catamaran specifications #36402
08/05/04 11:27 AM
08/05/04 11:27 AM
edelvice Offline OP
edelvice  Offline OP
I have been reading these forums for quite awhile but this is my first post. Took me awhile to get this far, discovered that I could not access posting to the forum with Netscape but only Internet Explorer -- go figure. My question is does anyone know where to find a general listing of catamaran specs. I found http://old.cruisingworld.com/ssbk/ssbolndx.htm which is good as far as it goes but doesn't give mast heights and other good stuff. I noticed in another post about a Nacra 450 purchase that someone quoted a Texel page and misquoted there the luff length as being the mast height. I would like better info than that if I could find a place to look it up.
It has been quite informative reading the forum and I am happy to join in.
Edel 15 Nacra 5.2 Ho-Ho-Kus NJ
Re: catamaran specifications [Re: edelvice] #36403
08/05/04 11:46 AM
08/05/04 11:46 AM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I am not sure if all the info can be found in one place. You could get the Multihull Table from the US Sailing site and then begin to visit each manufacturers website. Then you could assemble the information..... and then create a website...and then all the information would be in one place. Or, we could all start posting the pertinent info for each boat....
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: catamaran specifications [Re: arbo06] #36404
08/05/04 12:09 PM
08/05/04 12:09 PM
Sweden, Gothenburg
patrik Offline
patrik  Offline
Sweden, Gothenburg
There is a page, with quite a lot. (not BOA) for a lot fo beachcats.
www.schrs.com
And another with BOA.
http://www.multihullsmag.com/boats/boatlists/cats_up_to_20_feet.htm
BR
Patrik
Re: catamaran specifications [Re: edelvice] #36405
08/05/04 02:20 PM
08/05/04 02:20 PM
maui
jollyrodgers Offline
maui
hello,
A data base from a pool of the forum members would be interesting. i'll contribute.
i use mozilla which is the basis of nescape to view this forum. perhaps you version of netscape is outdated.
Re: catamaran specifications [Re: edelvice] #36406
08/06/04 06:34 AM
08/06/04 06:34 AM
arbo06 Offline
arbo06  Offline
I'll go first, my old boat first, and then the possible future boats.
Hobie 20 Miracle
Specifications:
Length: 19' 6"
Beam: 8' 6"
Mast Length: 31'
Sail Area: 250 Sq. Ft.
Weight: 420 lbs.
Hull Construction: Fiberglass/Foam Sandwich
ARC 21
LOA: 21' 6" (6.55 m)
LWL: 21 ' 3" (6.48 m)
Spar: 33' 0" (10.06 m)
Beam: 8 ' 6" (2.59 m)
Draft, Rudders only: 2 ' 5" (0.74 m)
Draft, Board down: 4 ' 3" (1.30 m)
Minimum Weight: 400 lbs. (181.44 kg)
Maximum Sail Area: 282 sq. ft. (26.20 m2)
ARC 22
LOA: 22 ' 0" (6.71 m)
LWL: 21 ' 9" (6.63 m)
Minimum Weight: 415 lbs. (188.24 kg)
Spar: 38' 6" (11.73 m)
Maximum Sail Area: 360 sq. ft. (33.45 m2)
Beam: 12 ' 0" (3.66 m)
Draft, Rudders only: 2 ' 0" (0.61 m)
Draft, Board down: 4 ' 0" (1.22 m)
Nacra F-18
LOA: 18' 0"
Width: 8' 6" (2.59m)
Mast Length: 29' 6" (7.52m)
Weight: 385 lbs.
Formula 18 Class Rule: 397 lbs. (180kg)
Mainsail with Mast: 183 sq. ft. (17.0 m2)
Jib: (large) 4.15 m2
(small) 3.45 m2
Spinnaker: (large) 21 m2
(small) 19 m2
Construction: vinylester foam sandwich hulls
Design: Nacra Design Team & Alain Comeyn
ISAF Recognized Class
Eric Arbogast
ARC 2101
Miami Yacht Club
0 registered members (), 2,528 guests, and 606 spiders.
