| Re: New F-14
[Re: rickmatos]
#47309 04/12/05 03:44 PM 04/12/05 03:44 PM |
Posts: 284 Norfolk, VA | Cool!! I used a "skinny" windsurfer mast for one of my poles and a two-piece carbon pole for the other. Both worked well, but the two piece was more convenient.
I ran a carriage bolt through the front beam right under the mast. My pole just slips onto the protruding end of the carriage bolt. Others have used other methods, but this one is easy and slick. If you have the factory dolphin striker (like the 16) you'll have to figure something else out..
You can use your stock jib blocks in their stock position, but you will probably want a barber hauler to adjust the slot.
Rick has the whole package on this website, so you can probably knock it out in one order.
If you want to talk about it, you can call me--757-589-6920
Dan
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
462
guests, and 344
