Batten Splinters #44545
02/15/05 04:13 PM
02/15/05 04:13 PM
Baton Rouge, LA
Dean Offline OP
Dean  Offline OP
Baton Rouge, LA
New battens; tiny, invisible, undetectible except for the pain, splinters when handled. Would a thin coat of polyurethane sovle the problem?
Re: Batten Splinters [Re: Dean] #44546
02/15/05 04:44 PM
02/15/05 04:44 PM
maybe hit them with a light sandpapering
Re: Batten Splinters [Re: Dean] #44547
02/15/05 06:26 PM
02/15/05 06:26 PM
Pensacola, Florida / Katy, Tex...
Cookie Monster Offline
Duct Tape. I had a similar problem once. Doudle back some duct tape and see if that will take them off. It worked for me.
Don Cook ARC22 #2226 ADRENALIN
Re: Batten Splinters [Re: Cookie Monster] #44548
02/15/05 07:01 PM
02/15/05 07:01 PM
davidtilley Offline
davidtilley  Offline
LIGHT SANDING FOLOWED BY CLEAR TWO PART URETHANE. uSUALLY ON MASTS AND STUFF IT IS BECAUSE SUNLIGHT HAS ETCHED AWAY THE SURFACE AND EXPOSED THE FIBRES. DONT WANT TO APPLY A LAYER OF SOMETHING THAT MIGHT EFFECT THE STIFNESS. (LIKE EPOXY) Also, typically, old fiberglass battens get really stiff too, so you might want to sand, taper and tune them. Catsailing for the nineties has a section on that, if I remember.
Re: Batten Splinters [Re: davidtilley] #44549
02/15/05 07:57 PM
02/15/05 07:57 PM
Baton Rouge, LA
Dean Offline OP
Dean  Offline OP
Baton Rouge, LA
Thanks for the suggestions. I'll try them all.
I really like these battens. They came already shaped with a very slightly used sail from a legendary sailmaker in the Keys (Hi, Steve), so the development work was already done on both sail and battens. I got lucky. They are quite a change from the factory big, thick, white sticks which would be fine for a breeze but here in FLA most of my time is in much less than a breeze.
Re: heat shrink [Re: Dean] #44550
02/15/05 09:37 PM
02/15/05 09:37 PM
samevans Offline
samevans  Offline
Once upon a time they sold kits with sections of special heat shrink tubing just for battens.
Re: heat shrink [Re: samevans] #44551
02/16/05 09:40 AM
02/16/05 09:40 AM
Houston
carlbohannon Offline
Houston
I had a set of battens like that.
Lightly sand them and apply a coat of water based polyurethane. Then keep your hands off off them as much as possible. Take them with you when you sell the boat.
The heat shrink tubing works. It does stiffen the batten though. A lot of the stock of heat shrink made for battens is getting old (15-20 years) and not stored properly. If you want to do this, buy new PVC or teflon heat shrink from an electronics supply store.
0 registered members (), 320 guests, and 35 spiders.
