 05:38 PM 08/31/04 05:38 PM |
Posts: 1,200 Vancouver, BC | Clarification...only Alu Alloy masts were allowed until today. Now carbon is permitted, but only masts from recognized builders. Marstrom will be the only recognized builder for two years (at least!) to allow them to recoup tooling/development costs. Price is to be held at the 2800 Euro amount unless carbon costs rise significantly. Sad fact is, $1400 is peanuts to a serious team...that's the reality of competing at this level. Good news is there will be lots of very good alloy tornado masts flooding the used market in the coming months...plenty to keep the average joe happy for years to come. But no new extrusions will be made. OK so maybe i misunderstood, i was under the impression that everyone was already limited to alluminum, because of the talk of the carbon fiber being "accepted". So is it more accurate to say that before mast was limmited only by leagnth, and this new rule limits the material as well? Sorry for being mostly ignorant, but sometimes I really have trouble getting past the price tags. To me $1400 is ALOT. But of course I have no sponsors, and by myself i probably never will.
[Re: BRoberts]
#34748 09/01/04 10:08 AM 09/01/04 10:08 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | Interesting thread, but I think we`re missing the point here with respect to the reason for the change. From what I`ve read here, the main reason seems to be to control costs at the cutting edge of the sport, where only 1% of the competitors play, and are paid to do so. The carbon mast will prevent competitors such as the British Olympic team from HAVING to have a "mast program" and spending millions on developing their boat. Rest assured they will find another direction to spend that funding, since they have it. It won`t make sailing a T more expensive for the weekend warrior - the ally masts will remain class legal for a time at least, and there will still be sailors who are self-funded and sail with the old rig. Those who want to sail a Worlds will spend the money, since it`s a fraction of the real cost of sailing the boat. What happened to the Tornado by becoming an Olympic class was that the cost of campaigning a boat rose substantially, as happens in all classes. The cost of a Laser has gone up disproportionately with the increase in technology required to build one - they should be the cheapest boat money can buy. It is, after all, only Tupperware with a dacron sheet for a sail on a round tubular alu. mast. You could not design a cheaper boat if you tried, yet they are damn expensive for what you get. This is what Olympic status creates - the perception that the boat is worth more than it is. The sad thing is that the market tends to support this ridiculous notion.
Back to the T - it has long since been a boat that the average cat-sailor can buy & compete with on equal terms to the top sailors. The Tornado Worlds were in South Africa a few years ago, and we have 10 or 12 Marstrom Tornados here, most with the new rig & spinnaker, yet South Africa is no longer listed as one of the Tornado class member countries. Why ? Because the cost of competing at that level has made it impossible for these sailors to continue without sponsorship, and sailing does not appeal to sponsors in this country since their return on investment is very low with respect to tv coverage etc. It is not worth these sailors effort to even be members of the class anymore. What this means is that only those with Olympic ideals will continue to campaign the boat, and the boat will no longer be marketed towards, or sailed by, the regular weekend sailor. The cost saving made at one level of the sport will become a cost increase at the base level, but that won`t concern the class association or the builders - the top level players will buy a new boat every 2 years at least.
If the Olympic selection committee ever choose another cat for the event other than the T, the class will disappear in a vapour trail, with only emty check-books as evidence it ever existed. Pity, as its a magic machine.
Steve | | | Re: Lighter mast makes the Tornado safer!
[Re: BRoberts]
#34749 09/01/04 11:45 AM 09/01/04 11:45 AM |
>>>Carbon fiber is ten times as stiff as aluminum.
This is simply not true !
Check again Bill.
Stiffness to weight may be 10 time more but stiffness in absolute sense is actually comparable.
[Re: Steve_Kwiksilver]
#34752 09/02/04 04:20 AM 09/02/04 04:20 AM |
Posts: 4,451 West coast of Norway | Steve: I agree with you on many points. I dont think the class would vaporize if it lost olympic status tough. Ref: British Tornado class Besides, the Tornado has 'always' been an olympic class. That is not new, but the cost of an campaign has rocketed.. What do you think the ITA should do to attract new sailors (while keeping old ones) to the class ? I'm not thinking about olympic campaigns, but regular sailors. The ITA has to act soon, becouse the olympic charter says that only boats with an widespread use are candidates. Today Germany and UK have quite strong classes, but even the germans had to cancel this years national championship due to lack of interest (20 boats wanted to sail, but the rules demands 25).. Constructive comments ?? | | | In kiting
[Re: sail7seas]
#34753 09/02/04 04:32 AM 09/02/04 04:32 AM |
Posts: 9,582 North-West Europe | In kiting we used the following numbers for carbon tube. Afterall these tubes are not 100 % fibre but a composite of abou 65-75 % fibre and 35-25 % of low modulus resin. Aluminium can of course be used in a pure form of one single material (alloy additions don't really change this) .
Carbon 80 - 125 GPa Glass 35 - 48 GPa Alu (alloys) about 70 GPa (never used twose by the way)
From these numbers the two are quite comparable.
Weight of Carbon = 1470 - 1600 kg per cubic meter Alu = about 2350 - 2700 kg per cubic meter.
This data came from EXEL a big producer of carbon tubes for kites and buggy kites.
I think that we both may be correct here. You stated the specs of pure fibre and I refered to the spec of a layup with resin. It is possible that over the years they were succesful in replacing resin with fibres making the fibre resin ratio alot higher and creating higher stiffness of the layups. I don't know. It has been several years since I was active in kiting.
2,782
guests, and 286
