| Re: "higher quality" ?
[Re: h17racer]
#40000 11/12/04 09:28 AM 11/12/04 09:28 AM |
Posts: 1,884 Detroit, MI | The white sail is both Mylar and Dacron. Vertical cut. You can see the pattern better in the photo below: That's the Dacron side. This is the Mylar side: I "won" a horizontal cut mylar sail in a raffle (it was excess inventory - a sail left over from the '90 17 Worlds in Toronto.) It was slow with a capital "S" | | | Various 17 Mainsails Designs
[Re: h17racer]
#40005 11/12/04 03:45 PM 11/12/04 03:45 PM |
Posts: 14 San Diego | The 17 sail, to my knowledge, has gone through five iterations. First was the original horizontal cut. Second was the radial cut, constructed from Teijin Taffeta Mylar. Japanese Fabric, Neil Pryde, Hong Kong constructed. The mylar choice was simple, they were using it in the windsurfing sails they were building at the time. Re-inforcements along the leech to keep the sail from stretching out. The vertical luff panels were 4.0oz dacron. Third was the same design built by Hobie Cat USA. Hand cut panels. Fourth was the same design, contructed from Dimension/Polyant 180x, colored mylar taffeta, same fabric developed for windsufing sails, fabric from Germany, same Dacron Luff. Hand cut. Fifth was a newer design imported from Neil Pryde in Hong Kong, design was same as used by Hobie Cat Europe. Same fabric, new mylar luff, computer cut. Effective around 1997. Because of tight class rules there has been no change in the fabric. And to the comment by one of the posters that the loads are less, not quite so. The 17 sail isn't much smaller than the new Tiger main. Chip Buck Former head sailmaker for Hobie Cat www.pointsails.com | | | Re: "higher quality" ?
[Re: chip]
#40009 11/15/04 09:05 AM 11/15/04 09:05 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | Hi guys, my 2c worth from an 80`s windsurfing freak background : One-sided mylar/dacron laminate sails were the first experiments using this technique to create a sailcloth that wouldn`t stretch as much as Dacron alone, the fully-battened surf sails were taking a higher load than the "Windsurfer One-Design" sails. I don`t know if it was developed FOR windsurfing, but they were probably the earliest users of this cloth. All sails made of this cloth had reduced stretch, but their lifespan was short-lived, because the bond between the two would fail due to the dacron side stretching more than the mylar side, cuasing delamination. The newer mylar sails don`t delaminate, don`t stretch, and if you go with the right weight sailcloth they will last longer than your sailmaker / sail supplier would want them to. (Ask your sailmaker what cloth he would recommend, and go one heavier  ) If your class rules dictate that the old one-sided mylar MUST be used, get the class rules changed, because your sails will delaminate after a year of hard use. It`s not the build quality, it`s the cloth that is at fault. I`m shocked any sailcloth company still makes the stuff. I don`t know what the process is to approach Hobie to have class rules changed, but I`d imagine that if all the sailors agree to it, Hobie would change the rule. If I know them, they will still be the only official supplier - that`s a business decision and I`m not knocking it, but they would still make money either way. (In fact they would stand to make more since all the competitive racers would invest wisely in a sail that will last them.) Unless, of course, Hobie still have 400 tons of that cloth in a shed somewhere, and need somewhere to offload it....  Cheers Steve | | |
1 registered members (FredL),
2,799
guests, and 283
