Size Rope for Mast Halyard on H18 #45438
03/04/05 03:37 PM
03/04/05 03:37 PM
Bridge City, Texas
pirate_tx Offline OP
Bridge City, Texas
Anybody Know the size rope on a hobie 18 main halyard? in the hobie catalog it says RHO14WHT X 58'. I know that its 58
feet long but what size diameter?
Re: Size Rope for Mast Halyard on H18 [Re: pirate_tx] #45439
03/04/05 03:42 PM
03/04/05 03:42 PM
Chicago, IL
Krisu13 Offline
Krisu13  Offline
Chicago, IL
If I remember correctly it is 3/16
I20
Re: Size Rope for Mast Halyard on H18 [Re: pirate_tx] #45440
03/04/05 03:45 PM
03/04/05 03:45 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
I think the 14 means 1/4".
Re: Size Rope for Mast Halyard on H18 [Re: pirate_tx] #45441
03/04/05 03:49 PM
03/04/05 03:49 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
I would also suggest 3/16". 1/4" may be stock, I don't know. However 3/16" of a no stretch line would be best.
Mike Hill
www.stlouiscats.com
Mike Hill
N20 #1005
Re: Size Rope for Mast Halyard on H18 [Re: Mike Hill] #45442
03/04/05 03:53 PM
03/04/05 03:53 PM
Bridge City, Texas
Bridge City, Texas
Whats the smaller size going to do for me?
Doug Ramsey
Re: Size Rope for Mast Halyard on H18 [Re: pirate_tx] #45443
03/04/05 04:44 PM
03/04/05 04:44 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
3/16" should run free'er and be cheaper and lighter. Disadvantage is that it may be harder to grip.
Mike Hill
www.stlouiscats.com
Mike Hill
N20 #1005
Re: Size Rope for Mast Halyard on H18 [Re: Mike Hill] #45444
03/04/05 05:12 PM
03/04/05 05:12 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
If a 3/16 halyard is "too hard to pull" there are other problems.
Usually this is battens are in too tightly, and/or binding on an old sail: I have moved the luff batten end caps forward about 1/4 inch by making new holes for the machine screws. This keeps the cloth luff tape from "wrapping around" the sail track and binding.
Also use McLube spray if the sail track is cleaned first.
The clue word here is "old sail"
Dacarls:
Re: Size Rope for Mast Halyard on H18 [Re: pirate_tx] #45445
03/05/05 10:36 AM
03/05/05 10:36 AM
California
Sailing Pro Shop Offline
California
3/16" and I would get 61 feet of Marlow prestretch. We have gone as thin as 1/8" spectron 12 but if you compress the mast with a ton of downhaul the halyard can sneak pased the bolt rope and exit the curf.
Drop me a note with any questions.
Mark Michaelsen http://www.sailingproshop.com (800) 354-7245
Re: Size Rope for Mast Halyard on H18 [Re: pirate_tx] #45446
03/05/05 03:43 PM
03/05/05 03:43 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
The smaller line will run more freely. Also, make sure you replace the sheaves in the mast (top and bottom). I found on my 18 that these wear around the axle hole, then they stop spinning, making things real bad. New sheaves, small line, and pointing the boat into the wind...
