| Re: Welcome Marcus !
[Re: Wouter]
#45395 03/06/05 02:55 PM 03/06/05 02:55 PM |
Posts: 13 Scotland | One thing you dont seem to have taken into account Wouter is the total surface area of the Stealths "T" foils, remember we have 4 (four) foils to an INT 14's 2 (two) so we're probably a lot closer than you think ! Also the Stealth is designed as a "PLANING" cat and the foils are angled to correspond with the optimum planing angle. As i'm from a Motor Racing background the beneficial side of the "T"s caught my attention although i was lucky to have a friend working for a F1 team who advised me on a more suitable section - glad i didnt have to pay for the use of their C.F.D. programming time ! anyway what are friends for ?
Keen Cat Sailor
| | | Re: "T" foil rudders - Pitchpoling is History !
[Re: Marcus F16]
#45396 03/07/05 07:58 AM 03/07/05 07:58 AM |
Joined: Jul 2001 Posts: 953 Western Australia Stewart
Posts: 953 Western Australia | Mate, The idea behind trim foils from a moth or a stealth is different to the original idea that inspired the 14's foils. The International Moth is highly unstable in all directions. Without a trim foil the skipper needs to be somewhere behind and to windward of the hull. ie they are not the easiest to sail normally and downwind almost impossible. A trim foil makes the impossible almost possible (while still being impossible to old fat slow guys like me) However the I14 while difficult beasty isnt that bad really. What the I14 has, is an issue with is length to power ratio. Biecker came up with the idea to use an assymetrical foil to modify the stern wave. Sort of similar to the bulb one sees on ocean carriers, but in reverse. By flattening out the stern wave, ![](http://www.catsailor.com/forums/images/graemlins/confused.gif) the theory goes the water "thinks" the hull is a much more acceptable 16 foot long. The longer the waterline length the faster the hull.. This is more important uphill than downhill. (Hopefully one doesnt have much hull in the water downhill). To accomplish this the trim foil needs to be the same width as the stern. Also the deeper the foil is below the stern wave the larger the surface area required to modify the surface wave. Secondary is the anti mining aspect. hope this makes sense.. I know what I mean anyway. Stewart | | | Re: "T" foil rudders - Pitchpoling is History !
[Re: Stewart]
#45397 03/07/05 08:14 AM 03/07/05 08:14 AM |
Joined: Mar 2005 Posts: 322 South Australia Marcus F16
Posts: 322 South Australia | Thanks for the welcome, this group seems to communicate very well.
I will dig out some mid to low resoltion photo's of the Blade F18 during construction & give some of the reasons why I belive the platform is very rigid.
I will attempt to create a new thread for this info & add my personal profile with all of yours.
I notice there is a good spread of people stretched to most corners of this planet & its good to see a couple of sailors close by ( Gipsland & WA).
Talk soon
Marcus
Marcus Towell
[Re: Stewart]
#45398 03/07/05 11:49 AM 03/07/05 11:49 AM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | For clarification, the Stealth T foils are strictly for anti-pitchpole purposes. They do little for the stern wave--they're just too deep. When I sailed with the T-foils they did prove to be very potent at preventing nose diving. But they were also very unforgiving to any surface grass, fishing line, or as we encountered, rope from a crab pot. (At least we had the second rudder to steer us home.)
Off the subject...a really nice aspect of the Stealth rudders is the cassette up/down design. This allows you to push the rudders only part way down in light air or shallow water. Of course, there's not way to do a kick up mechanism with the T foils. But a standard rudder that had both cassette up/down movement and a kick-up mechanism would be very handy and safe. I believe some of the new Farrier trimarans have such a rudder.
[Re: ejpoulsen]
#45399 03/08/05 05:10 AM 03/08/05 05:10 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | " Of course, there's not way to do a kick up mechanism with the T foils." Eric, we use the Dotan rudders, the mechanism allows for very quick "pump-action" push down and pull up of the rudders. If you`re moving slowly i`d assume you could use T-foil rudders on a system like this. Then again that doesn`t allow you to sail into the beach in sizeable waves, since you can`t surf a wave slowly ! (I`ve tried.) Also can`t have rudders partially down for steerage while launching. OK, I`ve just explained to myself why the cassette stocks are the only option with T-foils. Thanks ! ![](http://www.catsailor.com/forums/images/graemlins/confused.gif) Steve | | | Re: "T" foil rudders - Pitchpoling is History !
[Re: Marcus F16]
#45402 03/08/05 06:45 PM 03/08/05 06:45 PM |
Posts: 1,911 South Florida & the Keys | Would there be any benefit or drawback to adding T foils to the dagger? They are already in a cartridge?
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: "T" foil rudders - Pitchpoling is History !
[Re: arbo06]
#45403 03/09/05 04:02 AM 03/09/05 04:02 AM |
Many drawbacks, no advantages. Daggerboards are to close to center of bouyancy to have any damping effect on rocking about. Also the T-foils on teh daggers will lower and raise the boards automatically with different boattrim possibly you can see them move almost continiously. The T-foil rudders are pinned into place.
[Re: George_Malloch]
#45407 03/10/05 03:57 AM 03/10/05 03:57 AM | Anonymous
| Anonymous
Unregistered | Hi all,
is scratching of blades a big problem, many cats in OZ use to use dagger type boxes, but I thought one of the reasons they stopped was scratching of blades. As far as kick up is concerned this is easily fixed as Darryl Barrett suggests.
Many cats I have seen have deeper rudders than centreboards, I know on the mossie I have hit rudders on bottom without hitting centreboards. Mind you kick up rudders are not of upmost importance, I sailed a Contender dinghy with a 3' deep fixed rudder for years and survived, mind you a cat is harder to steer to deep water without the rudder than a dinghy.
Regards Gary.
#45408 03/11/05 03:44 AM 03/11/05 03:44 AM |
Posts: 13 Scotland | It seems that everbody thinks the Stealths "T" foils are only a down wind advantage - NOT - Just to clarify things i had a chat with Jon Pierce (Stealth Designer) and this is what we came up with. Going upwind with the "T"s the boat adopts a rather "different" feeling about her, when a gust comes and the boat heels/accelerates and whereas before you had that feeling through the rudders that she was trying to "screw up" into the wind now you dont. Jon reckons that its a combination of a) by keeping the bow up you reduce the forward wetted area thus leaving the centre of effort and the centre of pressure pretty much where they were designed and b)because of the angle of inclination of the "T"s as the boat heels they operate like mini-rudders and try to keep the bows off the wind. All i know is that it just improves the overall feel of the boat.
Keen Cat Sailor
[Re: MikeYoung]
#45411 03/21/05 08:19 AM 03/21/05 08:19 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | This was in Scuttlebutt: HIGH PERFORMANCE SAILING (Following is a brief excerpt from a feature on The Daily Sail subscription website presenting an update on the International 14 class from the UK perspective.) Like the Moth class, the International 14s are entering a 'period of consolidation' after inclinable rudder T-foils became de rigeur a couple of years ago transforming the performance and the necessary technique required to sail the boat. After attempts at putting foils at the bottom of the rudder, the class norm is now to fit the foil half way up and there is a general trend towards thinner foils. At present there are still essentially two systems for altering the pitch of the rudder T-foil: the Paul Bieker set-up which contains an internal push rod, the foil moving independently of the rudder blade and the RMW Marine/Morrison system where the foil and rudder are one part that is inclined in its entirety relative to the hull. Bieker it seems may be moving towards the RMW system as at the Worlds he was trialing a one part system - the advantage of this is that with no moving parts to squeeze in and the foils can have a thinner section. At present 'period of consolidation' does not equate with the 14s following the Moths in going fully foiling. At the Dinghy Show we spoke to the class' Dave Spragg who in fact has successfully tried fully foiling his 14 using the exact same gear as the Moths (lifting foils and the wand made by John Ilett's Flatacraft company in Perth) but all of it 50% bigger. "I've got one. I've flown it, but I don't think it is way forward for the class in the short and medium term," says Spragg. - The Daily Sail, full story and pictures: www.thedailysail.com | | | Re: Pictures of T-foils on rudders
[Re: Wouter]
#45412 03/21/05 08:57 AM 03/21/05 08:57 AM |
Posts: 552 | Marcus, Wouter and all, Thanks for the info and pics. If possible, could one of you provide a measure of some sort? For example, the width of the rudder ( fore and aft) at the bottom. From that data, we could approximate the rest of the dimensions. Thanks again, Bruce I17 St. Croix | | | Re: "T" foil rudders - Pitchpoling is History !
[Re: Mary]
#45413 03/21/05 09:54 AM 03/21/05 09:54 AM |
Posts: 552 | MAry and All, 1. The idea of 'removable' was interesting. 2. IF one were to make a fitting with rubber grommets and a 'pin'(s) to attach. Of course, it would have to be a nice job design to reduce induced turbulence. 3. IF this was possible, the one could fit to a rudder and/or a d-board. ..thanks again for a great line. regards, Bruce St. Croix | | |
319
guests, and 101
