| SEA-CAT 34, a French-built aluminum catamaran? #49999 05/27/05 06:06 AM 05/27/05 06:06 AM |
Posts: 2 North Carolina | My wife and I are considering the purchase of a cruising catamaran sometime in the next five years. In my research, I found a SEA-CAT 34 for sale. The Builder/Designer is listed as: MATONNAT, ARCACHON, FRANCEMICHEL LAURAT (said to be French-built)
I am intrigued about a sailing catamaran of this size with an aluminum hull. Unless I am mistaken, this seems to be somewhat rare. Unfortunately, I am not able to find any additional information about the Sea-Cat 34.
Does anyone know where I might learn more about this boat, in particular, or about other cruising catamarans (<40' LOA) with aluminum hulls?
Any assistance you can provide would be greatly appreciated.
Sincerely, Doug
Doug & Sheryl
| | | Re: SEA-CAT 34, a French-built aluminum catamaran?
[Re: RickWhite]
#50001 05/27/05 08:34 AM 05/27/05 08:34 AM |
Posts: 2 North Carolina | That is the site where I found the listing for the boat. I appreciate your opinion that it may be a good deal.
I am hoping to view the boat next weekend. Do you have any suggestions (or suggested reading references) regarding things to look for or questions to ask?
[Please note that I am a novice sailor and eventually-hope-to-be first time boat owner]
Thanks, Doug
Doug & Sheryl
[Re: SailingRelic]
#50008 04/26/06 06:34 PM 04/26/06 06:34 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | I don't think that Sizzler catamarans have anything to do with aluminum construction for big boats. It's not a valid comparison. Sizzlers probably "rotted out" because of electrolysis between the aluminum and the stainless "O" ring around the joining of the two halves of the hulls. After 20 years, I'm sure the rubber barrier between the two metals disintegrated. Here is one web site I found with some information about aluminum boats. http://kastenmarine.com/aluminum.htmOne thing I have always wondered about with metal boats, though, is how they react with lightning. I mean, the whole boat is basically grounded; right? So you don't need to put in a grounding device; right? But is the boat more likely to ATTRACT lightning because the whole boat is metal and grounded to the water? | | | Re: SEA-CAT 34, a French-built aluminum catamaran?
[Re: Ashiya]
#50009 01/12/07 08:59 AM 01/12/07 08:59 AM | Anonymous
| Anonymous
Unregistered | One of the great thing about French designs is the interior accomodations. In the more exotic ports it is not at all uncommon to see a 24 ft cruiser pull in flying the French flag. As the crew starts to emerge you can count 3...4...5...
Regards Chet | | |
244
guests, and 63
