| Re: What's the word on the Eagle 18 and 20 carbon?
[Re: macca]
#36453 08/15/04 09:37 AM 08/15/04 09:37 AM |
Posts: 284 S. Florida | Hello Macca, In the 1980s when SC20TRs were sailed by top caliber sailors, this boat was rated in the PN range of 62 to 60 when the Tornado was 64. This is US Sailing talking, not me. So there has already been a 20ft long production boat built that is faster than the Tornado. My son and I took one of these old boats, an over weight one by 100 pounds, and put some new sails on it and won the 2003 Steeplechase race, 100 miles long, by 25 minutes over the second place boat and that included a turnover and righting on our part. There were Tornados and I20s in the race sailed by the top caliber sailors. At the time I designed the SC20,1976, I had never designed a boat before. I had 20 years sailing experience in monohulls. I had engineering degrees and all I knew were "those ratios". Those ratios worked back them and they still work today. If your effort to put together a boat faster than the Tornado is to succeed, you better check those ratios and see that your system exceeds the Tornado in "those ratios". The M20 is definately tailored to the windward leeward race course and suffers on the close reach. Adding a small jib is very easy task. The Eagle 20 platform and rig may need no development at all. If the boat is designed and built by knowledgable and experienced people, they can hit the nail on the head first shot out of the box. I am willing to assume that this is the case until I hear otherwise. Winning the Texel race against the M20 and Tornado even by 1% says to me that the boat is at least equal to the best 20ft designs right now. I'm sure the Eagle 20 has some excellent "ratios". Bill | | | Hi Bill What's the number now?
[Re: BRoberts]
#36454 08/16/04 08:48 PM 08/16/04 08:48 PM |
Posts: 3,224 Roanoke Island ,N.C. | What's the sc20 tr number now and as it was raced in 2003 Steeplechase? Just wonderin', Todd
| | | No progress since 1970???
[Re: BRoberts]
#36458 08/18/04 05:45 PM 08/18/04 05:45 PM |
Joined: Jul 2001 Posts: 256 North Europe, Sweden, Uppsala Hakan Frojdh
Posts: 256 North Europe, Sweden, Uppsala | If there where no progress since 1970 how come no one uses a Unicorn A-cat to race with? Things change you know....
What kind of speed do we mean? Top speed, upwind/downwind race course or distance racing around islands?
The perfect round texel wind gives you little upwind/downwind sailing which means that the Uni rigged boats suffer. Is that the data we should use when comparing boats? The M18 won Texel once when there where bad texel conditions, only upwind/downwind in light winds. But we all know that the Tornado is faster. But in that Texel it was obvious for all that this was not a normal Texel race and it should not be used for speed comparision.
I don't agree that adding a triangle to the race course would make the M20 to loose against the Tornado. The M20 IS faster than the Tornado upwind and downwind but not when reaching. But will the speed differance in the reaching part of the added triangle be enough for the Tornado to get ahead, I don't think so.
The raced with two M20's in Lac le joux last weekend and both boats where 10 minutes ahead of the rest of the fleet. That included the new Ventilo (Uni), Tornado and some F20,F18 boats. The conditions wasn't heavy reaching, it was lighter winds and upwind/downwind.
/håkan | | |
2,245
guests, and 258
