Hobie 18' Missing Hull Floatation Blocks #38930
10/11/04 08:33 PM
10/11/04 08:33 PM
Milwaukee, WI
Cat_Centric Offline OP
Milwaukee, WI
Evening Folks:
Have started rebuilding my newest project a 1980 18' with wings.
No sooner than when I took the boat to the car wash to try to start getting some of the almost quarter of a century worth of grit and grime...that I noticed....no foam in either hull.
Now I am pretty sure that Hobie never made an 18' without foam in the hulls (somebody correct me if I am wrong) so I suspect an ealier owner pulled the water logged foam out and never thought any more about it.
Ok gang, how do I put some floation back in? Are there ready made inflatables...or am I going to have to play around with some D.I.Y. foam in a heavy guage plastic bag? Am not comfortable at all thinking about sailing around off shore in Lake Michigan without hulls I know will float...even if holed or worse.
Anybody who has solved this problem...feel free to chime in!
Thanks In Advance,
Poor Paul
Re: Hobie 18' Missing Hull Floatation Blocks [Re: Cat_Centric] #38931
10/11/04 08:46 PM
10/11/04 08:46 PM
Go to Walmart and buy several of the cheap long 'floating noodle' kids pool toys. Cut them into manageable lengths, insert them into the hull port and VIOLA! Hull floatation made easy...they are made of closed cell foam and perfectly suited for this task.
Re: Hobie 18' Missing Hull Floatation Blocks [Re: Cat_Centric] #38932
10/12/04 09:23 AM
10/12/04 09:23 AM
Houston
carlbohannon Offline
Houston
I think we have been through this a few times. Remember you need at least 3 cubic feet (1.5 in each hull) Here are a few options:
1) Easy and expensive 2 floatation bags made for monohulls $80. Call Layline or a Vanguard dealer can help you.
2) Pour Foam - mix 2 liquids and it turns into Styrofoam. Pour through the portholes into a trash bag. You need ~3 ft3 ~$80
3) Styrofoam - cut a sheet into strips that fit through your portholes a 4'x8'x 4" sheet is around ~$20. Look in the phone book and call for best prices
4) Foam noodles - They are on big sale now
5) Super Heavy Duty Beach Toys - They are on big sale now
6) Empty 2l soda bottles
7) Be inventive, go to the discount stores and look in the sale bins. I have heard some good ones over the years. Really cheap life jackets, Foam pool lounge, Giant green foam frog, Puncture proof tractor tire and my all time favorite "The inflatable pool woman". You were supposed to impress your friends by having this strange looking silicone rubber woman floating in your pool. She normally floated face down. I saw 4 of them and a piece of plywood being used as a work raft
Re: Hobie 18' Missing Hull Floatation Blocks [Re: Cat_Centric] #38933
10/13/04 05:01 PM
10/13/04 05:01 PM
Western New York
wyatt Offline
wyatt  Offline
Western New York
Rob:
I gotta tell ya; I don't think there is foam in there! I have a 1990 Hobie 18 magnum and I stuff things in the ports all the time, I've never seen anything like this in the 18s I've dismantled. I do have about four large foam noodles in each hull, though; I originally put them in for floating on when we're in the middle of the lake on a no-wind day with a cold beer in our hands.
Wyatt
Re: Hobie 18' Missing Hull Floatation Blocks [Re: wyatt] #38934
10/13/04 06:47 PM
10/13/04 06:47 PM
But I can atest (please don't ask me how) that a Hobie 18 completely swamped in both hulls and void of air will still stay on the surface of the water....
Re: Hobie 18' Missing Hull Floatation Blocks [Re: Jake] #38935
10/13/04 08:34 PM
10/13/04 08:34 PM
Darryl_Barrett Offline
The Hobie 18's were of a "foam core laminate" in manufacture, which, although it doesn't give a lot of bouancy, it does mean that when the hulls are full of water, they do have minimum positive bouancy
Re: Hobie 18' Missing Hull Floatation Blocks [Re: Jake] #38936
11/06/04 03:23 AM
11/06/04 03:23 AM
johnmellor Offline
johnmellor  Offline
A trick used by some kayakers is to shove a deflated basketball (football?)or two inside a port and inflate.
Re: Hobie 18' Missing Hull Floatation Blocks [Re: Cat_Centric] #38937
11/06/04 11:52 AM
11/06/04 11:52 AM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
How can you tell you're missing the foam? Isn't the foam between the crossbeams, like right in the center of the hulls? Can you see that without cutting a hole in the hull, or are the ports centrally located?
Whatever you replace with, keep in mind that: 1. It should be very light and 2. It should resist water absorption
sea ya
tami
Re: Hobie 18' Missing Hull Floatation Blocks [Re: tami] #38938
11/07/04 11:58 AM
11/07/04 11:58 AM
California
mmiller Offline
mmiller  Offline
California
Possitive floatation blocks of foam are placed inside of all Hobie Cat hulls. Fiberglass ones that is. On the 18, the foam would be behind the dagger wells.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Hobie 18' Missing Hull Floatation Blocks [Re: mmiller] #38939
11/10/04 12:23 AM
11/10/04 12:23 AM
catman Offline
catman  Offline
The blocks are large. Get a stick or something like it and probe through the port toward the aft end. You should find it. If it's not there then someone removed them. How? Certain chemicals will turn foam into liquid and it will pour out the drain holes. Why? To remove weight from the boat.
Why the foam is a really good idea [Re: Cat_Centric] #38940
11/10/04 12:54 AM
11/10/04 12:54 AM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
I am a big believer in building additional flotation into hulls. I was very thankful for the foam blocks in my 18 after an eventful weekend...(see attached photo).
Chris.
Re: Why the foam is a really good idea [Re: flumpmaster] #38941
11/10/04 01:01 AM
11/10/04 01:01 AM
catman Offline
catman  Offline
I'll bet your boat was a mid 80's model
Re: Why the foam is a really good idea [Re: flumpmaster] #38942
11/10/04 12:35 PM
11/10/04 12:35 PM
Lake Lanier, Georgia
hobiesailor Offline
hobiesailor  Offline
Looks like a weekend I once had. [Linked Image]
Re: Why the foam is a really good idea [Re: hobiesailor] #38943
11/10/04 01:14 PM
11/10/04 01:14 PM
You guys might be able to salvage one good boat between ya!
Re: Why the foam is a really good idea [Re: catman] #38944
11/10/04 02:51 PM
11/10/04 02:51 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Indeed....1986
Not the first person that happened too eh? Whenever I repeat my story there is often someone else who suffered a hull failure on a hobie 18 of that vintage.
Re: Why the foam is a really good idea [Re: flumpmaster] #38945
11/10/04 07:37 PM
11/10/04 07:37 PM
California
mmiller Offline
mmiller  Offline
California
No doubt that was a problem in the late 80's. In 1984 Hobie reduced the weight of the 18. To do this they reduced materials including some "patches" of glass that strengthened the crossbar connection points. Before that... the 18 was bullet proof. After a few years, problems started showing up. Didn't help that we also started adding wings in 1984. Took about 4 years to unwind from that and get the boat bullet proof again. That whole mess was thrown in my lap when I started at the factory doing Warranty back then. I got the warranty extended from 5 to 6 years and the prorated coverage increased to a minimum of 60% over the entire 6 years. Under the Coleman warranty program at the time, the coverage went down 20% per year over 5 Years. 100 1st year, 80-60-40 then 20.
Any 18 in that range should watch the area below the forward crossbar and add reinforcements inside the hull and be retrofitted with anchor plates.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Why the foam is a really good idea [Re: hobiesailor] #38946
11/10/04 08:51 PM
11/10/04 08:51 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Thats not a bad weekend, this is.....
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Why the foam is a really good idea [Re: arbo06] #38947
11/10/04 08:53 PM
11/10/04 08:53 PM
arbo06 Offline
arbo06  Offline
Oh, and by the way, there was foam flotation all over Biscayne Bay after the "incident" and the boat never sank. I say flotation is critical!
Eric Arbogast
ARC 2101
Miami Yacht Club
Where do you buy Pour foam? NM [Re: carlbohannon] #38948
11/13/04 05:13 AM
11/13/04 05:13 AM
DHO Offline
DHO  Offline
ewre
Re: Where do you buy Pour foam? NM [Re: DHO] #38949
11/14/04 12:09 AM
11/14/04 12:09 AM
0 registered members (), 652 guests, and 965 spiders.
