Tornado and Mystere added to table #3747
11/12/01 05:49 PM
11/12/01 05:49 PM
Ohio
TeamTeets Offline OP
Ohio
http://teamteets.dhs.org/F20/F20%20compare.htm<br><br>Mike Teets
<br>Dublin, Ohio
<br>I20 #246
<br>M4.3 #59
3786- (144 downloads)
Mike, Ohio
Re: Tornado and Mystere added to table [Re: TeamTeets] #3748
11/12/01 08:30 PM
11/12/01 08:30 PM
Ohio
Ohio
Some fun with numbers...
<br>
<br>Look at the sheet again. I added a "percentage of best" column to the length, beam, mast, sail, and weight. The biggest is considered best except in weight. I excluded spinnaker since all do not carry them. I also added an average of those numbers for each boat.
<br>
<br> I am not really sure what it means, but interesting to look at. Presumably, the highest percentage average is "better".<br><br>Mike Teets
<br>Dublin, Ohio
<br>I20 #246
<br>M4.3 #59
3797- (147 downloads)
Mike, Ohio
Thanks Mike, those % do really help [Re: TeamTeets] #3749
11/13/01 04:04 AM
11/13/01 04:04 AM
I would however split up sailarea into jib area and mainsail area, because both sails act differently. Example when a catrigged and sloop designs have equal sailarea's than teh catrigged boat will do slightly better upwind but the sloop will do much better downwind to such a magnitude that it more than compensates for it's loss uwind. Only exception to this is really light air where the possibly higher rig of the catrigged boat is much favored.
<br>
<br>Wouter<br><br>
3802- (137 downloads)
Re: Thanks Mike, those % do really help [Re: Wouter] #3750
11/13/01 07:15 AM
11/13/01 07:15 AM
Ohio
Ohio
I agree but I don't have all of the jib/main sizes so I cannot do it against all boats.
<br>
<br>Also, would like to get accurate numbers on EU vs.NA on 6.0 and I20. Is the Fox the same?<br><br>Mike Teets
<br>Dublin, Ohio
<br>I20 #246
<br>M4.3 #59
3804- (143 downloads)
Mike, Ohio
I can give you the EU numbers,I think FOX is same [Re: TeamTeets] #3751
11/13/01 07:27 AM
11/13/01 07:27 AM
<br>
<br>Best is when you look at www.texelrating.knwv.nl
<br>for data on sail sizes.
<br>
<br>Wouter<br><br>
3806- (146 downloads)
Re: Tornado and Mystere added to table [Re: TeamTeets] #3752
11/13/01 09:48 PM
11/13/01 09:48 PM
Toronto
mhb Offline
mhb  Offline
Toronto
Better get the correct numbers first
<br>
<br>The Mystere 6.0 is exactly 8 feet 9 inches BOA and about 19 feet 9 inches LOA when measured properly. The boat weight is all over the place with the latest boats reported under 400 pounds. So much for one design or fair racing.
<br>
<br>The last time I measured a Tornado mast it was 32 feet with a boat weight of 350 pounds. I think these are some of the B-class rules which the Tornado(old) is.
<br>
<br>The iF20 rules state a max LOA of 6.12m not 6.10m. This is just under 20 feet 1 inch. Since many boats have been built under that rule, it should also stand for NA - F20. Since the Fox and I20 hulls are iF20 class legal, they may also measure nearer to 20 feet 1 inch LOA. Factory specs are not to be trusted for the purpose of comparing makes and models.
<br>
<br>Marc
<br>
<br><br><br>
Re: Tornado and Mystere added to table [Re: mhb] #3753
11/13/01 10:36 PM
11/13/01 10:36 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Mark,
<br>
<br>I couldn't agree more. We need to throw the Manufactures specs in the trash as our first item. I don't know where they measured my H20 but It is no where near their measurement. We need to independently measure all boats and sails.
<br>
<br>Texel info is probably a fair source.
<br>
<br>Mike Hill
<br>H20 #791
<br><br><br>
3832- (140 downloads)
Mike Hill
N20 #1005
Re: Tornado and Mystere added to table [Re: Mike Hill] #3754
11/14/01 08:03 AM
11/14/01 08:03 AM
Ohio
Ohio
I would be glad to keep a manufacture table and a measured table... but unfortunately I don't own one of each boat to measure although I will run that past my wife tonight... wish me luck.<br><br>Mike Teets
<br>Dublin, Ohio
<br>I20 #246
<br>M4.3 #59
3836- (135 downloads)
Mike, Ohio
0 registered members (), 427 guests, and 27 spiders.
