| Re: Ok I give what's the trick, replacing main halyard
[Re: pirate_tx]
#46301 03/22/05 08:26 PM 03/22/05 08:26 PM |
Posts: 1,253 Columbia South Carolina, USA | Take a paperclip an open it up(bend one loop out), Stick one end thru the halyard, one thru the pull rope then a little bit of tape around all. This is hopw we replace halyards on big boats without dropping the stick. Its never failed me. David www.powergroovesailing.com
[Re: pirate_tx]
#46302 03/22/05 08:58 PM 03/22/05 08:58 PM |
Posts: 324 South Florida | Doug,
I did this last year with not much trouble. I started at the top end and twisted the rope as I pushed in (as if you were screwing it in). I only had a little trouble getting through a section of the lower mast (around where the luff is inserted), but by helping it through with a very thin screwdriver it finally made it through. At the bottom,the area you are having trouble with, again I used the screw driver to poke the end of the rope and pull it out.
Good luck.
Fred F
(ex Hobie 18)
[Re: pirate_tx]
#46303 03/22/05 10:42 PM 03/22/05 10:42 PM |
Posts: 12,310 South Carolina | Hobie 18? Can't you just take out the sheave that's causing the problem, route the line, and reinstall the sheave? Pardon me - because I can't recall how that was configured on the Hobie 18.
Jake Kohl | | | Re: Ok I give what's the trick, replacing main halyard
#46304 03/23/05 06:01 AM 03/23/05 06:01 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I use a ice or seal pick. Start with the mast track facing up. Get it started at the top, reach in the track with the pick and stick the line with it, add a little angle to the pick and walk.
[Re: wyatt]
#46307 03/28/05 05:11 PM 03/28/05 05:11 PM |
Posts: 829 Charleston, SC | Put a reaving splice into the rope and then just tie a small peice of line (read: little bitty) and then rerun the line through the mast. A reaving splice is incredibly simple, and I'm sure you can find instructions online. Or, just use duct tape...if you can't duck it, *&%$ it. Trey N20 314 Layline Rigging www.velocitysailing.com
Trey
474
guests, and 30
