| Re: Hobie 17 shroud adjuster settings
[Re: rbj]
#51815 06/28/05 02:20 PM 06/28/05 02:20 PM |
Posts: 12,310 South Carolina | As you change the load on your rudders, you also change, ever so slightly, the angle of attack of the daggerboards and hulls through the water. The proper angle of attack of the daggerboards will help generate proper lift to windward with minimal drag. With the proper amount of pressure applied to the underwater foils, leeway will be virtually eliminated allowing the hulls to track straight, and more efficiently, through the water.
In addition, a swept back wing profile is more efficient through the wind providing less forward drag...hence raking the mast back works a little better for speed but at the expense of a little power. A straighter wing profile will provide better lift (more power) so less rake is better for lighter airs.
Jake Kohl | | | Re: Hobie 17 shroud adjuster settings
[Re: rbj]
#51817 06/29/05 01:29 PM 06/29/05 01:29 PM |
Posts: 12,310 South Carolina | Yes - we change our rake for different expected wind strengths. We don't generally do much with the rudders because, at least in my case, my rudders are so neutrally balanced that the rake really doesn't affect them - I pretty much have no helm (but am working to put a little weather helm back in it). Even if I feel more or less helm, it has very little affect on boat performance so we don't mess with the rudder rake all that often.
[Re: DanWard]
#51819 06/29/05 07:51 PM 06/29/05 07:51 PM |
Posts: 122 | Remember that a well designed sloop rig boat will push the stern toward the lee side anytime the boat is tuned to sail on an 'even keel', that is with a minimal mismatch between the center of lift of the sail rig, and the center of lateral resistance determined by the hull's and/or daggerboard's centers of lateral resistance. Since a little weather helm is generally regarded as a good thing, it is intentionally designed into the boat by the placement of the daggers/max hull draft, etc. in conjunction with the sailplan.
Unbalanced rudderrs (rudders with the pivoting axis in front of the rudder's center of lift) have the ability to feedback the amount of lift they create back through the tiller; the greater lift they create (the angle of deflection) the greater the push on the tiller. This type of rudder will always self adjust to the angle of least resistance when the tiller is released. Since the boat naturally wants to steer to weather when correctly trimmed the unbalanced rudders give you the feel of weather helm. Virtually all beach cats have unbalanced rudders.
Note that the conditions which causes weather helm have nothing to do with rudders at all; it's just that unbalanced rudders allow you to feel it. This is not necesarily a bad thing because the feel of the helm can be regarded as a tuning tool allowing the skipper to adjust the center of lift of the sailpan (traveler position/cunningham tension) until the helm is light. The boat sails faster when the rudders are not fighting the daggers. This is sailing on an 'even keel'
You could adjust the rudder overhang to make the rudders more balanced, and this will reduce the sensation of weather helm, but the forces acting on the hulls and rig are still present, and you still need the same rudder deflection angle to overcome these forces and steer your intended course. With balanced rudders it just takes less muscle power to do so.
Anything you do which moves the center of lift of the sailplan aft will cause or increase weather helm. Loose downhaul tension increases the sail draft and moves the point of max draft aft, thereby moving the center of lift aft. The opposite is true for increased downhaul tension. Centering the traveler moves the cener of lift aft while traveling out moves it forward. Rear mast rake moves it aft also, so rear mast rake definitely will increase weather helm. Despite this, some boats will sail faster with pronounced aft mast rake despite the increased drag caused by the increased rudder deflection. This has to do with lowering the center of lift thereby reducing heel angle, among other things.
So if you have a 'stock' boat with excessive weather helm, don't immediately look to modify the boat to correct this. Check for the factory settings first and if they are OK, try to move the center of lift forward (traveler position, proper downhaul tension, mast rake) and then go from there.
I'm not trying to be too technical here, just want everybody to understand what's really happening.
Jimbo | | | Re: Hobie 17 shroud adjuster settings
[Re: Jimbo]
#51820 06/29/05 09:53 PM 06/29/05 09:53 PM |
Posts: 12,310 South Carolina | The boat sails faster when the rudders are not fighting the daggers. It's probably not much more than terminology but you do actually want the rudders to fight the daggerboards ever-so-slightly. This gives the daggerboards a slight angle of attack resulting in lift to windward countering the side drift introduced by the sail force ... it's all semantics really though.
[Re: Rolf_Nilsen]
#51822 06/30/05 06:52 AM 06/30/05 06:52 AM |
Posts: 12,310 South Carolina | I haven't been changing the spreader rake and/or diamond wire tension very often but only because Chris has been sailing with me steadily - our crew weight has remained consistent. With regards to the spreader rake, my feeling is that once it is setup to match the shape and reaction of the sail, it shouldn't be changed. I expect that the spreader rake specifications should come from the sailmaker. Diamond wire tension, however, helps to control the initial power setting (and keep the mast from inverting with the chute up!). So I would expect to make minor changes to this somewhat with changes in crew weight and wind/water conditions.
Having sailed in a pretty tight and reasonably populated F18 class for the last year, I have had opportunity to witness how important mast rake is. I've ended up without enough mast rake in some of the windier regattas and suffered pretty dramatically. Pointing ability suffered as did our speed because we were pretty overpowered (in some cases we probably we did not have enough downhaul cranked). Because we are a heavier team, my thought was to stand our rig up a little more than everyone else - but that has not proven successful.
#51823 06/30/05 07:17 AM 06/30/05 07:17 AM |
Posts: 4,451 West coast of Norway | Thanks for answering Jake, good to know what you think. I am with you on the spreader angle and diamond tension, but I think it's important to get it right for your crew weight. Heavier teams need more power (less angle and tension), and I guess having them out on trapeze helps bending the mast a little bit. We are talking small differences here, but still a difference (we still have a alu mast, and they also differ a bit in stiffness, so the sailmakers numbers aren't neccesarily the best, even we amateurs have figured that out  ) We also tried raking the rig less, to gain power, with the result that we lost windward ability. Now we sail with one rake in all conditions, and are pretty pleased with it. If you sail with your 'high-wind' rake setting in a light wind race, do you get killed off due to lack of power? I am just trying to find out how important adjusting mast-rake to the conditions really is on a high-performance cat, as we have more or less found a setting we are pleased with. Ricks book discusses it, but my own experience or rather lack of experience perhaps, is that once it's dialled in, adjustments aren't really needed. | | | Re: Hobie 17 shroud adjuster settings
[Re: Rolf_Nilsen]
#51824 06/30/05 07:32 AM 06/30/05 07:32 AM |
Posts: 12,310 South Carolina | We have yet to experiment much with light wind...usually, around here, when it's light it's also very spotty so it's difficult to determine whether or not you got better breeze or had a better setup. In the next couple of weeks we are planning a small two or three boat tuning session to experiement first on settings like mast rake and diamond wire tension that are difficult to set on the water. It should be interesting because we will probably have at least one Hobie F18 tuning with a Nacra or two.
[Re: rbj]
#51828 06/30/05 09:00 PM 06/30/05 09:00 PM |
Posts: 122 |
Jimbo - are you saying you don't think I should re-rake the rudders, even if the mast rake gives promiment weather helm? Beside the needed muscle power I really don't like significant weather helm, especially on a singlehander, since if you drop the tiller you're in irons before you know it and it make tacking tricker.
The recommended facory setting for the shouds (rake) is 4th hole from the top all the way around. I'm on 7th hole from the top (I assume my shrouds are just long) now with only mild weather helm but the prior guy who raced had it raked way back from that setting.
Remeber this is a unirig - I get the feeling that raking the mast on a unirig has a greater effect on weather helm than sloop rigged boats.
Thanks,
Jerry
Jerry, It's going to come down to an evaluation of just what you are getting out of all that mast rake. Some boats point significanyly higher with pronounced aft mast rake. Also, some boats heel less since the center of effort of the sailplan is lower. This may make the boat faster generally. I know that the mast rake mod works well for the H16, and there may be other boats where it is applicable as well. But it is not likely universally applicable. I'm not knowledgable about the H17 so can't comment on the applicability of this mod to that boat. If you race around buoys these sorts of mods do make sense, since they help you win and you are not fighting the helm all that long. But if you do mostly distances races or usually just like to cruise around, then that prominent weather helm has got to be fatiguing. Fatigue loses distance races. If you decide to keep the rake, then it does make sense to mitigate the weather helm as best you can with rudder balance. Don't expect miracles here; the rudders will still be unbalanced rudders, just a little bit less unbalanced. This whole dilemna might be just the thing you need to help you decide to add a jib  No more getting stuck in the irons, either. And sloops definitely point higher than unas. Jimbo | | |
3,137
guests, and 249
