| Re: Righting Pole on the Hobie 18
[Re: wyatt]
#49962 05/26/05 01:19 AM 05/26/05 01:19 AM |
Joined: Jun 2001 Posts: 217 Palm Harbor, FL, USA Lance
Posts: 217 Palm Harbor, FL, USA | I used to use the righting pole designed by Hobie Gary - the "Solo Right". His design was one that slid into the daggerboard slot. I only had to use it when testing it but it worked very well and never caused any problems to the daggerboard slot, even with my fat a** on it. Gary used to have a video of a 115 pound girl solo-righting a Mystere 20 by herself.
Lance Taipan 5.7 USA 182 Palm Harbor, FL | | | Re: Righting Pole on the Hobie 18
[Re: wyatt]
#49963 05/26/05 05:24 AM 05/26/05 05:24 AM |
Posts: 623 Gulf Coast | http://tinyurl.com/bvyveGo see if this drawing makes sense. If you have trouble, it's at the Yahoo! Beachcats forum, under Files, under 18 Square and Other Esoteric Knowledge, under rightbar.jpeg Nutshell: Drill holes thru the end of the pole, thread a line thru it, and use the line as a hinge, threading the line thru the first couple grommets of your trampoline, or if you don't have centre lacing like me, attach a rudder gudgeon bracket to your crossbar and tie the line thru that. sea ya tami | | | Re: Righting Pole on the Hobie 18
[Re: wyatt]
#49965 05/26/05 08:34 AM 05/26/05 08:34 AM |
Posts: 778 Houston | we can't get used windsurfer poles around here, so those people with interests have to buy the righting pole kit. ` There are alternatives New cheap windsurfer masts (search online) used Masts -try eBay Laminated wood (spruce or fir - I used spruce) fiberglass poles (tools, painting extensions, broken electrical lineman tools etc - try Home Depot) Fiberglass tubes (industrial supply, surplus, eBay) Aluminum tubing( 1 - 1.5" dia 1/8" wall should work) half a Laser mast or other small boat mast drive to the coast Windsurfer masts are called out because they are cheap and everywhere (most places that cats are sailed). I used laminated wood because I already had the materials | | | Re: Righting Pole on the Hobie 18
[Re: wyatt]
#49966 05/26/05 12:52 PM 05/26/05 12:52 PM |
Posts: 284 Norfolk, VA | I used a Hobie 16 boom for the pole and took the boom gooseneck assembly off. I then took a Hobie 18 mast gooseneck and bent the sides in to close it off. I got it so that it would wrap around the dolphin striker and I used two small screws (in the rivet holes) to tighten the sides around the striker pole. That gave me an attachment point and a nice universal for the boom to attach. Pretty slick install.
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
[Re: Dan Berger]
#49967 05/26/05 02:45 PM 05/26/05 02:45 PM |
Posts: 805 Gainesville, FL 32607 USA | Gooseneck? I think you mean the U-shaped block hanger (bail) off a Hobie boom which should be ok fastened around the dolphin striker. I've made several poles and they all worked ok. USE GOOD LINE not some thin stretchy crap. Poles are a lot better than dumping single-handed, then waiting for a passing jetski or well-meaning powerboater who may or may not not hole you. Or the Coasties who are happy to tow your boat back to shore at high speed- upside down and turtled.
| | | Re: Preventing forward motion?
[Re: David Parker]
#49972 05/30/05 12:04 PM 05/30/05 12:04 PM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | Is there anyone who could post some pictures of the righting pole hinge as it attaches to the main beam? I've been brainstorming some ideas of how to attach a righting pole to my Nacra 5.2 (solid tramp up front/no lacing, no grommets). -Rob Rob V.
Nacra 5.2
Panama City | | | Re: Preventing forward motion?
[Re: Redtwin]
#49974 06/02/05 03:57 PM 06/02/05 03:57 PM |
Posts: 307 maui | Hello, i made a righting bar for a TheMightyHobie18. i use my legs to keep the bar from swingging fore and aft. there is 5' or of line tied to the end of the bar which i tie to the shroud adjuster or even better to a loop i have where the dagger board bungie attaches forward of the main beam. the "hinge" was told to me by a friend at the miami yacht club. a short piece of line tied in a square knot. i tie mine around the dolphin spike, then loop some bugie around the bar and thru the tramp lacing to keep it out of the water. first i tried just drilling a hole in a winsurfer mast tip at each end. that looked like it was cracking so i filled each end with highdensity foam plugs and wrapped the outside w/a strip of glass and epoxy at each end. i used the bar twice successfully. the rest of the time no capsize. this all may seem too easy but it works for me. even solo. ![[Linked Image]](http://jollyrodgers.net/images/bar_hinge.jpg) | | | Re: Preventing forward motion?
[Re: gjoyce56]
#49976 06/02/05 08:05 PM 06/02/05 08:05 PM |
Posts: 12,310 South Carolina | The universal should attach to the bottom of the front beam ... somewhere.
Jake Kohl | | | Re: Preventing forward motion?
[Re: gjoyce56]
#49977 06/03/05 01:40 AM 06/03/05 01:40 AM |
Posts: 217 Palm Harbor, FL, USA | Maybe I'm just dense ... I have the universal kit and was going to send it back to Murray's 'cause I don't see how it's gonna fit on the forward bar with the dolphin striker ... without going through the tramp which doesn't seem wise. I even have windsurfer masts for the damn thing, but now I'm thinking of going with a bungee/Hawaiian set up or whatever system.
I'm a newbie, have an 18, will be soloing ...
Where is the universal getting hooked up? Or - as in the pics - can I just tie the mast/pole to the striker?
gary The Hawaiian System will not give you enough leverage to right the TheMightyHobie18 by yourself. The whole reason for the righting pole is to let you walk out or hang on it to get additional leverage that you can't get hanging offof the hull. The universal kit should have a Universal joint piece that attaches to the bottom of the front beam crossbar. The U-joint will allow the pole to pivot out sideways to be used for righting, with a stopper line to hold the pole at the proper angle. I believe the U-joint piece is supposed to be rivetted to the beam. Rick's Power pole in action & installation instructions
Lance Taipan 5.7 USA 182 Palm Harbor, FL | | | Re: Preventing forward motion?
[Re: jollyrodgers]
#49980 06/04/05 09:36 PM 06/04/05 09:36 PM |
Posts: 805 Gainesville, FL 32607 USA | JollyRoger has it right- Metal is ok but simple is best, just tie the pole high as possible on the dolphin striker. It will work great: Check it out at the beach to get your lines and stopper knots the right length.
2,475
guests, and 285
