| Sydney to Hobart-boat grave yard #41886 12/28/04 04:54 AM 12/28/04 04:54 AM |
Joined: Apr 2003 Posts: 1,669 Melbourne, Australia Tornado_ALIVE OP
Posts: 1,669 Melbourne, Australia | Not cat related but worth checking out. 45 to 50 knot winds and 10 meter seas. 54 off the 116 fleet have retired.... The 2 leading 98 foot super maxi's are now out of the race. Konica Minolta launched of a 10 mtr wave, splitting the cabin aft of the mast. Skandia hit a sunfish damaging a rudder then the canting keel locked on one side. The crew abandoned ship and now reports have come in that it has now lost its keel and rolled  Check out releases from Sydney to Hobart http://rolexsydneyhobart.com//Sail-World http://www.sail-world.comSailing Anarchy Forum http://www.sailinganarchy.com/forums/index.php?showforum=1 In Sailing Anarchy look under Hobart retirements and Hobart Dramas | | | Re: Sydney to Hobart-boat grave yard
[Re: Tornado_ALIVE]
#41887 12/28/04 05:42 AM 12/28/04 05:42 AM | Anonymous
| Anonymous
Unregistered | Hi all,
most amazing part about all this news is they won't allow multihulls in this race as they have been considered to unsafe to race to Hobart. They still haven't woken up to the fact that canting keels etc. put greater strains on hulls because of weight attached than modern multihull designs.
Would love to introduce them to Orange etc. Don't get me wrong this would be a tough race for any multi but I am sure thier old storey of multi's being unsafe can not stand up any more.
Regards Gary. | | | And do not forget that ....
[Re: ]
#41888 12/28/04 09:01 AM 12/28/04 09:01 AM |
Posts: 9,582 North-West Europe | And do not forget that moderns multi's are now capable of outrunning bad weather.
To story of Hobart seems to be that all boats in trouble get trapped in a bad spot and are killed. The faster boat nearly always manage to sail into saver zones.
| | | Re: And do not forget that ....
[Re: Stewart]
#41890 12/28/04 09:45 AM 12/28/04 09:45 AM |
I have some Hobart documentaries on tape and they all seem to point to a rather small zone of exceptionally bad weather in the larger picture of generally bad conditions. Mostly likely just because of this convergence of the two currents and the weather systems coming in from the southern polar ocean. Pretty much the boat outside this zone get bad weather but not of the magnitude that would kill them.
I venture that a small detour around such a bad spot bu a multi wouldn't hit its result to much and no boat is as slow as one that is on the bottom or sitting like a duck with all sails down riding out a particulary violant storm.
See it just like the dull drums, multi's can look for a passage through it along a much wider front than a mono hull can. As a result they can minimize the impact or slip through and escape the worst. I venture that finding a passage of relative mild conditions may be found in the same way.
In relation to Open 60's, I don't think these will hold up to well, They are designed to the extreme and they don't have much margin left. However the newer designs that are intended to participate in more ocean crossing races and the maxi cats should be able to.
After all Bass strait is bad but the Southern Ocean in general is bad and the maxi car have survive that one quite alright.
[Re: Wouter]
#41891 12/28/04 10:22 AM 12/28/04 10:22 AM |
Posts: 12,310 South Carolina | Most Southern Ocean multihull passages have been in a downwind direction with the swell. While the Southern Ocean is certainly treacherous, the part of recent multihull circumnavigations where most structural damage has occured is while beating to weather in the Atlantic on the way back home. It's more about the wind and wave direction than strength and size.
These guys in the Hobart are beating to weather in horrible conditions. Minolta's cabin roof buckled inward because her keel kept trying to go downward and hull nearly collapsed from the buoyancy after landing off a wave. One of Skandia's huge canting keel hydraulic rams snapped in two leaving the keel swinging wildly. I don't think many multihulls would survive this beating. Upwind is hard on anything.
Jake Kohl | | | Re: And do not forget that ....
#41892 12/28/04 11:34 AM 12/28/04 11:34 AM |
Posts: 3,528 Looking for a Job, I got credi... | I will be able to get a first hand account in a few days time, One of my good friends is skippering a Sydney 38 and has just retired - from what I can find so far it looks like they are making for Eden to then decide what to do next.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: And do not forget that ....
[Re: scooby_simon]
#41893 12/28/04 11:37 AM 12/28/04 11:37 AM |
Posts: 3,906 Clermont, FL, USA | Scooby,
What's the name of the yacht?
Dave
#41896 12/28/04 07:15 PM 12/28/04 07:15 PM |
Posts: 1,307 Asuncion, Paraguay | don't think many multihulls would survive this beating. Upwind is hard on anything. I guess upwind should be structurally harder on boats with a keel, because they require more energy to move, so when hitting a wave they also have more energy to loose. Also, they loose it faster due to their shape. Anyone can confirm that? A rigorous answer would be quite complicated, but maybe Wouter can enlighten us. Luiz
Luiz
[Re: Luiz]
#41897 12/28/04 07:44 PM 12/28/04 07:44 PM |
Posts: 12,310 South Carolina | Luiz,
I would agree with that statement wholeheartedly - but - monohulls are a lot more solid by nature of their shape. A multihull crashing through those kind of waves would not be landing flat on all surfaces and the dangling entities (i.e. hulls / amas) and their connections would have to bear huge torsional and shear shock loading. Not to mention that the multi-hull is sailing considerably faster even if taking a conservative pace.
I think that a multihull is more susceptible to structural damage in those kind of conditions than a monohull (gasp). HOWEVER...a multihull is much less likely to completely sink than a monohull if something does go wrong.
Jake Kohl | | | Maybe ...
[Re: Mark L]
#41899 12/29/04 12:01 AM 12/29/04 12:01 AM |
Posts: 9,582 North-West Europe | Ellen MacArthur is about to endure her third 50-60 knot storm. What does that say about being able to outrun all bad weather?
Maybe she is overtaken them ? Wouter
[Re: Mark L]
#41900 12/29/04 12:02 AM 12/29/04 12:02 AM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett
Posts: 1,012 South Australia | When Bass straight really "gets up" the waves resemble a monstorous "washing machine" with huge swells from one direction and waves breaking on top of the swells travelling in a different direction, and when I say "huge" it is a conservative generalisation. There are "rogue waves" that can appear from almost any quarter regardless of the direction of the swell and the wind, and gusts of 90 to 100 knots are a regular occurance when small (in area), intense lows converge from different directions as they funnel through Bass straight, meeting lows coming around Tasmania from the Tasman or up from the Southern oceans, all combined with an approx' two to three knot, warm current travelling south down the east coast meeting the cold waters of the southern ocean It can be an absolute "hell" to try sailing in. The Southern ocean on the other hand gets very "big" very "rough" and very dangerous, particularely the further south you sail across it, but it is completely "open" ocean with the winds travelling around the world without coming into contact with any land mass (for most of its spread) and as such it is a very different type of "sea" to sail in, with much more predictability when compared with the waters in Bass straight. | | | I'll pass ....
[Re: Luiz]
#41901 12/29/04 12:05 AM 12/29/04 12:05 AM |
Too many factor involved to give a meaningful answer.
Banging and Slugging around a 1000 kg lead keel is sure as hell putting a lot a stress and strain on mono contruction as well.
And the fashion these days is to make monohull racers with relative flat keel lines to get them planing. These vessel are far removed from the classical working boats that could survive petty much anything. Both the mono's and the multis'
But again to main idea was to not be at the spot where the [censored] hits the fan.
285
guests, and 47
