Knot on Main Halyard H18 #46284
03/22/05 03:30 PM
03/22/05 03:30 PM
Bridge City, Texas
pirate_tx Offline OP
Bridge City, Texas
I am replacing my main halyard rope on my hobie 18 for the first time. Is there any special knot I should tie to my halyard Ring?? Any special knot that would make hook set easier? The knot thats on it now is just a square knot. And
it hooks most of the time on 3 or 4th try.
Doug Ramsey
TheMightyHobie18 #4383
Re: Knot on Main Halyard H18 [Re: pirate_tx] #46285
03/22/05 04:40 PM
03/22/05 04:40 PM
California
mmiller Offline
mmiller  Offline
California
I have an FAQ on that:
http://www.hobiecat.com/community/viewtopic.php?t=371
>>>Locking the Hobie 17/18/20/21 Halyard:
It is best to simulate the halyard locking with the mast down so you clearly understand the system. Then, depending on how old the boat is, be sure the hook does not have the old "flopper" stainless piece hanging on the hook. This old device caused difficulty in raising and hooking but would make it easier to release and lower. Also, be sure that the knot tied to the ring is very low profile. A long bowline knot will hit the mast head before the ring gets to the hook. If the ring has a small loop at the top... The line should be passed through the loop and a small knot tied. The knot (when ring and shackle are afixed to the sail) should be facing the mast. This tilts the ring closer to the mast. Then (before attaching halyard shackle to the sail) spin the haylard 3 or 4 times clockwise (looking down on the shackle). This "pre-loads" the halyard line and causes the ring to swing back towards the hook. Keep the boat into the wind and hoist. Should lock easily. To release... fully release the downhaul and outhaul. Partially feed the sail up the luff track. Hoist with the halyard to the top till it stops, hold... rotate the aft of the mast base to starboard, hold the mast rotated, ease the halyard a few feet before releasing the mast. Lower the sail.<<<
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: Knot on Main Halyard H18 [Re: pirate_tx] #46286
03/22/05 09:10 PM
03/22/05 09:10 PM
Santa Barbara CA
sbflyer Offline
sbflyer  Offline
Santa Barbara CA
try a buntline hitch...
1 registered members (JesperS), 234 guests, and 47 spiders.
