Fast boat for camping? Motor Boat, Cat or Tri? #43705
01/30/05 07:55 AM
01/30/05 07:55 AM
fabola Offline OP
fabola  Offline OP
I want to upgrade my small 14 feet catamaran to a faster boat that also will be used for camping (sleep in it or dry space for tent and camping equpment). Good if it's simple and if it's possible to sail singlehanded. It should be fast even i light winds. Even if i don't like the idea I'm also considering a motor boat. Any suggestions, pros and cons?
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: fabola] #43706
01/30/05 10:52 AM
01/30/05 10:52 AM
South Florida & the Keys
arbo06 Offline
Happy Birthday arbo06  Offline
You could camp on this bad boy!
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: arbo06] #43707
01/30/05 11:02 AM
01/30/05 11:02 AM
arbo06 Offline
here is a better view of the deck
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: fabola] #43708
01/30/05 11:10 AM
01/30/05 11:10 AM
Cape May, NJ
DrySailor Offline
DrySailor  Offline
Cape May, NJ
It seems for the uses you have described, a Corsair Tri would be a great option. It is a large price jump from your 14 ft. cat, however, it is very fast, stable, has camping accomodations and a very shallow draft...they are technically beachable although I am not sure as to the effect that would have on the gel-coat. You could pick up a used F-24 for near the same price as a motorboat with camping accomodations...and you would still remain on the correct side of the tracks...A stiletto 23 might also be a great option; as they are much less expensive and still have spartan accomodations...although you would probably use it to store your tent and gear and then camp on shore. There are numerous posts about both of these boats on this forum. I enjoyed the story in the "crusing multihulls" section by Tom House entitled, "another great crusing adventure," which was about a trip on a stiletto. Good luck and do your best not to cross over to the other side...
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: DrySailor] #43709
01/30/05 11:34 AM
01/30/05 11:34 AM
You might want to consider a Shark catamaran, 20 foot long, 10 feet wide and folds for trailering (folding and unfolding only takes a few minutes). It has a hard deck instead of a trampoline, so it would be great for a boom-over tent. And it has storage compartments at the forward end of the deck. You could probably mount a small outboard on the back, but it is quite fast sailing in light air.
Another option, although smaller, might be the Isotope. It has huge storage compartments in the hulls and is an excellent light-air boat.
Both boats have simple rigging and are easily singlehanded.
Re: Fast boat for camping? Motor Boat, Cat or Tri [Re: fabola] #43710
01/31/05 08:20 AM
01/31/05 08:20 AM
Brisbane Queensland- Australia
Q
Qb2 Offline
Qb2  Offline
Q
Check out the 'camper mobile' story on page 7 for a H21 fully loaded complete with sound system! H18s have excellent carrying capacity,speed and can be sailed solo. I don't know if you have 16' Calypso cats in the US. These had large deck hatches which allowed huge in-hull storage and were quite the rage in Oz for camping holidays.
If you want a cat with below deck accommodation look for Seawind 24s/or malcolm tennant designs for sale in your area.
If you want to build your own and have about 3 months free, go to members.optusnet.com.au/~rhturner1
for the Aussie Jarcat trailerable cats.
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: fabola] #43711
01/31/05 09:53 AM
01/31/05 09:53 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Try a Mystere 6.0 with a front tramp and wings.. Loads of volume in the hulls and lots of sail area..XL is 10' wide.
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: pitchpoledave] #43712
01/31/05 05:33 PM
01/31/05 05:33 PM
arbo06 Offline
look at this storage area.
43903-keys Kruisin\'.jpg (139 downloads)
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: arbo06] #43713
01/31/05 05:45 PM
01/31/05 05:45 PM
But where is the "dry" storage area?
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: fabola] #43714
01/31/05 06:22 PM
01/31/05 06:22 PM
Houston, Texas
EasyReiter Offline
EasyReiter  Offline
Houston, Texas
Well asking all things of anything is usually not realistic, however if by fast you mean as fast as the 14 or faster, and by camping you mean really rustic, (use a 5 gal bucket for a potty, tarp over the boom, sleep on the tramp) then you really only need 2 coolers tied to the boat, one for beer and the other for beer or dry clothes and small blanket). The Hobie 21, with gizmo on the front crossbeam is about as close to a fast cat with storage that I have seen. once you ask for real storage on a cat it starts to make the hulls wider and thus slower. Was on a stiletto 30 great boat, moderate storage, could sleep in if it was raining, but not a screamer. If a motor boat is a consideration, get towing insurance. I like to keep the performance of a cat separate from living arrangements, drive somewhere, set up camp and sail from there or to it.
Marc Reiter I 20 #861 Dikes, Ferries and Tramps. www.texascitydike.com
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: EasyReiter] #43715
01/31/05 07:30 PM
01/31/05 07:30 PM
Flensburg, Germany
Fritz Offline
Fritz  Offline
Flensburg, Germany
This is the fastest high quality built camper you can get:
http://dragonfly-trimarans.org/d920_photos.htm
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: fabola] #43716
02/01/05 01:36 AM
02/01/05 01:36 AM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Consider a Reynolds 21. Nacelles access spacious hulls, carries lots of camping gear and crew without much speed penalty. Still tops 15 kts. Not a lot of them out there though. Dave
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: fabola] #43717
02/01/05 11:16 AM
02/01/05 11:16 AM
Tiger Offline
Tiger  Offline
Build this
Wharram Tiki 21
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: Tiger] #43718
02/01/05 11:25 AM
02/01/05 11:25 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Tiki 21 is a nice boat, comfortable but not fast. The Reynolds 21 is pretty fast and has storage inside (you could sleep there if needed to. (there is one for sale at our club, young fellow single hand all the time) I have a Stiletto 27, rates about the same as a H16 or better. I've put 10 people with plenty of room to spare (not to race though). Fun to sleep on or in. If you want more room than that you'll need to go to a leaner, but you'll never do 15 knots on one of those.
Clayton
S27, H16
Re: Fast boat for camping? Motor Boat, Cat or Tri? [Re: Tiger] #43719
02/01/05 11:53 AM
02/01/05 11:53 AM
Houston, Texas
EasyReiter Offline
EasyReiter  Offline
Houston, Texas
Or buy it from Tami.
Re: Fast boat for camping? Motor Boat, Cat or Tri [Re: arbo06] #43720
02/01/05 11:30 PM
02/01/05 11:30 PM
toronto, canada
basket.case Offline
basket.case  Offline
toronto, canada
eric, i could store your boat in mine. its not quite as fast, but great for camping.
Re: Fast boat for camping? Motor Boat, Cat or Tri [Re: basket.case] #43721
02/02/05 08:55 AM
02/02/05 08:55 AM
arbo06 Offline
Hey Basket,
That is BAD butt, what is it?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Fast boat for camping? Motor Boat, Cat or Tri [Re: arbo06] #43722
02/02/05 11:04 PM
02/02/05 11:04 PM
toronto, canada
basket.case Offline
basket.case  Offline
toronto, canada
thanx, she is a highly modified tomcat 6.2 i built. 6 oz kevlar hulls inside outside of a half inch core and a 65 lb carbon wing mast. (11.5x4.5 inches) she is not the fastest boat out there, but she works for my family.
Re: Fast boat for camping? Motor Boat, Cat or Tri [Re: basket.case] #43723
02/03/05 12:40 AM
02/03/05 12:40 AM
Westport, Ma. U.S.A.
Brian_Mc Offline
Brian_Mc  Offline
I think all those boats are awsome! The Tiki may be slow by comparison, but I hear they are great little cruisers, and the Supercat and Tomcat are incredible! They must be a blast! Eric , are you going to do any camping trips on her? And what about her name? Did I miss that somewhere? A beauty like that deserves a name!
Re: Fast boat for camping? Motor Boat, Cat or Tri [Re: Brian_Mc] #43724
02/04/05 09:23 AM
02/04/05 09:23 AM
jluzius Offline
jluzius  Offline
I have a Reynolds 21 in good condition for sale if interested. I can email pics. Jluzius@yahoo.com
0 registered members (), 4,603 guests, and 635 spiders.
