| Re: Hobie 18' Missing Hull Floatation Blocks
[Re: Cat_Centric]
#38931 10/11/04 08:46 PM 10/11/04 08:46 PM |
Posts: 12,310 South Carolina | Go to Walmart and buy several of the cheap long 'floating noodle' kids pool toys. Cut them into manageable lengths, insert them into the hull port and VIOLA! Hull floatation made easy...they are made of closed cell foam and perfectly suited for this task.
Jake Kohl | | | Re: Hobie 18' Missing Hull Floatation Blocks
[Re: wyatt]
#38934 10/13/04 06:47 PM 10/13/04 06:47 PM |
Posts: 12,310 South Carolina | But I can atest (please don't ask me how) that a Hobie 18 completely swamped in both hulls and void of air will still stay on the surface of the water....
[Re: mmiller]
#38939 11/10/04 12:23 AM 11/10/04 12:23 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | The blocks are large. Get a stick or something like it and probe through the port toward the aft end. You should find it. If it's not there then someone removed them. How? Certain chemicals will turn foam into liquid and it will pour out the drain holes. Why? To remove weight from the boat.
| | | Re: Why the foam is a really good idea
[Re: hobiesailor]
#38943 11/10/04 01:14 PM 11/10/04 01:14 PM |
Posts: 12,310 South Carolina | You guys might be able to salvage one good boat between ya!
Jake Kohl | | | Re: Why the foam is a really good idea
[Re: arbo06]
#38947 11/10/04 08:53 PM 11/10/04 08:53 PM |
Posts: 1,911 South Florida & the Keys | Oh, and by the way, there was foam flotation all over Biscayne Bay after the "incident" and the boat never sank. I say flotation is critical!
Eric Arbogast ARC 2101 Miami Yacht Club | | | Where do you buy Pour foam? NM
[Re: carlbohannon]
#38948 11/13/04 05:13 AM 11/13/04 05:13 AM |
Posts: 208 | | | |
640
guests, and 432
