| Re: Broke the boom to mast connector........
[Re: Scubajeep]
#47964 04/25/05 10:27 AM 04/25/05 10:27 AM |
Posts: 829 Charleston, SC | Any hobie dealer can get you the parts for the hobie 18 gooseneck. Just drill those rivets out, remove the endcap, then remove to gooseneck part. Put the new one in, and put it all back together. Be sure to use aluminum rivets so that you don't have problems with dissimilar metals on down the road (ie corosion). For the trap handles, assuming that the wires themselves are in good shape (double check them!), go ahead and break off the old handles. I'm not sure if the online catsailor store has them, but I know Murray's Marine has handles that are made to replace those. They just screw together over the wire and work well. Good luck! Trey N20 314 Layline Rigging www.velocitysailing.com
Trey
[Re: catman]
#47967 04/25/05 03:41 PM 04/25/05 03:41 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | One other thing. I'm not sure how long you've had your boat, besides the normal things you look at for maintance check the shroud anchors. This is the eye that comes up through the hull. The shroud is attached to it. Unscrew it all the way and look closely at it. I had to replace these things yearly. It would tear in half. I had one break and found a few over the years several that had cracks.
The other thing to look at is the furler. Look at the stainless where the bridles are attached. Where the metal is formed into a circle around the drum, look for cracks at the bottom.
[Re: catman]
#47968 04/25/05 07:06 PM 04/25/05 07:06 PM |
Joined: Jun 2001 Posts: 217 Palm Harbor, FL, USA Lance
Posts: 217 Palm Harbor, FL, USA | One other thing. I'm not sure how long you've had your boat, besides the normal things you look at for maintance check the shroud anchors. This is the eye that comes up through the hull. The shroud is attached to it. Unscrew it all the way and look closely at it. I had to replace these things yearly. It would tear in half. I had one break and found a few over the years several that had cracks. I second that. Two years ago we dismasted during a race when one of those let go. The bolt had rusted through.
Lance Taipan 5.7 USA 182 Palm Harbor, FL | | | Re: Broke the boom to mast connector........
[Re: Mary]
#47971 05/10/05 10:42 AM 05/10/05 10:42 AM |
Posts: 70 Louisiana | Got the replacment for the goose neck and will work on it this weekend.....
Does anyone know what size rivits to use?
Thanks Todd Hubbell
Sailing a 1980 Hobie-18M with 1990 hulls in Southern Louisiana.
[Re: flumpmaster]
#47974 05/10/05 01:31 PM 05/10/05 01:31 PM |
Posts: 70 Louisiana | Thanks Guys..... Ya'll are the best!
309
guests, and 40
