| Re: Setting up for flying nice solo on a 16
[Re: whoa]
#49669 05/24/05 12:41 PM 05/24/05 12:41 PM |
Posts: 152 Central Texas | The variables... Wind & boat speed are difficult to determin with out tools... Anemometer and GPS can be helpful to make that stuff more measurable. While you will find a couple of GPS's that would work o.k. for cat sailing... measuring true wind speed on a boat is not really possible.
Pointing... Pointing or improving the ability of your cat to point is quiet important. Hobie 16's with asymetric hulls and the lack of lateral surface (daggerboard) perform particularly poorly in that category. Raking the mast back will improve your pointing abilities. Raking the mast back is limited by your cat's main sheet system, the mastbase, and the way the jib is cut. Even with a good amount of mast rake your pointing abilities will be far less than that of a average monohull. From on tack to the other I meassure more like 120* (that angle could be in the range of 90*) Mast rake has some other undesirable side effect... while moving the center of effort further back you cat will pull more towards weather. You can compensate for that with the helm - causing drag. Rudder rake adjustment can be helpful if this is available on your Hobie - the drag remains - just feels better on the helm.
As Jim mentioned befor... it is a trade off - power vs. pointing
Patrick, Hobie 16 '85
[Re: yoh]
#49670 05/25/05 12:20 PM 05/25/05 12:20 PM |
Posts: 35 Hudson Valley | Pointing... Pointing or improving the ability of your cat to point is quiet important.. [color:"blue"]Not to me yoh, I want to go fast, but I am not in a hurry to get anywhere in particular. [/color] Mast rake has some other undesirable side effect... while moving the center of effort further back you cat will pull more towards weather. You can compensate for that with the helm - causing drag. [color:"blue"]Yeah - well that is the same thing as pointing higher so you have to pull on the helm to keep from heading up too much, eh? Thanks for the get back.[/color] | | | Re: Setting up for flying nice solo on a 16
[Re: whoa]
#49671 05/25/05 10:09 PM 05/25/05 10:09 PM |
Posts: 217 West Texas | Pointing... Pointing or improving the ability of your cat to point is quiet important.. [color:"blue"]Not to me yoh, I want to go fast, but I am not in a hurry to get anywhere in particular. [/color] Well yes, but when you want to get back *up* the lake in the evening you might appreciate pointing ability a tad more.  Mast rake has some other undesirable side effect... while moving the center of effort further back you cat will pull more towards weather. You can compensate for that with the helm - causing drag. [color:"blue"]Yeah - well that is the same thing as pointing higher so you have to pull on the helm to keep from heading up too much, eh? Thanks for the get back.[/color] KIND of. There's a difference between the actual ability of the boat to point and the mere tendancy of the physics of the thing to want to go head to wind all the time. One is nice, one is annoying, yet they are closely related.
Warm regards,
Jim
243
guests, and 48
