| Re: LESS WEIGHT, LESS POWER, MORE EFFICIENCY!
[Re: Maurizio]
#4594 12/11/01 04:57 PM 12/11/01 04:57 PM |
Maurizio,
I agree with alot but please, we shouldn't over do it. Or make it into more than it really is.
>>Anyway yr "UNDERPOWERED" F18HT is faster than any other 20 footer both upwind and downwind up to Force 3-4.
I would like to distance myself (and the F16HP class with it) from claims like this. A US I-20 has nearly the same mainsail as the F18 HT and is equally high and together with the slot effect the I-20 rig will produce more power than is proportional than it's increased draq. Ergo it has a better power to drag ratio.
Now I might accept downwind but not upwind. Simply because in a few examples the numbers just don't add up.
>>>The INTER 20, HOBIE FOX, NACRA 6.0 etc. are slower in all conditions than F18HT cats.
This is a tough claim. And I don't think that the situation is that clear cut. But time will tell.
>>The reason:
LESS WEIGHT (110-130 lbs), LESS POWER (204 sqft against 225-245 sqft), MORE EFFICIENCY (UNIRIG vs SLOOP - higher aspect sailplan/32' vs 29.5' tall mast)
More efficient ? This is very simple to say but equaly hard to proof scientifically. I can assure you that efficiency in this respect is very dependend on conditions. A sloop in higher winds of equal or little less overall sail area can well produce more thrust than a high masted uni rig that is depowered under the same conditions.
These numbers and remarkable meteological phenomenons favour the F18HT heavily in winds up to 5 kns as well as any other high masted rig. But right from 6 kns and up the advantage has been cut down to just a few % ; this is without depowering, when the rigs get depowered the sloop will close the cap even more and even overtake the uni rig in total produced power.
These numbers do explain the F18 to iF20 experiences in the medd to high winds so why shouldn't they cover the F18 HT.
Now saying that the F18 HT is much faster than all others can do us far more damage than we want inflict on this new lightweight classes. So please, do not overstate the performance.
Once again, F16 HP class does not support these claims and my models who have been used to develop this clear don't do so either.
| | | Please do maurizio !
[Re: Maurizio]
#4596 12/12/01 01:21 PM 12/12/01 01:21 PM |
Please do maurizio ! And I want the conditions listed too and I'm going to look them up on the net.
Nobody is benefitted by claims that can not be substantiated so I think you should do this.
I'm very amused by this sudden discovery of the all time greatest catamaran but till now I can only say that it had a all together negative effect.
And it will kill us off when these claims are debunked.
Now I can show some results that a 16 footer beat 20 footers this 2001 season but notice that I DON"T claim that this cat can do so on a regular basis.
| | | I would like the data anyway M. I can also use dat
[Re: Maurizio]
#4600 12/14/01 07:00 AM 12/14/01 07:00 AM |
I would like the data anyway M. I can also use data as input to fine tune the models.
2,742
guests, and 394
