| Re: Help: Supercat 17, Nacra 5.7 or Prindle 18-2?
[Re: royaluser]
#47701 04/18/05 01:05 PM 04/18/05 01:05 PM |
Posts: 591 Bradenton, FL | The Prindle 18-2 and Supercat 17 both use 'boards. The Nacra 5.7M and Prindle 18 are boardless, with the Nacra being a skeg boat and the Prindle being asymmetrical. Of those two, I'd go with the Nacra 5.7M because they are still being produced. You won't be able to right any of them single-handed (without modifications) unless you're a very large man. Adding righting pole should allow you to right any of these boats single-handed. Since you do not give your location, I'm not sure which odd-ball boats might be in your area that would better suit your needs. For instance- a G-Cat 5.0 (~16') or 5.7 (~18') are boardless, dual-trampoline boats with both the room and buoyancy to carry 4-6 people comfortably without undue loss of performance. I've had 9 people aboard my G-Cat 5.7M in 15knots of wind and 4-6' rolling seas and a good time was had by all
Hobie 14T
[Re: royaluser]
#47702 04/18/05 01:24 PM 04/18/05 01:24 PM |
Posts: 217 | Of those 3, I would highly recommend the NACRA 5.7. Boardless *and* boomless, it has fewer controls, and is still in production (as NACRA 570). As another poster pointed out, there is also a G-cat 5.7m, which is also board-less. It has a boom, but, it has a front crossbeam, to which I have seen folks add a forward trampoline.
[Re: flounder]
#47706 04/19/05 11:09 AM 04/19/05 11:09 AM |
Posts: 591 Bradenton, FL | The G-Cat 5.7M doesn't have a boom. The early 5.0s did though. The G-Cat is a SE US manufactured boat, so there should be some in your area.
It has extremely simply controls and is a very durable boat. I've been happy with mine for the past 7 years but have been considering selling it to buy an 18sq as I primarily single-hand.
Hobie 14T
[Re: royaluser]
#47707 04/19/05 12:58 PM 04/19/05 12:58 PM |
Posts: 833 St. Louis, MO, | Greetings,
I may want to occasionally single-hand the boat. If the boat capsizes, I need to be able to right the boat single-handed. None of these boats are able to be righted singlehanded in most conditions. You would need to purchase a righting pole or Gary's righting method. The righting bag in my opinion doesn't work too well. I haven't sailed all of these options. They are all good boats though. I owned an 18-2 for a while and it was a great boat. However the 18-2 is the only boat on your list with centerboards but they do kickup. Also the 18-2 is a bit more fragile of a construction than the other boats. Thus the 18-2 performs a little better than the other boats so there are always tradeoffs. I really like the SC17. I've never sailed it but have sailed against it and it is very fast. The 5.7 and P18 are both nice boats as well. As long as the hulls are solid and it's in good shape you really can't go wrong with any of these boats. Mike Hill www.stlouiscats.com
Mike Hill N20 #1005
[Re: Mike Hill]
#47708 04/20/05 02:44 AM 04/20/05 02:44 AM |
Posts: 11 Molokai, HI | I used to have a Prindle 18, I think they call it the Escape now. Could have sworn I used to right it myself when singlehanding. I weigh about 175.
I'm in a similar situation, need a daggerless boat but me and a teen have to carry it to the water so weight is an issue. We get a lot of wind, usually gusty, and I want to be able to right it by myself - which given the conditions may be often. I originally wanted a Nacra 5.7 but that is pretty much out due to weight and righting considerations. So looking at the NAcra 5.0, Prindle 18 Escape and the P16.
Another consideration, although there will usually be a crew of two, at times the whole family might want to go out. The Escape would handle it but will the Nacra 5.0 or P16 handle 500+lbs without sinking? All comments are appreciated.
EZ | | |
3,195
guests, and 376
