Hobie 16' Jib Line Question #38416
09/25/04 08:23 PM
09/25/04 08:23 PM
N
NoBeginner Offline OP
N
Evening Folks:
Just got my mast up with my new self-furling jib setup. Problem is, now my (32' stock) jib lines seem way too small. Anybody out there know what the proper length of jib lines for the self-furler is (bear in mind that I need the jib lines long enough to change them while well aft 'On The Wire').
Any assistance would be appreciated.
Re: Hobie 16' Jib Line Question [Re: NoBeginner] #38417
09/27/04 07:37 PM
09/27/04 07:37 PM
Western New York
wyatt Offline
wyatt  Offline
Western New York
Hey Paul:
I wouldn't worry about it. Normally sailors that put on the furlers do so because they want to make everything easier; you won't find it necessary to trim the jib while you're on the wire. You can't race a Hobie 16 because the furling system is not legal, and you no longer have a legal jib. Even when we were racing the 16, we adjusted the jib very little; once you have the correct slot opening (via traveler and jib sheet), you just sort of kept it there. In high winds, the traveler will get you out of trouble, and the mainsheet will lower the boat in the puffs.
Wyatt
Re: Hobie 16' Jib Line Question [Re: NoBeginner] #38418
09/30/04 08:52 AM
09/30/04 08:52 AM
Houston
carlbohannon Offline
Houston
I am assuming the line is too short to be comfortable when trapped at the rear of the boat.
The easiest way is to measure it.
Do this on the beach wind no wind.
Disconnect the side of the jib closest to you. . Let the jib out to a broad reach . Trap out as far aft as you would ever go. Get a comfortable amount of line in your hand and a comfortable amount of slack on the tramp. Mark the end of the "slack" with tape and the location of the end of the slack on the tramp with a beer can, rock, etc.
Pull the line out and measure from the end of the line to the tape. WRITE IT DOWN.
Now rig the other side of the jib line. Hold or tie the jib in a broad reach position just like it was before. Now run the jib line loosely (just like you were sailing) to the beer can on the tramp. mark the line and pull it out. Measure to the mark. WRITE IT DOWN.
Add the two numbers up and you have it.
And old friend of mine, rigs his boat with the cheapest line he can find. One side is rigged properly and the other just has some kind of stopper knot He keeps shortening the line by retying the stopper knot until he can just barely do what he wants. When he gets it just right he pulls it out and measures it
0 registered members (), 322 guests, and 47 spiders.
