| Re: leaking hull repair
[Re: aaronhoy]
#51242 06/20/05 01:19 PM 06/20/05 01:19 PM |
Joined: Apr 2005 Posts: 292 Ontario, Canada Captain_Dave
Posts: 292 Ontario, Canada | Aaronhoy, Look a few posts down for "Hull Condition". I posted a detailed step-by-step on how to fix this very problem. As for the chopped glass,yes find some and mix it into the resin to fill some of the voids. However, this should not be your first step, nor should you neglect to use some fiberglass cloth in your repair. As for the resin controversy, go with epoxy for sure. This will (by far) adhere the best to the damaged area. For this job, polyester resin is simply a poor choice. See the post as I suggested. If you have any other questions email me at dpcarey@golden.net and I will help you out. In the mean-time,dry those hulls out and keep the rain off of them until the repair is done. Dave | | | Re: leaking hull repair
[Re: aaronhoy]
#51244 06/20/05 04:03 PM 06/20/05 04:03 PM |
Posts: 292 Ontario, Canada | There are some products available with glass fibers already mixed in. However, I have always prefered buying the chopped (usually called "milled", not "chopped") fiberglass separately and mixing it with the resin of my choice. That way you can completely control the viscosity of your mixed product. This is important for different applications at different temperatures. Also, and perhaps most important, the pre-mixed stuff that I have seen has been mixed with polyester or vinylester resin. And although I generally like the vinylester resins, I do not like polyester for structural repairs. For structural repair, epoxy is the best way to go. Vinylester is nice for smaller stuff (chips, dents, dings and scratches) especially if you are on a tight budget. Also, the chopped (milled) glass, when mixed thick with resin, can be a little difficult to work with and doesn`t always settle out smoothly. You would find it easier to use fumed silica or microballoons as your additive to the resin for filling voids. Then use straight resin and glass cloth to build up your repair.
Dave
[Re: newbiesailor]
#51246 06/22/05 08:27 AM 06/22/05 08:27 AM |
Joined: Jun 2005 Posts: 90 Saint Simons Island, GA aaronhoy OP
Posts: 90 Saint Simons Island, GA | I dont know that much about fixing the bottoms of the hulls, thats why I posted this thread. (although I think i finally figured out everything I need to do, thanks a lot guys) But anyway, as far as other leaks, as has been mentioned in other threads one good way is to cover the hull in soapy water and run air in through the drainplug. I actually took an old drainplug and attatched a valve to it so I can hook it up to an air source. If the hull leaks then you shuoldn't run a danger of putting too much pressure in it, but keep an eye on the pressure anyway just to be safe. The places where the soapy water bubbles are the leaks. Suspected places are the bottoms of the hulls, the drainplug seals, the rudder assembly attatchments, the deck/hull joint, and the points where the 4 posts that support the frame go into the hulls. Supposedly once you get everything sealed right the hull will actually hold a little bit of pressure and you will hear a pressure gradient equalizing everytime you take out the drainplugs after sailing. My hulls have never been that well sealed though, so maybe you should get more advice from some of the mose experienced people here. | | | Re: leaking hull repair
[Re: aaronhoy]
#51253 06/23/05 09:06 AM 06/23/05 09:06 AM |
Posts: 292 Ontario, Canada | Aaronhoy, I am a little uncertain regarding this part of your question: "if your hull was so well sealed that pressure was equalizing then it would never take on enough water for this to be an issue". But, since I have the time today, I will try and cover all the obvious angles on this. With regard to a perfectly sealed hull being unable to take on any water, I would have to say you are perfectly correct. However, as ambient temperatures rise and fall and the internal temperature of your hulls change, you can expect significant changes with the internal pressures of the hulls as well. These could be greatly enhanced or inhibited by the effects of cool water or the radiant effects hot sunshine. Those experiencing the aforementioned "swoosh" are subject to this situation. Although I cannot comment on the particular strength of the H16, I can say this could be very bad. It certainly could accelerate a delamination process (especially in a cored layup construction) and possibly even crack open a hull. The concern over a "perfectly sealed" hull then becomes an issue of damage from pressure as opposed to water. I believe the Hobie techs could address this much better than I can, but it seems pretty straight forward to me. If the architechs and builders of the hull wanted it truly air-tight, they could have done it in the factory with relative ease. The real trick appears to be how does one significantly minimize water accumulation while maintaining good pressure equalization...again, not a tough thing to do. This is even easier than creating an air-tight hull. But, sealing the pylons (vents) would not be a good idea at all - in my opinion. If you are trying to find some special point where the hulls just barely leak air (equalize) yet somehow completely inhibit water intrusion, I would have to say it is not a realistic goal. The best you can hope for is to plug all leak points on the fiberglass hull itself and be sure that the foam plugs in the pylon are in good firm condition so that they cannot simply act as funnels for water to enter the hulls. Dave
[Re: newbiesailor]
#51254 06/23/05 09:44 AM 06/23/05 09:44 AM |
Joined: Mar 2005 Posts: 66 Durban, KwaZulu-Natal, South A... Clint_SA
Posts: 66 Durban, KwaZulu-Natal, South A... | I recently found some small air leaks by presurising the hull. All it took were 5 or so large breaths blown into the bung holes. This also allows one to hear the fine pitched sound of air leaking as you build up the pressure. It's probably easier too...
Dubulamanzi
[Re: Clint_SA]
#51255 06/23/05 10:11 AM 06/23/05 10:11 AM |
Posts: 292 Ontario, Canada | Clint,
Nice low tech approach! Always worth a try! However, I am surprised by some of the difficulties people are experienceing here. The leak points should be relatively easy to find if you know where to look.
As I have been thinking about it, I have a suspicion some of these mystery leaks MAY be occurring below the waterline at the sites of previous repairs. If sailors are not using the proper process or materials in their patch work, then leaks may still occur. This is why I have repeatedly posted that simply slapping on some type of filler, or cloth and resin, may not do the trick (at least not for very long) on anything but the smallest repairs. I also think some might be omitting a proper cleaning process and/or an initial sealer application of thin resin (without fillers). Only after these steps can resin fillers and/or lamination be applied with any confidence.
If one does not follow these steps, it almost guarantees eventual seepage through previous repairs - especially along an edge like the bottom of the Hobie hull.
People who work with fiberglass understand these particular issues well - it goes with the territory. For everyone else, it is a matter of finding (and trusting) good information.
Dave
1 registered members (FredL),
2,799
guests, and 283
