| Re: Another "re-learning" expereince
[Re: grob]
#51919 06/29/05 07:46 PM 06/29/05 07:46 PM |
Posts: 915 Dublin, Ireland | [quote Why not just drop the whole rig, mast, sails etc, wait for the storm to pass, then rerig the boat and sail home. [/quote] You guys are no fun, someone was supposed to say "how do you put the mast up while out at sea" then I get say "its easy with a rig like this" and post this... Our rig actually came down last weekend due to operator incompetence on my part, we were about a mile out and did indeed manage to put it all back up and sail home. Gareth www.fourhulls.com [/quote] Gareth, Is this you project finally complete ? I cannot see the hulls - the photo is too dark ? And your site has not been updated  Dermot.
Dermot Catapult 265
[Re: Dermot]
#51920 06/30/05 09:02 AM 06/30/05 09:02 AM |
Posts: 545 Brighton, UK | Hi Dermot, It is certainly getting closer to completion, I think there is still alot of work to do though, we are pleased with the way it sails, it could do with being a bit faster, we have quite small sails at present 2x 7m, we are going to upgrade to 2x 10.3m thats 220 sqft. I don't have any really good pics of the hulls, but attached are a couple more, I can't seem to get the black hulls to photograph very well! I will endevour to update the website this weekend. All the best Gareth | | | Re: Another "re-learning" expereince
[Re: grob]
#51923 06/30/05 10:08 AM 06/30/05 10:08 AM |
Posts: 1,382 Essex, UK | OK Gareth, I give up... Where do you sit? How do you hike out/trapeze? Oh, I get it - it's for pygmies!!!
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Another "re-learning" expereince
[Re: grob]
#51924 06/30/05 10:20 AM 06/30/05 10:20 AM |
Posts: 915 Dublin, Ireland | Hi Gareth, That's great. That rig looks really classy. I look forward to seeing the sailing shots. Seeing that rig reminds me of the question that people with windsurfing background always ask me: With all the new technology around, why do catsailors still fasten their battens with bits of string  Do windsurfing type adjusters really add that much more weight ? The ones in the photos look very streamlined. Having asked this question, I have to say that I know nothing about the technicality of windsurfer rigs. Wouter - Only one paragraph  See ya, Dermot.
Dermot Catapult 265
[Re: grob]
#51925 06/30/05 10:43 AM 06/30/05 10:43 AM |
Posts: 1,382 Essex, UK | How much does the whole piece of kit weigh, Gareth? How have your trials gone? As you've apparently done such a great job of making a radical piece of thinking into a reality, how about a thread dedicated to discussing your progress - I for one would be really interested and I'm sure others on here would be keen to know more too!
[Re: Dermot]
#51926 06/30/05 02:09 PM 06/30/05 02:09 PM |
Posts: 915 Dublin, Ireland | Seeing that rig reminds me of the question that people with windsurfing background always ask me: With all the new technology around, why do catsailors still fasten their battens with bits of string  Do windsurfing type adjusters really add that much more weight ? No, and the windsurfing rigs are really nice, high tech and cheap, Our rig has camber inducers and an allan key to adjust the batten tension. So, why are we not using camber inducers on cats  Dermot.
Dermot Catapult 265
[Re: BobG]
#51929 06/30/05 05:28 PM 06/30/05 05:28 PM |
Posts: 915 Dublin, Ireland | Ah 4keel drive! Sorry could'nt resist . Now that is funny  (Or is it just that I have had 4 glasses of wine  )
Dermot Catapult 265
[Re: Jalani]
#51931 07/01/05 09:40 AM 07/01/05 09:40 AM |
Posts: 24 Milwaukee, WI | Morning Folks:
Keep in mind that I sail on the very cold Great Lakes, and frequently sail solo.
In terms of the "Rambo PFD" I carry: 'waterproof' VHS radio--which is really only water resistant (kept in an actual water proof bag); a three pack of small 'waterproof' Skyblazer flares--each flare contains its own launcher---packed in a double Ziploc; on the outside front of my PFD attached to the PFD's built in lash point a short, blunt tip scuba knife---which also has a hand lanyard; in various pockets: a signaling mirror and an emergency safety whistle; a stainless steel multi-tool; and a laser flare (which is attached to an automatic retractor leash). At the rear of my PFD, I have a battery operated strobe light attached to the PFD's built in lash point. If you have never looked into the laser flare concept, I strongly encourage you to do so. The laser flare is visible over long distances...can be seen both in day or night...and they run for time periods from 15 to 72 hours. According to some sources the laser flare is 8,000 times brighter than a flashlight at 1,000 feet and effective up to 20 miles away, day or night. The medium size version of the laser flare is small enough to put inside your PFD. Regular cost for the laser flare is around $100; however, right now the National Geographic has laser flares on sale. The Rescue Laser Flare that uses 2 N cells is on sale for $54.95 instead of the normal $99.95.
In terms of sea anchors, in my humble opinion they are too expensive and oversized for beachcats. Instead I carry two different sized Drogues (the smaller one goes on my H-16, the larger goes on my H-18) depending upon the boat and/or weather conditions. The smaller drogue I bought from Boat US for around $40. The larger drogue was made by one of my friends who is handy with a commercial sewing machine. In terms of using the drogues (material cost around $50), it is extremely important to make sure that you use nylon line: at least 25% of the load will be captured by the rode alone. Second you must construct a bridle to handle the heavy load---I am not sure how long a dolphin striker would hold up. Third, be sure to allow yourself plenty of rode...the longer the rode the less violent will be the shocks you and the boat experience. Lastly, YOU ABSOLUTELY MUST HAVE A FITTING BETWEEN THE RODE AND THE DROGUE WHICH WILL ALLOW THE DROGUE TO SPIN. In a couple of boat experiments I tried, when the drogue does not have the ability to spin around, it simply kinks up the line until the drogue will not effective catch water any more.
In order to carry my drogue and other safety equipment(flares, paddle, drogue bridle/rode, waterproof light, etc.) which I keep handy on my H-16 boat tramp, when I had my new bias-cut one piece mesh tramp made...I also had them install a mesh "Safety Pod" (Paul's nomenclature) on the bottom of the tramp. I designed the "Safety Pod" to be accessible (via zippered openings) from both the top and the bottom of the boat. The Pod allows me to have a single place to store all of my safety stuff, let's me immediately see if I have forgotten to put anything into it, before I leave the launch area; and keeps me from having to open one or both of my hull ports (which just might be underwater at the time) to facilitate any self-rescue efforts. The "Safety Pod" was not inexpensive to add to the tramp, but if you have ever experienced a situation where you need to use your safety equipment "Right Now" (Been there, done that...way too many times) you may find the investment to install a "Safety Pod" to be a real life saver.
If you would like to see pictures of any of this stuff, let me know and I can post some digital pix.
I would rather be sailing, than reading about sailing!
[Re: rbj]
#51933 07/01/05 10:14 PM 07/01/05 10:14 PM |
Posts: 24 Milwaukee, WI | Evening Jerry:
Yes the laser flare is on sale at the National Geographic site. Last time I checked they still had them on sale.
I will upload pix of all the gear sometime tommorow. Once you see the pictures, if you have any questions, drop me a line.
Good Holiday Sailing!
Paul Milwaukee, WI
[Re: OldSalt]
#51934 07/02/05 03:31 AM 07/02/05 03:31 AM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | What is the difference between a sea anchor and a drogue? I'm just curious, because I have never quite understood it. I am thinking that a drogue is something you drag behind your boat when you are running away from the wind and that a sea anchor is deployed from the bow when you are facing into the wind and just drifting backward.
Is that correct? And what is the difference in how they are constructed and what they look like?
1 registered members (basket.case),
483
guests, and 25
