| Re: twist & shout...
[Re: Steve_Kwiksilver]
#49769 05/24/05 11:02 AM 05/24/05 11:02 AM |
Posts: 2,718 St Petersburg FL | When solo, I cleat the main, play traveller, downhaul is at my feet for easy reach. This caught my attention, maybe my newbie recomendation can do wonders for you. I always rig my lines with figure eight knots, to the trapeze setups. They do not get snagged because they are pretty lengthy. Obviously if the line is withing amrs length, there is no need to crunch to your feet to reach the line. You have it right there in front of you. Have you tried it? Its awesome, no need to reach onto the tramp for anything, everything is a arms reach away. Give it a shot, you may like it. | | | Re: twist & shout...
#49770 05/24/05 11:04 AM 05/24/05 11:04 AM |
Posts: 1,382 Essex, UK | Downhaul is on deck at my feet when trapezing, I play it rather than crew Ah, Steve,Steve, Steve - that's where you're losing out! You'll go faster if you play the crew instead  (Sorry - I just couldn't resist it.....)
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: twist & shout...
#49772 05/24/05 01:20 PM 05/24/05 01:20 PM |
Posts: 9,582 North-West Europe | Steve,
Don't you think you can get some extra pointing with the same speed out of your rig by reducing the downhaul a little and derotating the mast. I assume you are sailing with a flexible alu mast as well.
To much downhaul kills pointing, and to much mastrotation will make the top stand up and may create excessive drag.
[Re: Jalani]
#49776 05/25/05 04:50 AM 05/25/05 04:50 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver OP
Posts: 612 Cape Town, South Africa | "Ah, Steve,Steve, Steve - that's where you're losing out! You'll go faster if you play the crew instead " Hey John, I did that a while back, have an 8 month old daughter to show for it !!  That`s why I sail solo a bit more often now.. Steve | | | Re: twist & shout...
#49777 05/25/05 07:40 AM 05/25/05 07:40 AM | Anonymous
| Anonymous
Unregistered | Hi all,
I used to run vang control to trap handle on Contender dinghy. It was the line I used most. It worked best with bungee on end which didn't stretch longer than you could reach so it reduced slack rope. Problem could be if it will let you back far enough on wire to stand on transom of F16, I didn't stand that far back on trap on Contender. Also found plastic clip on end allowed you to clip it out of way to sidestay when sitting forward in light winds. Will have to look at it for Altered funny the stuff you forget. I will try it for downhaul this is the control I use most.
Interested to hear how much some use control lines. Being singlehanded I try not to use them to much have to keep head out of boat. So far I have sailed Altered the same way I sailed Mossie.
Traveller set close to centre. Downhaul adjusted according to wind seen ahead. Mainsheet played for gusts.
I generaly didn't point much on Mossie used heaps of twist to depower. Which was a combination of downhaul and eased mainsheet. Boat always seemed to go faster with a bit of mainsheet eased, I guess boom was a couple of inches higher than maximum sheet tension not skying. Rarely moved Traveller.
I have continued this on Altered as from talking to A's they mostly now seem to keep traveller centred and play mainsheet.
Regards Gary. | | |
285
guests, and 47
