| What's the word on the Eagle 18 and 20 carbon? #36433 08/06/04 02:54 PM 08/06/04 02:54 PM |
Posts: 18 | I saw on another site that said these boats were really fast (Eagle 18 and 20 carbon). Just curious because I haven't heard any mention of them over here. If you want to take a look at their web site, Eagle Sail Boats. I am going to be out sailing on SF Bay on Sat. Let me know if any of you are going to be out there.
Hobie 18
| | | Re: What's the word on the Eagle 18 and 20 carbon?
[Re: the_skier]
#36434 08/06/04 11:20 PM 08/06/04 11:20 PM |
Posts: 12,310 South Carolina | Have you heard about the price for those suckers!? This is muli-handed information but I hear the Eagle is around $32,000 to $36,000.
Jake Kohl | | | Re: What's the word on the Eagle 18 and 20 carbon?
[Re: arbo06]
#36436 08/08/04 03:56 AM 08/08/04 03:56 AM |
Posts: 3 | Hello catamaran friends, In small switzerland sails many teams with 18ht and 20ht catamarans. also with eagles 18ht and eagles 20 and naturally bimare javelin and ventilo from switzerland. both eagles 18ht and 20ht are full carbon with a carbon mast of marstrom. the eagles 20C was fastest from all in the "Texel Race 2004" costs the eagle 18ht approx. 23,000.dollar "ready to race" the eagle 20C approx.. 31,000. dollar "ready to race" sail fast and light Greeting steve www.volvento.ch | | | Re: What's the word on the Eagle 18 and 20 carbon?
[Re: Volvento2]
#36437 08/11/04 12:36 AM 08/11/04 12:36 AM |
Posts: 18 | Dam for that price that boat better be really really really fast.
Just curious for comparison what is the cost for a marstrom 20?
Hobie 18
[Re: the_skier]
#36441 08/12/04 04:48 AM 08/12/04 04:48 AM |
Joined: Sep 2001 Posts: 254 Gower, Wales, UK sailwave
Posts: 254 Gower, Wales, UK | Just curious for comparison what is the cost for a marstrom 20? 25500 EURO (~$31000) I asked while enquiring about the price of their A-Classe, which is expensive at 18334 EURO without a sail! | | | Re: What's the word on the Eagle 18 and 20 carbon?
[Re: Seeker]
#36443 08/12/04 12:48 PM 08/12/04 12:48 PM |
Posts: 1,911 South Florida & the Keys | Correct! It also depends on the intended use, mentality of the user and financial ability, it is all relative. That is a little pricey for me but I would be willing to spend $10,000 less on a new ARC 21 or 22.
Eric Arbogast ARC 2101 Miami Yacht Club | | | Just to give my perspective
[Re: macca]
#36446 08/13/04 03:28 AM 08/13/04 03:28 AM |
Posts: 9,582 North-West Europe | I would like to mention that making a boat significantly lighter while keeping it at 20 foot is not an optimal thing to do. Reducing its hull length makes it noticeable faster again.
To give rough mathematical an example
180 kg + 150 kg crew on 20 foot => drag ratio wetted surface = 100 % 130 kg + 150 kg crew on 20 foot => drag ratio wetted surface = 92 %
compare to
130 kg + 150 kg on 18 foot => drag ratio wetted surface = 87 %
For this reason I never understood why Marstrom and even Eagle remained at the 20 foot hull length. Some extra 5 % on top of the original 8 % reduction can be had by making the hulls shorter. Dive stability is not that much of a problem as the reduction in drag causes the sailforce to reduce as well and in in this example a 19 foot hull on the lighter boat will still have exactly the same dive resistance as the heavier 20 foot hulls when running the numbers on the complete boat while sailing.
Wave making drag then ? Look at prismatic ratio's
180 kg + 150 kg crew on 20 foot => Rough Prismatic ratio = 100 % 130 kg + 150 kg crew on 20 foot => Rough Prismatic ratio = 85 %
compare to
130 kg + 150 kg on 18 foot => Rough Prismatic ratio = 94 %
See the shorter 18 foot hull of the lighter boat also has a lower wave making drag coefficient then a 20 foot hulled boat of the original weight. This is an example of how looking only at waterlength can be very misleading.
By now it is well understood that wetted surface drag is a larger portion of the overall drag than wave making drag while the later is still significant enough to not be neglected. So If one has to choose between a lower prismatic ratio of a lower wetted suface ratio one is wisest to choose the lowest wetted surface ratio.
In short at 130 kg boat is best build at 18 foot length (within the limits of this example) instead of at 20 foot. The difference in speed CAN WELL BE significant. Another 5% can easily be gained this way.
So unless some designer comes out with such a platform and doesn't f*ck up the rig at the same time I think we will see the lightweight boats being (very) limited in their gains. Simply because their designers don't take the time to do the basic math and ratio research.
| | | Re: Just to give my perspective
[Re: Wouter]
#36447 08/14/04 01:54 AM 08/14/04 01:54 AM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | For this reason I never understood why Marstrom and even Eagle remained at the 20 foot hull length...... [color:"red"] Dive stability is not that much of a problem [/color] as the reduction in drag causes the sailforce to reduce as well and in in this example a 19 foot hull on the lighter boat will still have exactly the same dive resistance as the heavier 20 foot hulls when running the numbers on the complete boat while sailing.
Ok, I gotta call BS on the stability bit.... I've sailed F18 and I-20 and the stability comparison.... ha ha ha!!! There is none! That two feet (10%) means a lot in survivability. I think that there is a reason the fastest boats out there are bigger and the designers are fully aware of the reasons. Just on a quick view, 20' boats were the first 4 finishers in the 2004 Texel. Also consider that 7 of the top 10 boats in round texel were 20'. One thing you can't argue with is results. I don't see that any 18' boats have any Worrell/Tybee records. There has got to be something to it..... Hmmmmmmmmmmmmm........ Design numbers mean one thing, but on the water performance is another. IMHO | | | Re: Just to give my perspective
[Re: Will_R]
#36448 08/14/04 02:24 AM 08/14/04 02:24 AM |
Please read my post again Will,
-1- speed and dive stability is two different things
-2- greater dive stability is indeed linked to greater length and so to are larger wetted surface and lower speeds THEN COULD be achieved with a shorter hull WHEN the platform is made a lot lighter.
We are talking in relative terms here not absolute terms. The name of the game is "It could be even better IF...."
| | | Well, ...
[Re: BRoberts]
#36450 08/14/04 06:30 PM 08/14/04 06:30 PM |
Well, guys believe what you want to believe. Ignore the pointers and dig into to the commercial talk.
I sailed my own boat, the kind that "just can't sail right", a few more times and I can assure you that I will NEVER EVER buy an "normal" boat again.
You guys just don't know what you're missing. AHPC rig ? Excellent, the bloody rig talks to you. Am I going crazy ? If so than I want to be completely insane by tomorrow morning. And I'm not the only one ; some at my club are actively looking to ditch their old normals boats like a 1 year old Blast to get "one of these". One comment of late, and this guy wouldn;t shut up after the test ride. "I thought the Taipan would be a twitchy and unstable boat, It REALLY isn't. She felt more stable than all the other boats I had and it sped along so enormously". Dive problems ? Not here. I did a bit of the F18 and I can tell you that Your Tiger has more problems there and that the Nacra I-18 takes more chop on the beam. The Nacra 5.5 goes done like a submaring when coming down swell or chop. The T goes in like a good suspension and pops right out ready for the next wave. I put it done to the lightweight mast.
Now this T is smaller and shorter than ALL YOUR BOATS and I think it is heaps better. The accelerations are just orgasmic. Out of trim ? Pull in some sheet or control line and she reacts like you hit the G-spot head on.
Guys, you make up your own minds. I can tell you all you need to know about these ratios and whats works and what not, but you are never going to believe me and honestly THAT IS YOUR LOSS.
I'm sailing and pissing of some unconverted sailors in the process.
Have fun guys and buy some more old rig and old technology boats. God knows not much has changed since the 70's right ?
Or did it ?
[Re: macca]
#36451 08/15/04 12:39 AM 08/15/04 12:39 AM |
Posts: 3,116 Annapolis, MD | Hey folks
Notice that the F18HT is the lighter and shorter boat that Wouter proposed. It's PN rating is approaching the I20 and Tornado. 60 versus 59!
The rule does not allow the boat to max out the trailerable beam. It's not 8 for 6 wide... (I think it's 8' 3" in width)
Mark
crac.sailregattas.com
2,530
guests, and 406
