Main traveler removal #39400
10/26/04 07:56 AM
10/26/04 07:56 AM
Virginia Beach
Sunvista Offline OP
Sunvista  Offline OP
Virginia Beach
How does one replace the main traveler on old style Hobie 16? Do I need to seperate the aft crossbar from one of its corner castings?
Re: Main traveler removal [Re: Sunvista] #39401
10/26/04 08:19 AM
10/26/04 08:19 AM
Virginia
Drej Offline
Drej  Offline
Virginia
You need to drill out the last 2 or 3 rivets in the track, which will allow you to lift it up enough to remove and replace the traveller car. Be careful only to drill out the head and not enlarge the hole. Then replace with countersunk rivets. The post below gives some hints on what to do to re-rivet the track back successfully.
http://www.catsailor.com/forums/sho...ew=collapsed&sb=5&o=&fpart=1
0 registered members (), 2,670 guests, and 238 spiders.
