Hobie 20 bulkhead repair #35286
07/10/04 03:19 AM
07/10/04 03:19 AM
Kaneohe Bay
Dray Offline OP
Dray  Offline OP
Kaneohe Bay
Way back HCC paid a local to repair my hull and the hole (6"Dia.)that was cut on the outer side of the hull is opening up.
any suggestions? Should I contact the factory again ten years later or should I try to repair it myself? NOTE: the gelcoat is just as thin as the outer skin of the hull.
NACRA Dealer
NACRA Infusion "sailing"
Hobie Tiger "sold"
Hobie 20 "sold"
Re: Hobie 20 bulkhead repair [Re: Dray] #35287
07/10/04 10:27 AM
07/10/04 10:27 AM
California
mmiller Offline
mmiller  Offline
California
Find the local guy again... The factory (I) will just refer you to someone in your area for the repair.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Hobie 20 bulkhead repair [Re: mmiller] #35288
07/13/04 03:41 AM
07/13/04 03:41 AM
Kaneohe Bay
Dray Offline OP
Dray  Offline OP
Kaneohe Bay
Thanks for responding Matt,
I'm a pretty good F'glasser myself and think I'll tackle this one. I've got one (or two) question for you. Would you suggest cutting a 2x4 hole near the deck on the inner side of the hull and reinforcing the inner skin of the original repair? I'm not sure if the inner skin is OK.
Or, do you think I should do some exploritory work on the outer skin of the original repair? i.e. use dremel to gentlly remove gelcoat.
I think scarfing of the outer skin is the key for the repair, what do you think about unidirectional carbonfiber running fore and aft. or should I use cloth & mat
Aloha, Dan
NACRA Dealer
Hobie Tiger "sold"
Hobie 20 "sold"
0 registered members (), 434 guests, and 43 spiders.
