| Prindle 16 Jib Rigging #5222 01/12/02 11:06 AM 01/12/02 11:06 AM | Anonymous OP
| Anonymous OP
Unregistered | I have just purchased a well-kept 1981 Prindle 16. The only problem I see is slipping the S-hook at the head of the jib into the O-ring at the top of the forestay. Is there a trick to doing this or is there a modification a person can make? Your advice would be appreciated.
Andrew | | | Re: Prindle 16 Jib Rigging #5223 01/14/02 08:36 AM 01/14/02 08:36 AM |
Posts: 2,844 42.904444 N; 88.008586 W | 1. make sure the ring is hanging aft of the forestay when you rig the boat.
2. Make sure the 's' has the opening to the rear when hoisting. when it goes thru the ring, just pull down to catch it.
3. When de-rigging, loosen the luff tension, and pull up the halyard slightly, the down quick to get it thru the ring. Pullin the clew to the side often helps here.
Good luck, hope this helps.
F-18 Infusion #626- SOLD it!
[Re: Todd_Sails]
#5225 01/14/02 05:28 PM 01/14/02 05:28 PM | Anonymous OP
| Anonymous OP
Unregistered | Todd,
Thanks for your reply. Your advice sounds promising. When I bought the Prindle, both the up and down portions of the jib halyard were led THROUGH the ring. Is this the proper way to do it? It does not look so. Or should only one or none of the halyard sections be going through the ring? By the way, we had a wonderful sail on it yesterday and we really like this cat.
[Re: Sailortect]
#5226 01/14/02 05:33 PM 01/14/02 05:33 PM | Anonymous OP
| Anonymous OP
Unregistered | Thanks for your additional advice. In fact, we have already resorted to pulling the "little darling" down on its side for rigging the jib halyard, but the main thing is that we had a great sail afterwards.
Andrew | | | Re: Prindle 16 Jib Rigging #5227 01/14/02 10:07 PM 01/14/02 10:07 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Yes, both sides of the halyard line go thru, if your luff tensioner is on the forestay that is. I've seen older P16's rig the halyard to the mast, in which case you would only have one. Sounds like yours is on the forestay though.
Good luck,
Todd
[Re: Todd_Sails]
#5228 01/15/02 10:23 AM 01/15/02 10:23 AM | Anonymous OP
| Anonymous OP
Thanks for your latest advice; it makes sense and I appreciate it.
| | | Re: Prindle 16 Jib Rigging #5229 03/20/02 01:40 PM 03/20/02 01:40 PM | Anonymous OP
| Anonymous OP
Unregistered | This may be obvious, but one other thing that makes it easier to catch the ring is to ensure the bow is directly into the wind. The farther off you are when raising the sail, the trickier it is to hook.
My P-16 is a lovely little Cat.
Dave | | | Re: Prindle 16 Jib Rigging
[Re: Sailortect]
#5231 03/21/02 12:49 PM 03/21/02 12:49 PM | Anonymous OP
| Anonymous OP
Unregistered | Give it a try... I've never had to tip the boat sideways to hook the jib.(only to put the main halyard wire back on the pulleys at the masthead!...UGH)
Dave
3,079
guests, and 444
