| Key Hole Trapeze System #49593 05/18/05 01:05 PM 05/18/05 01:05 PM |
Joined: Jul 2001 Posts: 1,200 Vancouver, BC Tornado OP
Posts: 1,200 Vancouver, BC | Anyone tried the "Bethwaite" Keyhole style trapeze system? I'm interested in the weight savings and preventing another deck puncture when crew hauls himself aboard (has happened twice this year).
Only drawback I can see from the pics I've seen is that the ball-end part can only go in at one set length, unlike the old dog bone rings where you could select a 4 inch difference in length by hooking the top or bottom ring.
Mike.
| | | Re: Key Hole Trapeze System
[Re: Robi]
#49595 05/18/05 01:36 PM 05/18/05 01:36 PM |
Posts: 1,200 Vancouver, BC | Yes, but in the heat of the moment, while racing around the cans, you don't want ot be fiddling with the adjuster lengths. I like to just hook onto the ring I know I'll need for the leg I'm doing (windward=shorter since you will be further forward; offwind=longer 'cuz you're moving further aft).
[Re: Tornado]
#49596 05/18/05 02:54 PM 05/18/05 02:54 PM |
Posts: 805 Gainesville, FL 32607 USA | There have been robust quick adjusters available for many years: metal V-shaped jam or aluminum jam cleats. Metal ones can be length-changed in 2 seconds even while on the wire. BTW- I happily changed to ball-and-socket/ keyhole plate to stop badly denting the sides of my older foam A-cat.
[Re: dacarls]
#49597 05/18/05 02:56 PM 05/18/05 02:56 PM |
Posts: 3,528 Looking for a Job, I got credi... | I think Mikes reasons are simply time(i.e. you don't have any) and you cannot let fo of anything to fiddle - I am planning the same dog bone for my next boat for this very reason - want to be lower down wind. And I will have to go in to put the kite up so there is no overhead in changing ends.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Key Hole Trapeze System
[Re: Andinista]
#49599 05/18/05 05:55 PM 05/18/05 05:55 PM |
Posts: 390 | I'm with Mike, I use the 9" long keyhole dogbones for the same reason. I will use the "short ring" if the water is so rough that the waves are hitting me in the bum. For a two-way keyhole system, you could make a ball rig that had a ball at each end with a tie point off-center between them. Here is a page about a quick-release system. http://www.rwo-marine.com/newproducts/main.htmI don't like the idea of using the quick-release and possibly losing the hook during a race. Perhaps a pivoting hook release could work? Also, the standard trapeze system has the line tied to the dogbone and then run through a block or a thimble and then tied to the bungee cord. This causes the line to wear and get nicks. I tie the tail end of the line to the handle and run the bungee through the block and tie it to the dogbone. I haven't been dunked from a broken line since I started doing it this way. Some of the Charlotte sailors even used wire rope, swedged on. | | | Re: Key Hole Trapeze System
[Re: Eric Anderson]
#49602 05/19/05 10:24 AM 05/19/05 10:24 AM |
Posts: 552 | Hello All, I switched over 2 years ago, as a solo sailor I need to be able to minize potential hazards,..and that ol' hook on my waist will grab onto anything. Does it work?....yep 100% Better?.......oh yes. Why?.....Look at your dogbone,...is it bent?....is it bent around the weld?....I had a weld 'go',...yes, at a very inopertune time.....never again will I wear a dogbone. Heck, I have even broke a weld on a harness spreader bar...you must check those too. Will the ball 'pop out'?....no, I customize the fit by adding 1 layer of tape just above the ball, so as I move around there ia a little 'passive retention'.. Out here, we are in wind and waves all the time,..there is alot of motion to the rig. I preset my trap line height. I run a 3/8' kevlar line from the trap wire direct to the ball, a setting determined on shore....no pulley( I had one blow up), no spring line( had these break too). So, in review, I go.. trap wire..to...kevlar..to .ball....minimize the weak links . ( I keep the bungie thru the hull of course.) So, when a trap system failure put me in the water,..and I got to see my boat sail away from me in a race,.....believe me, this makes you see things differently. ..were was I ,..oh yes,...ball and keyway?..a good product for me. regards, Bruce St. Croix I 17 euro | | | Re: Key Hole Trapeze System
[Re: Eric Anderson]
#49603 05/19/05 10:33 AM 05/19/05 10:33 AM |
Posts: 1,200 Vancouver, BC | Thanks to the generally positive comments on this systems. I have contacted my local source and he states they are in the process of re-designed the area where the straps go through the plate. Apparenty they have had reports of failures on the plastic units. He said I could purchase from his remaining stock and upgrade it later when the new ones appear (or even trade them in for the Carbon units plus extra $$$). So, I went for it. Went ahead and installed them on my two trap belts...but found the one Gul "Nappy" style belt has a stainless spreader bar sewn in at the lower strap. Will either need to cut & re-stitch or switch to a different belt to get the keyhole unit on there.
Mike.
[Re: samevans]
#49604 05/19/05 10:34 AM 05/19/05 10:34 AM |
Posts: 1,200 Vancouver, BC | Good idea Sam. Now I can have the cake and eat some too  I'm with Mike, I use the 9" long keyhole dogbones for the same reason. I will use the "short ring" if the water is so rough that the waves are hitting me in the bum. For a two-way keyhole system, you could make a ball rig that had a ball at each end with a tie point off-center between them. Here is a page about a quick-release system. http://www.rwo-marine.com/newproducts/main.htmI don't like the idea of using the quick-release and possibly losing the hook during a race. Perhaps a pivoting hook release could work? Also, the standard trapeze system has the line tied to the dogbone and then run through a block or a thimble and then tied to the bungee cord. This causes the line to wear and get nicks. I tie the tail end of the line to the handle and run the bungee through the block and tie it to the dogbone. I haven't been dunked from a broken line since I started doing it this way. Some of the Charlotte sailors even used wire rope, swedged on.
[Re: nesdog]
#49606 06/28/05 01:24 PM 06/28/05 01:24 PM |
Joined: Jun 2004 Posts: 141 Panama City Beach, FL steveh
Posts: 141 Panama City Beach, FL | I'm looking at the key-hole system and the Murray's catalog (p 46) shows three different ball setups; the original key-ball-on-a-wire connector, a "can't miss" ring and a "can't hurt" loop. Catsailor.com lists two and the Bethwaite site shows an additional variation of the key-ball-on-a-wire connector. Looking at the different variations, I have a hard time seeing why one would be considered can't-miss, another can't-hurt and how either could miss or hurt any more or less than the original.  Does anyone have any experience with the different connectors? | | | Re: Key Hole Trapeze System
[Re: brobru]
#49611 12/22/05 04:52 PM 12/22/05 04:52 PM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | Has anyone noticed Jake has hit the 3000 post milestone? Catching up to Tad quickly..... Congratulations Jake.
I'm still on the fence with the Key Hole Ball and socket. Didn't I read that some were being recalled? I would like to know once and for all the number of people who use them and whether they think it is as good, in terms of safety, as it's billed. I haven't heard anyone who uses it say anything bad but........ I'd also like to know once and for all WHY those people who don't use it, don't use it. Is that too much to ask?
Thanks and Merry Christmas to everyone. Especially those who make this all possible, Rick and Mary. Greg
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | |
2,423
guests, and 262
