| Re: Why no Wings on F16's?
[Re: Tony_F18]
#51593 07/04/05 05:49 PM 07/04/05 05:49 PM |
I don't think adding wings to an F16 will encounter any limits in the way of load or stresses. Especially not if they are secured directly to the beams.
I think the bets option would be to just copy the FX-one wings. These seem light weight and sufficient.
Personally I'm not very much interested in wings but I would love to see some-one give it a try.
[Re: rbj]
#51594 07/04/05 05:53 PM 07/04/05 05:53 PM |
Posts: 9,582 North-West Europe | My main question remains unanswered - will singlehanding with wings stress the hulls/structure less than doublehanding without them?
I will never give any garantees without running all the numbers on such an additions in detail. Besides the original builders of these boats will undoubtably have something so say about this and warranty. But Having said that, if I were to add wings to my own boat (hypothetical situation) then I would probably not even bother doing to math on what my beams and hulls would take and only do the math on the design of the beams itself. If you catch my drift here. Wouter
[Re: rbj]
#51597 07/06/05 06:34 PM 07/06/05 06:34 PM |
Posts: 465 Oxford, UK | Jerry,
You're right to be cautious, but you should be fine if only used for single handing. The thing to worry about is the rig, rather than the hulls or beams - assuming you can find some decent way to attach the wings to the beams.
Wings have the ability to increase your righting moment. The maximum force in the rig is limited by the fact that as the power increases, the moment of the rig will become equal to your righting moment, and the boat will start to tip over. The more you increase the right moment, either by becoming heavier, or by moving further away from the leeward hull, the greater the force in the rig before it starts to heel.
On the back of an envelope: when on the trapeze on an F16, your centre of gravity is about 11 foot from the leeward hull. Add a 1 foot wing and trapeze off it, and you'll increase your moment by less than 10%. Put a crew on the trapeze with you without wings, and you'll increase your moment by 100% - so I think you should be safe in 1-up mode.
Failure to do these calculations can be expensive, though - I've seen the remains of a Hobie Pacific mast after it was taken out 3-up in a force 6.
Paul | | | Righting moment calcs
[Re: rbj]
#51598 07/07/05 05:35 AM 07/07/05 05:35 AM |
A good rule of thumb for righting moment is :
Righting moment RM = 0.5 * boat width * boat weight + (boat width + 1) * crew weight
The formula uses SI units, so meters and kilograms, if you want to do it with feet and pounds then replace (boat width +1) by (boat width + 3) (this a rough approximation)
The results are :
F16 sloop two-up with 150 kg crew
RM = 0.5 * 2.5 * 107 + (2.5 + 1) * 150 kg = 133.75 + 525 = 658,75 = say 659 kgm
F16 sloop two-up with 150 kg crew and 1 foot wings (=0.3 mtr by 5 kg each)
RM = 0.5 * 2.5 * 117 + (2.5 + 1.3) * 150 kg = 146.25 + 570 = 716,25 = say 716 kgm = 8.6 % more than standard F16
Is comparable in righting moment to putting a 166 kg crew on the wire of a wingless F16
RM = 0.5 * 2.5 * 107 + (2.5 + 1) * 166kg = 133.75 + 582.5 = 716,25 = say 716 kgm = 8.6 % more than standard F16
F16 uni one-up with 80 kg crew
RM = 0.5 * 2.5 * 104 + (2.5 + 1) * 80 kg = 130 + 280 = 410 = 37 % Less than standard sloop 2-up F16
F16 uni one-up with 80 kg crew and 1 foot wings (0.3 kg by 5 kg each)
RM = 0.5 * 2.5 * 114 + (2.5 + 1.3) * 80 kg = 142.5 + 304 = 446.5 = say 447 kgm = 32 % Less than standard sloop 2-up F16 and 9 % more than standard 1-up.
Don't make out too much aof 10 % higher rigting moments in the way of performance enhancements.
A good rule of thumb giving the UPPER limit to windward leeward gains is :
0.5 * (Sq.rt (new sail drive) - 1)
so
0.5 * (Sq.rt (110%) - 1) = 0.5 * (sq.rt (1.1) - 1) = 2.4 % or about 90 seconds per hour when doing everything else just right.
This is an upper boundery as increases in overall weight, windage and the fact that the relationship is "stronger" than a sq.rt take away from the gains.
Typically I use a power relationship of 1/2.5 instead of of the normal sq.rt that is a powerrelationship of only 1/2
So
0.5 * (110%)^(1/2.5) - 1) = 0.5 (1.1)^(1/2.5) - 1) = 1.9 % = 70 seconds per hour bouy racing when doing everything else just right.
This number I would use as a relatively accuracte estimations of the performance gain IN HIGH WINDS only ! Of course in all conditions where normal trapping of sitting on the luff hull is sufficient the winged catamaran will have no advantage at all, rather it is expected to be disadvantaged.
668
guests, and 112
