I17 Weight #4249
11/26/01 07:31 PM
11/26/01 07:31 PM
Anonymous OP
Anonymous OP
Does anyone know the actual weight of the I17R (with snuffer, etc)? Not just guesses. Not from the old web site. Maybe someone who actually weighed one with a carbon mast. I have hear so many different numbers (280-325) and would be interested to know if someone put one on a scale.
<br>
<br>Thanks<br><br>
Re: I17 Weight #4250
11/26/01 08:05 PM
11/26/01 08:05 PM
Crystal Beach/Dunedin CSWY Fl.
catsailorp19mx Offline
Not thinking of getting rid of the UNI , are you ?
<br>Dave<br><br>
4259- (18 downloads)
Re: I17 Weight #4251
11/26/01 10:50 PM
11/26/01 10:50 PM
USA
NaCl H20 Offline
NaCl H20  Offline
USA
The ISAF measured the Euro I17 at 157kg (345 lb)
<br>Texel has 155kg (341 lb)
<br>The Euro I17 Alu mast would probably weigh about 8 lbs more and I think Texel weighs the boats with required safety gear ( righting lines, paddle, and whatever) so figure 10 lbs.
<br>I was considering the I17R a while ago. When I called the factory they wouldn't give a definite answer. <br><br>
4264- (21 downloads)
Re: I17 Weight [Re: NaCl H20] #4252
11/27/01 05:37 AM
11/27/01 05:37 AM
Anonymous OP
Anonymous OP
note: Texel weighs WITHOUT the spinnaker equipment<br><br>
Re: I17 Weight #4253
11/28/01 06:52 AM
11/28/01 06:52 AM
brobru Offline
brobru  Offline
Mike,
<br>
<br>I suspect that the boat ( dry) is NOT as heavy as noted.
<br>
<br>Reason being, I have a I 17 normal. I use boat fenders, not beach wheels( long story) to pull my boat up the beach here in St Croix. I can do it fairly easily too ( I have a good incline to go up!).
<br>
<br>Tom has a I-20 next to me, him and Scott (crew) are younger and stronger than me, (I'm 49), they grunt and groan to get their boat up the same incline. In fact, they look for a third body to help, if they can..( they use beach wheels)
<br>
<br>Point being, I doubt if I can roll 350-ish pounds up a sand dune.
<br>
<br>I still say 310 or so. Why the Factory does not cooperate is stupidity.
<br>
<br>Bruce
<br>
<br>St. Croix
<br><br><br>
Re: I17 Weight #4254
11/28/01 03:07 PM
11/28/01 03:07 PM
Anonymous OP
Anonymous OP
To One and All
<br>
<br>I weighted mine the best I could and came up with 315 lbs, and that was everything.
<br>
<br>Just so ya know
<br>
<br><br><br>CR, Inter 17R USA 107
4335- (17 downloads)
0 registered members (), 591 guests, and 41 spiders.
