| Re: Are you a "wavepiercer-fashion" victim ?
[Re: FRENCHIE]
#45061 02/26/05 02:05 PM 02/26/05 02:05 PM |
Posts: 3,116 Annapolis, MD | How well does the Hobie Fox sail? The boat has been sailing for several years with a wave piercer design.
The boat never caught on in the US. However, I believe one boat was actively raced in Southern California against a well sailed I20. I was never sure if its failure to match the performance of the I20 was due to a less then optimal rig OR to the hull shape. Did the boat go through the water well and handle the loads and weight?
Mark
crac.sailregattas.com
[Re: FRENCHIE]
#45062 02/26/05 04:36 PM 02/26/05 04:36 PM |
It is undoubtably true that part of the wave-piercer thing is a hype. However, the larger boats can be improved when understanding the concept properly. It has nothing to do with wave-piercing and everything with the redistribution of the SAME total amount of volume.
Test sail a Taipan 4.9 and then a Blade F16 and you'll know what the difference can be.
Some designers however just take a older hull shape and trim the bow and sterns. That way they end up with waht looks like a wave-piercer but is actually worse than the older unmodified hull.
As always there is no substitution for understanding what is really going on.
But in our 1 min attention span society this is alot to ask.
[Re: Wouter]
#45063 02/26/05 06:03 PM 02/26/05 06:03 PM |
Posts: 2,718 St Petersburg FL | Yep, I have been cought into the hype. But the Blade being built locally I could not pass up the oportunity for this. So yes I am part of the Versace club fashion trend!!  lol | | | Re: Are you a "wavepiercer-fashion" victim ?
[Re: FRENCHIE]
#45065 02/27/05 11:30 AM 02/27/05 11:30 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I'm not a victim for sure, because, to me, "wave-piercing" translates to "very wet." I would much rather go over the waves than through them.
And I think Frenchie is right about the problems of carrying the concept up to bigger racing cats and to cruising cats.
Question: Of the three maxi cats racing currently in Oryx Quest, are their bows considered to be "wave-piercing"? | | |
4,352
guests, and 686
