| Re: new crossbar
[Re: sailor3001]
#39403 10/26/04 05:15 PM 10/26/04 05:15 PM |
Posts: 833 St. Louis, MO, | Well the big trick is getting those bolts out and back in without twisting them off. I'd highly recommend spraying them down with WD-40 or some good stuff to help them break free. Also pay a lot of attention to the recommended ft. lbs when you go to tighten them. Do not exceed the recommended ft. lbs. Many people have twisted the heads off these bolts and ended up having to redrill and retap the holes. If the bolts come out and go in cleanly you should be homefree.
Good Luck, Mike Hill Tiger #1520
Mike Hill N20 #1005
| | | Re: new crossbar
[Re: Mike Hill]
#39404 10/26/04 05:29 PM 10/26/04 05:29 PM |
Posts: 1,253 Columbia South Carolina, USA | us ethe white lithium grease, I think thats what the manufacturer uses. Some people "seat" thier beam in a bed of caulk or 3M 5200(?) cant remeber exactly what the product is.
Glad to hear you got the beam, See you at the Midlands! David Mosley
| | | Re: new crossbar
[Re: dave mosley]
#39405 10/26/04 05:45 PM 10/26/04 05:45 PM |
Posts: 3,116 Annapolis, MD | You seat the beams in epoxy. Set the boat up bolt it together and make sure its square. Unbolt, Wax the beam... lube the bolt with grease and coat the beam pocket with strait west systems. Tighten it down with the torque wrench and mop up the extra as it squeezes out for the next 1/2 hour.
crac.sailregattas.com
| | | Re: new crossbar
[Re: Mike Hill]
#39408 10/26/04 08:34 PM 10/26/04 08:34 PM |
Posts: 99 Chicago, IL | Mike What do you mean by: “Do not exceed the recommended ft. lbs.”
What would be appropriate number of ft/lbs?
I20
| | | Re: new crossbar
[Re: Mark Schneider]
#39410 10/27/04 12:59 AM 10/27/04 12:59 AM |
Posts: 3,528 Looking for a Job, I got credi... | Had not heard that this was required.
Why would this matter?
Thanks Mark Before un-doing the bolts you need to remove any pre-bend in the front beam. Ideally when sailing, the front beam should be flat - Rig tension / mainsheet tension etc will bend it down.... So your front beam should be bent up - remove this before un-doing the bean bolts or you will cause problems
F16 - GBR 553 - SOLD I also talk sport here | | | Re: new crossbar
[Re: scooby_simon]
#39411 10/27/04 07:09 AM 10/27/04 07:09 AM |
Posts: 12,310 South Carolina | Before un-doing the bolts you need to remove any pre-bend in the front beam. Ideally when sailing, the front beam should be flat - Rig tension / mainsheet tension etc will bend it down....
So your front beam should be bent up - remove this before un-doing the bean bolts or you will cause problems Since that is my old beam, I can attest that there is not much prebend in it*...however, any prebend that exists due to the tightness of the dolphin striker post would be between the tips of the dolphin striker 'arms' and would not affect the outer lengths of cross bar that attach to the hulls - they would still be as straight as the day they were born. I don't see how this might be a problem when attaching it to the hulls. *When I upgraded my 5.2 post, the upgrade manual said to put an inch of prebend in the front beam. I could not find this kind of information anywhere for the 6.0 and my dealer told me to just get it tight.
Jake Kohl | | | Re: new crossbar
#39412 10/27/04 08:55 AM 10/27/04 08:55 AM |
Posts: 3,528 Looking for a Job, I got credi... | Before un-doing the bolts you need to remove any pre-bend in the front beam. Ideally when sailing, the front beam should be flat - Rig tension / mainsheet tension etc will bend it down....
So your front beam should be bent up - remove this before un-doing the bean bolts or you will cause problems Since that is my old beam, I can attest that there is not much prebend in it*... however, any prebend that exists due to the tightness of the dolphin striker post would be between the tips of the dolphin striker 'arms' and would not affect the outer lengths of cross bar that attach to the hulls - they would still be as straight as the day they were born. I don't see how this might be a problem when attaching it to the hulls. *When I upgraded my 5.2 post, the upgrade manual said to put an inch of prebend in the front beam. I could not find this kind of information anywhere for the 6.0 and my dealer told me to just get it tight. They might be straight, but will they still be level ? Any bend in the front beam will result in the bolt holes (in the beam) being deflected away from vertical - this will over stress the bolts when taking them out and may result in the stripped-thread-re-tap-nightmare-of-doom.
600
guests, and 45
