mast step link pin #36734
08/12/04 09:28 PM
08/12/04 09:28 PM
sandman Offline OP
sandman  Offline OP
Once the mast is up, are there any easy ways to remove
the mast step link pin other than brute force or a hammer?
Hobie 16 [color:"brown"] [/color] [color:"blue"] [/color]
Re: mast step link pin [Re: sandman] #36735
08/12/04 09:45 PM
08/12/04 09:45 PM
catman Offline
catman  Offline
Try lifting up on the mast as you pull the pin out. You might try using a screwdiver under the mast to pry up,lifting the mast. Are you using a mast chip?
Re: mast step link pin [Re: catman] #36736
08/12/04 10:56 PM
08/12/04 10:56 PM
South Florida
SOMA Offline
SOMA  Offline
South Florida
I wiggle the mast back and forth from the mast rotation limiter and it comes right out.
Fred F (ex Hobie 18)
Re: mast step link pin [Re: SOMA] #36737
08/13/04 12:26 AM
08/13/04 12:26 AM
catman Offline
catman  Offline
the 16 is a bit different,
Re: mast step link pin [Re: sandman] #36738
08/13/04 08:40 AM
08/13/04 08:40 AM
Houston
carlbohannon Offline
Houston
It's been a long time but, since I think I have made every mistake possible, I will try to remember some:
1) Mast raked way too far aft or forward, try putting the jib up first.
2) You are putting the pin in the wrong hole. Most links have a H14 and a H16 hole
3) Wrong link. I tried to use a H14 only link once, it didn't work. Plus other cats from the 70's used similiar things
4) Altered mast base or wrong mast base. Compare both sides of your mast base against a H16 known to be right. (an extreme case- we rescued an H16 with a ~28 foot mast off god-only-knows-what. The mast base was apparently put on with bondo)
5)(Most likely) Bent or crushed link
Hope it helps
Re: mast step link pin [Re: carlbohannon] #36739
08/13/04 12:31 PM
08/13/04 12:31 PM
San Francisco
TSurfer Offline
TSurfer  Offline
San Francisco
As Mike mentioned, I also had success removing the pin when lifting the mast straight up before tightening the rig.
Tim S. Urfer 1984 Nacra 5.2
