Ratings addressing crew weight #4901
12/20/01 09:05 AM
12/20/01 09:05 AM
Dallas, Texas
thom Offline OP
thom  Offline OP
Dallas, Texas
Bill Roberts gave me this info awhile back and I am curious about what you might think.
I want to try to tie in exact crew weight with Portsmouth. I will use my boat for demonstration.
Overturning moment divided by restoring moment does this I think. Overturning moment is related to sail area times 40% of mast height. Restoring moment is related to TOTAL sailing weight times 1/2 of the boat width. So here goes:
ARC22
O.T Moment = 360[sail area] x 40% x 38.5 [Mast Height]= 5544
Rest. Mom. = [467 boat wt + 400 crew wt] 867lbs x 6' = 5202
OT Mom/Rest Mom = 1.065
Next multiply ARC22 Portsmouth Rating [58.5] times the OTmom/RestMom 1.065 you get 62.34.
This factor/rating takes into many factors: exact crew weight, boat specs as a base factor for both sides of the equation, and demonstrated boat performance from MHC.
fair winds
thom
Re: Ratings addressing crew weight [Re: thom] #4902
12/20/01 09:23 AM
12/20/01 09:23 AM
MERRITTISLAND, FL
Matt M Offline
Matt M  Offline
MERRITTISLAND, FL
Thom,
This is a commonly used approximation. Sails generate lift, and it is not a direct relationship to surface area. Different aspect and curvature ratios, in combination with the mast characteristics will give significantly different heeling moments for your equation...oh bother
Sail Fast
Matt
0 registered members (), 282 guests, and 50 spiders.
