| Re: Finally a carbon mast also on the Olympic Torn
[Re: Rolf_Nilsen]
#34694 07/12/04 06:56 PM 07/12/04 06:56 PM |
Posts: 1,200 Vancouver, BC | Regarding tip weights...my Marstrom Mast (alu) came with a .5 lbs lead weight rivetted to the very top. Surprised me! How can the carbon mast be promoted as "safer" since it's lighter...yes, sure it's safer than a alu stick with even more weight stuck to the top! Wouldn't it just be easier to change the tip weight rule and get the lead off if safety was the concern? I guess the intent of the tip weight rule is to prevent extra light/thin sections which would lead to failures left right and center. There would need to be a change to the tip weight rule for carbon, as there's much less advantage if building to alloy weights. Another thing I found quite intriguing about all this...if accepted Marstrom will be the only allowable builder of carbon masts section for 2 years, to help them re-coup development losses. This seems quite a departure from the "any manufacturer" nature of the the class. Mike. The proposed changes to the class rules on http://www.tornado.org does not say anything about the weight (as far as I could see). So we dont know much about the weight or tip-weight of the new mast. I guess it will be lighter, as easier righting is used as an argument for the change (and the change would be meaningless if weight was maintaned, even tough the mast would become amazingly strong). Bill: You are probably right about the re-cut. Unless the whole front panel of the sail was replaced (most Tornado mainsails has one panel running from the bottom to the top along the luff). The outcome would anyway be uncertain and probably not competitive. If the mast is accepted in the ballot, it will be interresting to measure the performance between the two masts.. Regarding politics, yes this is a quite hotly contended subject. One has to wonder where all the messages on the German T-forum discussing this subject is. They all disappeared last month.. Politics ? Interresting times!
[Re: BRoberts]
#34696 07/12/04 07:22 PM 07/12/04 07:22 PM |
Posts: 1,200 Vancouver, BC | Hi Stranger, It seems strange that the variation in aluminum mast bend from mast to mast is coming into question at this time. The Tornado has been around for a long time and there has been no question about mast bend inconsistency. Even if we start the Tornado history with the Marstrom Tornado, there has been no question about variation in aluminum mast bend until recently. Bill, I think there has always been this inconsistency...see the Marstrom website for a discussion. It's just never been discussed at length because there was no solution to it other than testing many extrusions until you found one that best matched your sailing style/weight range (ie. flex characteristics). Again, this was only ever a concern at the top levels of the class, where minute performance advantages are sought after. Of course at this level, budgets are less of a concern as well. The bend in the top few feet of the mast is very small reguardless of taper because the bending moment is still small due to the short lever arm in the top few feet of the mast. The region of max mast bend occurrs in the region below the hounds and above the diamond spreader. From looking at my alloy mast under spinny loads, a lot of bending is happening above the hounds and in a leeward direction...it looks ugly-scary. This is with the older Marstrom mast (pre-2000). They have reported failures in these older sections and have increased wall thickness of the web on current extrustions. There is also an untapered option offered...but I'm not convinced this increases strength above the hounds...just the flex characteristics and obviously buoyancy after a capsize. If there is variation in aluminum mast bend/flex characteristics, it is likely in the extrusion die wearing out and allowing the mast wall thickness to increase. The solution is a new extrusion die. This is exactly what Marstrom claims as a primary cause of extrusion variation...but that is can happen quite often and leads to basically no two masts being identical in flex performance. As far as my comment about sailors specifying the mast layup, Scooby made the comment that sailors could "design their own masts to suit their needs". And once it's "just right"...they can make that same unit for all boats they buy in the future and the build can offer it to other teams on demand.
[Re: HuntS]
#34698 07/13/04 01:54 AM 07/13/04 01:54 AM |
Posts: 3,528 Looking for a Job, I got credi... | With Tornado and Hunts. The Tornado has been around for a long time and there has been no question about mast bend inconsistency. Even if we start the Tornado history with the Marstrom Tornado, there has been no question about variation in aluminum mast bend until recently. This is simply not true. There have been discussions within the Tornado fleet (and other fleets) for years about this. Back as far as the 80's people were talking about 'fast' masts and mast selection processes.
F16 - GBR 553 - SOLD I also talk sport here | | | Now you got me in disbelieve as well
[Re: Kevin Cook]
#34702 07/13/04 10:21 AM 07/13/04 10:21 AM |
>>I have to respectfully disagree on a couple of points. Static mast weight is not the issue. The carbon stick reduces the radius of gyration by a factor of almost 4 which reduces pitching moment of the hulls.
What exactly do you mean by that ?
"Static" mast weight (Do you have a thing called dynamic mast weight ?) DOES factor in COMPLETELY in Moment of enertia that is linked to oscillation of a platform.
You got me completely lost on your "radius of gyration" statement. Especially on how a reduction of radius REDUCES the pitching MOMENT of the hulls ?
Pitching MOVEMENT of the hulls maybe ?
Or else RESULTING radius of gyration given some reduction in mast weight ? This of course contradicts your statement of "Static weight is not an issue"
I guess there are some typo's in these statements that result in a very awkward statement otherwise you are completely off the chart with respect to dynamic of bodies.
[Re: HuntS]
#34704 07/13/04 11:17 AM 07/13/04 11:17 AM |
No Typos in this post, quick google on defining moment of inertia : Definitions of moment of inertia on the Web: The property of an object associated with its resistance to rotation.It depends on the objects mass and the distribution of mass with respect to the axis of rotation. fuse.pha.jhu.edu/outreach/kit2/glossary.html A physical property of a member which helps define rigidity or stiffness and is expressed in inches raised to the fourth power. It is a measure of the resistance to rotation offered by a section's geometry and size. www.hancockjoist.com/glossary.htmThe rotational analog of mass. The sum of the products of mass and the square of the perpendicular distance to the axis of rotation of each particle in a body rotating about an axis. unistates.com/rmt/explained/glossary/rmtglossarylmn.html The amount of force required to spin an object. www.bowlingfans.com/faq/glossary.shtml– the mass of a rotating object times the square of the distance to the axis of rotation www.mhhe.com/physsci/physical/jones/graphics/jones2001phys_s/common/glos_m.htmA physical property of a member, which helps define strength and deflection characteristics. www.sentinelbuildings.com/glossary.htmthe rotational analogue of mass, in units of mass*length2 (see rotational kinematics) people.ucsc.edu/~erowland/glossary.html Amount of force required to spin an object. www.jayhawkbowling.com/Pro_s_Corner/Glossary/glossary_new.htmlThe moment of inertia of the armature is measured about the torque motor's axis of rotation. The ratio of the motor moment of inertia to the damping factor with a zero-impedance power source gives the mechanical time constant of the motor. In direct drive systems, load inertia and damping factor have to be added to the motor inertia and damping factor to determine the mechanical time constant. www.servomag.com/reference/glossary.htmThe resistance to twisting of any golf club head when that head is impacted off-center. www.wickedsticks.com/glossary2.htmthe tendency of a body to resist angular acceleration www.cogsci.princeton.edu/cgi-bin/webwn
F16 - GBR 553 - SOLD I also talk sport here | | | Let me see if I understand it now ...
[Re: Kevin Cook]
#34706 07/13/04 05:02 PM 07/13/04 05:02 PM |
Posts: 9,582 North-West Europe | And I'm in a reall antagonistic mood so please pardon my excessive use of sarcasm.
Let me see if I understand it now :
>>What I mean is that redius of gyration is the conventional name for resistance of a mass from rotating.
Actually the radius of gyration is nothing more that the "radius of gyration" it takes a little bit more to express the resistance of a spinning mass to CHANGES IN ANGULAR SPEED. Or in other words, There is no "resistance to rotating": unless you are trying to discuss the principle behind gyroscopes but that is a whole different matter.
More comments later.
>>If you take a long slender object such as a mast and reduce the weight by half it should cut this property by about 4 (or is it 8??).
It is neither. Right answer is "cut in halve". You are talking about the Moment of Enertia here which is defined as the sum or integral of the product :
lever^2 * mass (techies call this a second order moment because of the squared lever)
With a mast you must use the integral expression but this one behaves the same as the some of a given number of finite elements with a finite mass. In short the lever (or radius of gyration for that particular element or part) is squared while the mass is not. Therefor if you reduce the mass by a factor of 2 then the moment of enertia (the true expression for resisting changes in angular speed) is also reduced by 2. Reducing the lever is more efficient of course as that is a squared relationship, but that would leave you with a short mast. (And they say that reducing the mast height in the F16 class was a bad idea)
Anyways:
Somebody else claimed that a carbon mast would not be much better as their was the tip weight rule. Meaning, any mass lost must be put back on the top (in part) to arrive back at the correct tip weight.
This is a HUGE consideration as the tip weight is determined using the gravity force (1st order moment) while the performance improvements are linked to the moment of enertia (2nd order moment).
For techies under us. The mast tip weight test is a process that is dependent on the first order moment (lever * mass) while the performance is dependent on the second order moment (lever^2 * mass)
This results in the situation where the extra piece of lead used to correct tipweight results in a inferiour mast when compared to a mast that has perfectly spread out all the mass over its full length while still just satisfying the tip weight rule.
This is one of the reasons why I never understood the fact that people tried to make masts as light as possible only to have a piece of lead in the top to compensate for being underweight.
The problem is in the Lever being squared in moment of enertia.
Simple example and I will not bore you with the integral calculus:
mast - 10 mtr long weight 10 kg (no fittings etc) Assume all mass evenly distributed (no taper etc) mast tip weight when layed horizontal = 5 kg
Moment of enertia = 300 kgM^2
New mast ! mast - 10 mtr long weight 5 kg (no fittings etc) Assume all mass evenly distributed (no taper etc) mast tip weight when layed horizontal = 2.5 kg To compensate for tip weight rule (as present in Tornado rules) additional 2.5 kg needed at top (= 1/2 of weigth savings)
Moment of enertia = 150 kgM^2 + that of corrector weight = 150 + 2.5*10^2 = 150 + 250 = 400 kgM^2
Making the second mast absolutely worse in performance. This new mast with corrector weight in the top compares with regard to Moment of Enertia to a mast that is overall 13,33 kg (= 77% heavier) but evenly distributed.
Tipweigths are dumb. One reason why F16 class is advicing against using them although it uses a minimum tipweight rule. It is adviced to use the excess weight in making extra loops around the mast when using carbon, making the mast more robust as well. The F16 tipweight is below what is feasable in alu so this rule will never have a problem there. Pardon me for the shameless promo for the F16 class, I just couldn't resist. However it is also an example of how the tornado class could modify their tipweight rule to keep carbon masts under control and secure the continued use of alu masts for some time.
>>An aluminum T mast weighs 38 lbs and a carbon version can weigh 21 lbs.
Well, we did some investigating on 8.5 mtr carbon F16 masts and the quotes gave about 9.35 kg for the blank = 20.6 lbs. I think your 21 lbs for the much taller and the more heavily loaded Tornado mast is a bit optimistic.
Lets continue with an estimate of 25 lbs. Ratio between new vs old = 25 / 38 = 66 % => mom enertia ratio new / old = 66 % as well when only taken on the mast and no corrector weights. Than we need to add sails 7kg's and fittings 1.5 kg halyards etc. A quick calculation ends up with a ratio of new/old = 0.85 = 85 % A long shot from the initial statement concerning the magnitude of improvements as made by you. The reduction is more like 1/6 th
>>>The overall radius if gytation of the entire boat is the summation of it's various parts.
No, that would be the summed moment of enertia.
>>These can be combined by superposition just like the linear motion analogy (moments of inertia).
Actually the lineair analogy is "Enertia" (often just called "mass") while the rotational variant is "moment of enertia" or even angular enertia in less correct fashion. You can also replace "superposition" by "adding" or "summing". Superposition is not entirely wrong in the strickt sense but suggest something more complex than is really adressed. Besides superposition is far more used in relation to waves and more complex vector calculus although even in these cases it amount to not much more then "adding"
>>So a carbon mast may help the boat overall by say 8% (a wild guess).
In what sense ? A ratio without reference framework is useless. 8 % more speed ? No way ! 8 % less moment or enertia overall ? Not likely especially not with 150 kg of crew hanging of the wires some 1.5 mtr behind the fulcrum of the rotation. In addition to that a rearbeam of 6 kg at 2 mtr and some rudder setup of 3 kg at 2.5 mtr. It is probabaly more like 4 %. 8 % less amplitude in oscillation ? That could be the case but that doesn't say much to most sailors not educated in these matters.
>>The boat radius of gyration is directly related to the amount of energy it takes to move a boat through waves (reduces pitching moment and rolling moment).
Some claim that reducing pitching inproofs performance by improving the flow over the sails that are otherwise more disrubted by constant (sometiem violent) changes in 3D. I'm not even sure that the reduction in mast related moment of enertia are even significant in the amount of energy needed to propel the boat through the water. But I guess I'm more an acceptive of the improved flow over the sails explanantion. Jury is still out on this one.
>>Does it make sense now?
Yes, thank you for explaining all this to me.
Of course I wasn't really asking for that in my last e-mail as I was asking about the proces that lead to some weird statements concerning the dynamics of finite bodies under the assumption of classical physics. But I think I understand that as well now.
Thank you,
| | | Ehh Simon ?
[Re: scooby_simon]
#34707 07/13/04 05:25 PM 07/13/04 05:25 PM |
Posts: 9,582 North-West Europe | I think you missed the fact that I asked Kevin to explain his use of the words "Radius of Gyration".
I, of course, suggested that what he was trying to describe is actually the Moment of Enertia.
I'm personally totally unfamiliar with the "radius of gyration" definition. This could be me but then again dynamics of bodies is something that I've been tested on many years when at the university and often in the English language as a well.
Even if the "adius of gyration" exists as a definition than Kevins use of it is awkward. The second point conveyed in my post. Mostly because "pitching moment" is a force on a lever while Moment of enertia (Radius of gyration ?) is not.
And a few other things.
| | | Re: Ehh Simon ?
[Re: Wouter]
#34708 07/14/04 06:36 AM 07/14/04 06:36 AM |
Posts: 4,451 West coast of Norway | I think I got the gist of the 'gyration' theori in the first post, so I will not comment on the quite heated discussion about the proper physical non-layman terms that has bloomed in the last couple of posts. Mark: Regarding the "Society of Ordinary Tornado Sailors", where do I join It is a shame if public perception and politic scares people off the T.. Now, if I have understood the last part of the discussion right. Going for a strict one-design carbon mast, as is proposed in the ballot, will in fact take away the possibility of the olympic campaigneers to find a mast section suitable for their sailing weight and style ? (Warning: I'm playing a bit of devils advocate here) To all the non-Tornado sailors who has given their opinion, please continue to do so! In my opinion, all information is of the good, and different views on an issue only gives a richer base of information to make a decicion on.. | | | Thanks
[Re: BRoberts]
#34711 07/14/04 10:33 AM 07/14/04 10:33 AM |
Bill,
Thanks for confirming that to me.
So in basis the Radius of gyration will not change at all when making a mast lighter UNLESS the relative distribution of the mass is changed as well.
Yep, got that
| | | Re: Thanks
[Re: Wouter]
#34712 07/14/04 01:17 PM 07/14/04 01:17 PM |
Posts: 1,307 Asuncion, Paraguay | ...the Radius of gyration will not change at all when making a mast lighter UNLESS the relative distribution of the mass is changed as well. Wouter, Exactly. Note that the radius of gyration can be reduced simply adding weight to the mast foot, but this doesn't improve performance. Add more weight and the radius gets smaller and the boat slower. Something like this could happen if the new rules maintained the minimum mast weight unchanged but eliminated the mast tip minimum weight. I wouldn't expect them to do that (I hope so) because it would be weird to use new carbon masts with lead weights in the mast foot... The gyration radius would be small, but reducing the minimum mast weight and tip weight obviously make a lot more sense. Regards,
Luiz
| | | Gabler letter and Grandfield response
[Re: Luiz]
#34713 07/14/04 02:44 PM 07/14/04 02:44 PM |
Posts: 3,116 Annapolis, MD | Mike Grandfield's letter to the US Fleet followed by Roland Gabler's point of view.
Dear All,
Although I have great respect for Roland, I believe that he has NOT given you good advice regarding the carbon mast ballot proposal.
Here are the reasons why:
1). THE PROBLEMS OF THE FINN SAILORS HAVE NOTHING TO DO WITH THE CARBON MAST PROPOSAL IN FRONT OF TORNADO SAILORS.
- The Tornado ballot proposal includes both pricing and price guarantees. The guaranteed price is 40-50% more than the current Marstrom aluminium mast.
- The Finn mast is not a strict one-design mast. It is customized for each sailor.
- The Tornado carbon mast is a strict one-design, with very precise tolerances; and the design will be transferred to ISAF to protect the class and ensure that other builders can be licensed.
- The problems of Finn mast breakage are not relevant; the proposed Tornado carbon mast was designed for strength and durability, and Marstrom has built over 3000 carbon masts.
2). The aluminium masts have never been equal for all TORNADO sailors; and by next year no one WILL believe that they are TRULY one-design.
- There are 5 flexibility groupings of the current Marstrom masts. Only a few top sailors find really good masts, most of the fleet gets average masts.
- Most current Marstrom masts bend differently to port than to starboard. How many sailors have noticed that they point better on one tack than the other?
- Today, there are commercially available aluminium masts from Marstrom. Hobie, Nacra, and soon from Swiss Carbon; and there is a privately developed mast that was designed the UK with funds from the RYA - this mast has been used at Hyeres and SPA, but it is not commercially available.
- There are at least 2 additional mast designs that could be built if we stay with aluminium.
- So, we will have between 5-7 different aluminium masts. Each one has a different die and different cross-section; BUT each of these measures in as a LEGAL Tornado mast.
- Is that ONE DESIGN? NO!
- If any of the new designs are better than the current Marstrom aluminium mast, then EVERYONE will have to buy a new mast.
- If the RYA mast is the best, but not commercially available, then EVERYONE will complain that it isn’t fair and could easily spend a year or more trying to develop a mast that is competitive.
- If we keep the aluminium mast, we could easily become LESS one-design than ever before.
- There is no price protection with aluminium. A higher performance mast could easily be as expensive as a carbon mast.
- ONLY FULLY FUNDED TEAMS WILL BE ABLE TO AFFORD THE COST OF TESTING NEW ALUMINIUM MASTS AND THE SAILS THAT MATCH THEM.
3). THE REASONS TO CONSIDER THE CARBON MAST ARE NOT “LIGHTER WEIGHT” or “HIGHER PERFORMANCE”
- The Marstrom aluminium mast is not strong enough; Marstrom is selling over 3 times as many masts as new boats! The fleet has spent over ½ MILLION EUROS (Before VAT!) on spare and replacement aluminium masts since the new rig was introduced.
- The Marstrom aluminium Masts are not equal in performance; by next year there will be at least 5 different aluminium masts to choose from.
- The reasons to choose between aluminium and carbon are:
o Strength
o Safety
o Equal Performance
o No advantage to teams with bigger budgets
4). I DON’T WANT TO SPEND MONEY ON A NEW MAST; I STILL HAVEN’T BROKEN THE ONE I BOUGHT IN 1998.
- But, by next year there will be a better carbon mast or a better aluminium mast.
- In 2005, we will all have to consider buying a new mast to remain competitive.
- I believe that the carbon mast ballot item is a very good proposal and the best way to provide a level playing field.
- I’d be excited to sail with a new carbon mast; but I’d be frustrated and angry to have to buy a new aluminium mast instead.
For many years the Tornado fleet has been protected because all of the boats and masts came from Marstrom. THAT TIME IS OVER. The real choice is a one-design carbon mast or a new “arms race” to build a better aluminium mast. It is unrealistic to think that nothing will change.
Clearly, the RYA has already committed to the new aluminium mast effort. SOME OF YOU WILL PROBABLY RACE WITH IT OR AGAINST IT IN ATHENS.
The carbon mast ballot item is your opportunity to choose the future you want for the class. I hope you choose wisely.
Michael
-----Original Message----- From: Roland Gäbler [mailto:roland.gaebler@sport.tdcadsl.dk] Sent: Wednesday, July 14, 2004 7:50 AM To: [email]yann.guichard@wanadoo.fr;[/email] Hugh Styles; Hugo Rocha; [email]iorpas@yahoo.gr;[/email] Jim Young; John Forbes; John Lovell USA 808; [email]Jpolgar@aol.com;[/email] Jürgen Jentsch; Kristof Koch; [email]mail@sailcenter.se;[/email] Marström AB; [email]mgrandfield@sailingwind.com;[/email] Mitch Booth; Niko Mittelmeier; [email]obackes@aol.com;[/email] Nuno Barreto; [email]p.wetzig@gmx.de;[/email] P. Egger; Patricia Kirschner Ross; Patricia Tornado; Patrick Egger; Philip Wetzig; [email]pres@tornado.org;[/email] Ralph Mittelmeier; [email]ramirami@t-online.de;[/email] Sail Center Per Wearn; Sebastian Moser; [email]sec@tornado.org;[/email] slange; [email]tornado@topica.com;[/email] Wolfgang Heinemann; Will, Fabian; [email]will.howden@virgin.net;[/email] [email]xavier-revil@wanadoo.fr;[/email] Aaron McIntosh; Aaron McIntosh; Guenter Moertl; [email]GunnarStruckmann@aol.com;[/email] [email]funinthesun@juno.com;[/email] Ullman Sails - GZ S.r.l. Cc: Jürgen Tiemann; Darren Bundock; BSG Sports Subject: Carbon Mast Importance: High
Dear Tornado Friends,
just some days ago I had some nice talking with some Finn Sailors in Athen about their change to the carbon mast some years ago.
- 4-6 times more expensive (and the mastbuilders said before it will cost just the half more) ha, ha, ha, ha.....
- A carbon Finn Mast cost 2.800-3.500.- euros now !!!! ask your national finnsailor
- A Aluminuim Mast was 700-800.- euros !!!!
How much we must pay to make our boat 8 KG ligther? My Finn Friend sayed, he can finance a new house with all the money he spend in carbon masts last years. Hy guys, wake up................
Security. Safe Sailing? We are the Formula one of sailing. Who wants to go save with this boat. Just not go out when it blows 30knots plus offshore.
Do you think if you open to much the sheet under spinnacker what the carbon mast will not brake? The Finnclass broke more mast than ever in the last years!
Each Finnsailor has 3-6 Mast plus 3-6 light cloth sails. Also forget the cubenfibre sails, they are shrinking.
Instead of getting more milliseconds of speed, we should not forget the think about the youth. How they should finance the new masts? Plus Spinnackers, Plus Cuben Fibre Sails?????????
Do you think only Sail Center of Sweden will make the mast? Many others will come.
I can easy make each mast different. What a nice and expensive mixture???
One Question: How much money you spend in Spinnacker last 3 years? Worth one Car? Ok, we have max fun with our spinnacker. Yes, yes, yes we enjoy........But do we get some much fun-factor with the carbon mast?
Lets concentrate to get back on our One-Design and Olympic Idea.
If you want go faster, buy the M20
I donnot want to talk about the carbon mast. I just wrote my way. Please do not answer this mail. Just answer the ballot and SAIL FOR FUN
See you in Athen. Cheers,
Rolando
crac.sailregattas.com
1 registered members (Seanziepop),
581
guests, and 110
