| Re: Pete Melvin Wins the A-CLass Worlds
[Re: Wouter]
#51982 06/30/05 10:07 AM 06/30/05 10:07 AM |
Posts: 12,310 South Carolina | You're right with regard to the canted hulls - there is nothing that says they're not allowed. However, the rule was changed with regard to the daggerboards specifying that they must remain in the vertical plane of the hulls. B.1.4. DAGGERBOARDS AND RUDDERS The platform shall be equipped with a pair of rudders and, if fitted, a pair of daggerboard or centerboards. The dagger board boxes and the rudders have to be in the vertical plan of the hulls. The daggerboard or centerboards and rudders may be made using epoxy resin. Carbon may be used for the construction of daggerboard, centerboards or rudder blades. All underwater appendages must be symmetrical. EDIT: sorry - I should have mentioned that this is from the F18 rule set.
Jake Kohl | | | Re: Pete Melvin Wins the A-CLass Worlds
#51983 06/30/05 02:14 PM 06/30/05 02:14 PM |
Joined: Jul 2003 Posts: 29 Netherlands Marc Woudenberg
Posts: 29 Netherlands | The amount of angle on an A-Class daggerboard is only limited to the maximum platform width that must include the boards fitted in their pockets with the tip flush with underside of the hull. Due the slender hulls, there is not much more room than about 5 degrees angle. As a matter of fact the boards of AHPC newest boats were made by Peter Saarberg and were within 1 mm from the maximum platform width upon measurement. Luckily a piece of the top part on the outside on both boards broke off by accident to keep it well within the class legal width limit, such a lenghth those boards are now. In the boat area one could see that the tendence for dagger boards is defitely longer and narrower with a 1:10 w/l ratio.
Marc Woudenberg T49/F16 Ned302
[Re: Hans_Ned_111]
#51986 08/09/05 08:41 PM 08/09/05 08:41 PM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett
Posts: 1,012 South Australia | Any A class is capable of out pointing an F18 or an F20 (with advantage -VMG) by more than a "few" degrees simply by its hull shape, rig configuration, weight (or lack there of) etc, etc, regardless of the centre boards being canted or otherwise? So a comparison to these other classes cannot really be taken as any sort of “conclusive” result? The only comparison would be A class to A class, - one with and one without (canted boards). Hydrofoils by the way are of an asymmetrical profile generating lift only in one direction, due to their shape and their movement through the water, the centre/dagger boards referred to as “cantered or not cantered” are of a symmetrical profile that will generate lift on either side of the foil, depending on their angle of attack relative to their direction through the water. | | | Re: Pete Melvin Wins the A-CLass Worlds
[Re: Darryl_Barrett]
#51987 08/10/05 05:38 PM 08/10/05 05:38 PM |
Posts: 1,307 Asuncion, Paraguay | Hydrofoils by the way are of an asymmetrical profile generating lift only in one direction... This is a common mistake. If this was correct, airplanes with asymetrical section wings wouldn't be able to fly upside down - and they can. The appendage being symetrical or asymetrical is not the real issue. What your statement neglected is the angle of attack. Given enough angle of attack, a canted symetrical daggerboard may lift a boat out of the water (although not as efficiently as an asymetrical daggerboard) - so it behaves like a hydrofoil. Conversely, a non-canted asymetrical foil generates only lateral lift to both sides (although not as efficiently as a symetrical foil) - so it is not a hydrofoil. It does not provide vertical lift until the boat heels. Conclusion: the rules need a better definition of "hydrofoil". But a proper definition is quite a challenge because with a bow up atitude, a "plain vanila" vertical symetric daggerboard will provide vertical lift as the boat heels. And the hulls as well, even without heeling! How do the A class rules define "hydrofoil"?
Luiz
[Re: Luiz]
#51988 08/10/05 11:37 PM 08/10/05 11:37 PM |
Posts: 1,012 South Australia | Hey Luiz, what you have said is actually the same as I wrote? but with added examples. I never said that hydrofoils would not generate lift on either side under the (extreme) conditions you give, such as aircraft wings which, when the plane is inverted the angle of attack of the foil is increased to such a degree that lift can be generated on their “flatter” side more than the lift on the curved surface and in so doing the aircraft can remain flying etc, but there is a great penalty in drag incurred to do so. Symmetrical foils, as I said generate lift on either side of the foil depending on their angle of attack to their inclination to the direction they are travelling through the water. Rudders are symmetrical foils and obviously generate lift on one side as well as the other whenever their angle of attack to their direction through the water is altered, and therefore, they then turn the craft in the desired direction. What I was offering, principally, is the well established, defined fundamental, difference between the main functions of a hydrofoil and a (symmetrical) foil, (which is not considered to be a hydrofoil even though a symmetrical foil, as I said, can be used to generate lift equally in two desired directions) When a hydrofoil is used on water borne craft, the foil is generally in a fixed attitude to the longitudinal length of the boat and the, profile shape lift that it generates is always “upwards” at (or about) 90 degrees to the waterline of that boat. This is due solely from the asymmetrical shape of that foil This is the same for most aircraft, and in the instance you give of a plane, the tailplane elevators and the Aerolone on the wings alter the “angle of attack” to the wind direction passing over both the wing and the tail plane. In the case of the asymmetrical shape of the wing, the Aerolone will actually go a long way to altering the “shape” of its exposed “profile” to the wind, of that wing, from that of a fully asymmetrical shape when flying “right side up” to more of a symmetrical shape, to the wind direction when the plane is inverted, and of course most commonly, elevators are symmetrical (not always though) in profile and take over a large percentage of the work in keeping an aeroplane flying when inverted. The best example of symmetrical foils on a boat generating lift in a multifunctional desired directions (other than the rudders themselves) is a fixed, (in the vertical plane) rudder that has a, non-adjustable “T” foil attached to it below the waterline. When the boat starts to pitch down at the bow with the boat travelling forward, the T foil is angled down in relation to its forward direction. Due to that angle change, lift is generated on the under surface of that symmetrical T foil and it “pulls” the stern down (and conversely the bow upwards). The same applies when the bow pitches upwards. Lift is generated on the upper surface of that symmetrical T foil (for the same reasons) and the stern is lifted upwards (conversely the bow moves downwards) ergo pitch is greatly reduced. This same principle applies to symmetrical dagger boards that are canted (particularly canted inwards). Due to the “pitch” of the boat, and their continually changing inclination to the forward horizontal direction of that boat, they will generate lift in a desired (at that moment) direction. So symmetrical foils on a boat can generate lift that is “desired” in both upward and downwards directions (or side to side as in rudders), whereas “hydrofoils” on a boat will generate principal lift only in one direction all the time. That amount of lift (of a hydrofoil) is a variable directly proportional to the “speed” it is travelling. (They obviously generate some lift in the horizontal plane as well i.e. acting to reduce “leeward drift”, but that is generally secondary to their main function) For boats, the function of a symmetrical foil is more “dynamic” while the asymmetric foils function is mainly “static” P.S Luiz, these examples are primarily "as they apply to boats" so that the extreme angles of attack as described with planes, (there are other many and varied applications as well), simply should not be applied in this instance. | | | Re: Pete Melvin Wins the A-CLass Worlds
[Re: Hans_Ned_111]
#51991 08/11/05 02:15 AM 08/11/05 02:15 AM |
Posts: 3,528 Looking for a Job, I got credi... | The a-class rule about foils is that the maximum angle of the boards is so far angled that when the bottom of the centerboard is full inside the hull ( bottom hull is bottom board) the measured width on the top of the board is not more then 2,3 meter. This means that boat is never more than 2,3 mtr's in width. This means that you never get the extreme foils like the Icarus.
Hans I assume curved foils are banned ?
F16 - GBR 553 - SOLD I also talk sport here | | |
1 registered members (FredL),
446
guests, and 68
