| STS!! (Slippery Tramp Syndrome) #41094 12/12/04 01:20 PM 12/12/04 01:20 PM |
Posts: 3,114 BANNED | First of all, I'm still catching my breath from the first sail of the N20 yesterday. In 15-20 with gusts to 25-30, the thing was hauling butt like a raped ape.
However, one thing that we had problems with was that the trampoline, after getting wet, was like a slip-n-slide. During tacks, I wouldn't need to get over, the momentum of the boat slid me across the tramp. It was kind of cool, but then when I needed to honk down on the sheet, my butt would slip right down to the bottom hull, creating a very periless situation.
Short of rubbing it with sand, what can we put on this thing so it has a LITTLE tacky to it?
(FYI, its a brand new tramp) | | | Re: STS!! (Slippery Tramp Syndrome)
[Re: MauganN20]
#41097 12/13/04 08:40 AM 12/13/04 08:40 AM |
Posts: 552 | Hey MH 17 I suspect your H 17 has a vinyl trap,...does it? The mesh tramps are little 'quicker'. Do you have a harness that is mesh on-the-butt- too? If so,....when 'mesh meets mesh', you are positioned for 'lift off'! I had this happen to me,..went back to the fabric harness (with leather seat} Once, I cleaned the I-17 to the max,..which included cleaning the tramp with mild soap,....BIG MISTAKE!!!! For, that thing was a'slip-and-slide' for about the next 5 sails,.....I could not rinse out the soap!,....I would be sailing and just be amazed how my tramp would suds up.....never again! [we are talking salt water too] the I-20,...no comparison,...a true ocean going cat,....enjoy! regards, Bruce St. Croix USVI | | | Re: STS!! (Slippery Tramp Syndrome)
[Re: MauganN20]
#41098 12/13/04 09:02 AM 12/13/04 09:02 AM |
Posts: 371 Michigan, USA | Try a kitchen "cleanser" mild abrasive type product. Always does the trick on NACRA tramps.
Les Gallagher
[Re: Brian_Mc]
#41102 12/13/04 07:21 PM 12/13/04 07:21 PM |
Posts: 1,200 Vancouver, BC | Tad, I had treated mine with U.V. protectant, and had the same problem, as well as a peeved beauty of a crew.I rubbed it down with Sex Wax from a local surf shop. I've never thought of rubbing my crew down with Sex Wax before...guess I've never had "a peeved beauty of a crew" on board
[Re: MauganN20]
#41105 12/14/04 10:54 PM 12/14/04 10:54 PM |
Posts: 3,224 Roanoke Island ,N.C. | AJAX simple as that. Congrats on the new boat. Todd
| | | Re: SES!! (Slippery Everything Syndrome)
[Re: MauganN20]
#41107 01/18/05 02:28 PM 01/18/05 02:28 PM |
Posts: 145 Cheshire, UK | Just as additional warning - I made the mistake of lubing my mainsheet blocks, thinking I was doing the right thing for any little bearings in there. While I was at it, I also sprayed the traveller, and then any other blocks I could find. I made sure the spray went into the blocks & bearings by using the nozzle tube and pointing it into suitable cracks. Swelling with pride after this episode of fettling, I plunged headlong into the wind and chop that is our estuary. Result of all this care and attention: Nightmare.
My lube spray had found its way onto the traveller and main sheets as well as greasing the tramp. I could cleat the main and traveller just long enough to get double-trapped and heave in. Any additional pressure, such as a wave, gust, or an attempt to power up, and bang the traveller let go, dumping us in the drink. We returned to shore and applied sand to the sheets (uuurrrrrgh! but what else could we do in a hurry?). They still slipped out like mad. Then we sent a delegation off to the club house to return with a beer glass full of washing up liquid, which we spread over everything. We sudded up like Santa's beard, and headed out again. Not much better. It took several more attempts, using degreaser (and meths if I remember correctly), and even a rough file edge on the sheets, to finally get some grip back into the system. This represented a total loss of three sailing days before we were safe again. The tramp seemed to get back to normal fairly quickly with degreaser.
My lesson from all this is not to lube anything! If anyone has advise of what should be lubed and when, I'd appreciate it!
Meantime, consider yourself lucky to be sailing anything at the moment - our last three weekends have been blown off (well, it is winter in the North West UK).
Cheers Simon
Simon Shadow 067 | | |
875
guests, and 38
