| Re: Looking for a Wave
[Re: peter]
#52298 07/02/05 07:02 AM 07/02/05 07:02 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Lots of luck, as used Waves rarely appear on the market. We have a building fleet of Waves in Key Largo, FL (winter home) and in Put-in-Bay, Ohio (summer home) and hardly ever are able to find anyone wanting to part with their Waves. If there are any folks out there willing to sell, you can also contact me at rick@catsailor.comSee ya, Rick | | | Re: Looking for a Wave
[Re: RickWhite]
#52299 07/02/05 01:17 PM 07/02/05 01:17 PM |
Posts: 41 los angeles | Well, I must admit I've gotten that feeling after searching the internet, but felt I had to try before plunking down the full pop for a new one. Thanks. I've been reading your posts about hooters, rigging, and jibs with great interest. Sailing in the ocean here I'll probably be dealing with mostly 12-15 knots of wind, so the hooter might be overkill, but I'm interested in a jib set up. Aside from the bow spreader bar, is there any point in buying Hobie's jib hardware kit? What diameter cable did you find to be appropriate for the forestay and between the bows? Your solution for getting enough luff tension seems very elegant. Did you ever put together a jib hardware kit for the Wave? What size jib do you think would work best on the Wave, if the Hobie jib is woefully undersized, and the blade jib doesn't work? Hope I'm not overburdening you with questions, it just seems that you've done a lot of work with this boat and I appreciate your experience. | | | Re: Looking for a Wave
[Re: peter]
#52300 07/03/05 07:19 AM 07/03/05 07:19 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | The Hobie jib option definitely does NOT work. I am still working on the jib setup. The sail is supposed to be here within a week or so. After that I will be able to give you an honest appraisal. Until then, it is just a guess.
While the rig I am working on includes both jib and Hooter, I suppose you could use a short bow sprit to get a proper sized jib working.
When I get the sail and get things sorted out, I will post the information. Thanks, Rick | | | Re: Looking for a Wave
[Re: Barry_Steel]
#52307 07/20/05 03:01 PM 07/20/05 03:01 PM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | I finallly have my new sails on the way for the the Wave HT. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Dont' know if it will be effective or not, but I think it will. I now have a 9'6" bow sprit with a roller furling Hooter (spinnaker) at the end, with the head at masthead level and sheets from beyond the rear beam. The jib is 5'6" out on the sprit, the head is at the hounds and is self tacking at the main beam. That should be a lot of sail area for the jib and should have no problems with luff tension. I should be able to give a full report in a week or two.
I plan on racing it in the Sandusky Steeplechase (21-mile jaunt from Sandusky to Put-in-Bay, Ohio and feeder race for the I-LYA Bay Week Regatta) Object is to outright beat the Mystere 4.3, which I am almost doing with the smaller Hooter we have been using.
Wish me luck, Rick | | |
323
guests, and 36
